Unchanging residual for nonlinear fluid dynamics problem
I am trying to run a multiphase flow problem in Dolfinx using the momentum, gas phase transport, and continuity equations. When solving the transient problem, the residual seems to change after the first iteration, but then does not change and ultimately does not converge.
Are there any steps I can take to fix the static residual problem? I changed the solver settings a few times, which changed the static residual from nan to a finite value, but still does not update.
Here is my code:
from dolfinx.fem import Constant, Function, functionspace, assemble_scalar, dirichletbc, form, locate_dofs_geometrical, locate_dofs_topological, set_bc
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_vector, set_bc
from dolfinx import mesh
from ufl import (FacetNormal, Identity, TestFunction, TrialFunction,
                 div, dot, ds, dx, inner, lhs, nabla_grad, rhs, sym)
from dolfinx.mesh import GhostMode, locate_entities_boundary
# Define domain size
width, height = 0.5, 1.0
inlet_width = 0.2
nx, ny = 100, 100
# Create mesh
domain = mesh.create_rectangle(MPI.COMM_WORLD, [[0, 0], [width, height]], [nx, ny], mesh.CellType.triangle)
# Inlet: middle portion of bottom boundary
def inlet_boundary(x):
    return np.logical_and(
        np.isclose(x[1], 0.0),  # bottom edge
        np.logical_and(
            x[0] > (width / 2 - inlet_width),
            x[0] < (width / 2 + inlet_width)
# Walls: left and right edges
def wall_boundary(x):
    return np.logical_or(
        np.isclose(x[0], 0.0),  # left
        np.isclose(x[0], width)  # right
# No-slip top boundary
def top_noslip_boundary(x):
    return np.isclose(x[1], height)  # top
with XDMFFile(domain.comm, "domain.xdmf", "w") as xdmf:
    xdmf.write_mesh(domain)
t = 0                                       # Initial time
final_t = 2                                 # Final time
dt = Constant(domain, 1/1000)
D_gc = 0.01  # Drift diffusion coeff
u_slip = Constant(domain, np.array((0.0, 1e-2), dtype=np.float64))
p_ref = 1e5
M_hydrogen = 2.02e-3  # kg/mol
T = 500
R = 8.31
rho_l = 2729.3 - 0.73 * T
mg_l = Constant(domain, 1e-5)
mu_l = Constant(domain, 4E-4 * np.exp(4170 / T))
g = Constant(domain,[0.0, -9.81])  # Example for 2D gravity vector
# Define the elements
V_ele = element("CG", domain.topology.cell_name(), 2, shape=(domain.geometry.dim, ))
Q_ele = element("CG", domain.basix_cell(), 1)  # Continuous Lagrange, degree 1
# Create a mixed function space
W = functionspace(domain, mixed_element([V_ele, Q_ele, Q_ele]))
upphi = Function(W)
upphi_n = Function(W)
vu, vp, vphi = ufl.TestFunctions(W)
u_l, p, phi_g = ufl.split(upphi)
u_l_n, p_n, phi_g_n = ufl.split(upphi_n)
phi_l = 1 - phi_g
phi_l_n = 1 - phi_g_n
# Definign sub spaces
V_sub, _ = W.sub(0).collapse()
Q1_sub, _ = W.sub(1).collapse()
Q2_sub, _ = W.sub(2).collapse()
# Inlet velocity conditions
inlet_facets = locate_entities_boundary(domain, 1, inlet_boundary)
# y-component = 1.0
u_inlety = Constant(domain, 1.0)
bcu_inlet1 = dirichletbc(u_inlety,
                         locate_dofs_topological(V_sub, 1, inlet_facets),
                         W.sub(0).sub(1))
# x-component = 0.0
u_inletx = Constant(domain, 0.0)
bcu_inlet2 = dirichletbc(u_inletx,
                         W.sub(0).sub(0))
# No-slip boundary condition for velocity
noslip = np.zeros(domain.geometry.dim, dtype=PETSc.ScalarType)
wall_facets = locate_entities_boundary(domain, 1, wall_boundary)
bc_wall = dirichletbc(noslip,
                      locate_dofs_topological(V_sub, 1, wall_facets),
                      V_sub)
top_facets = locate_entities_boundary(domain, 1, top_noslip_boundary)
bc_top = dirichletbc(noslip,
                     locate_dofs_topological(V_sub, 1, top_facets),
                     V_sub)
phi_val = Constant(domain, 0.1)
# Locate inlet dofs for phi_g
inlet_dofs_phi = locate_dofs_topological(Q2_sub, 1, inlet_facets)
# Apply DirichletBC
bc_phi_inlet = dirichletbc(phi_val, inlet_dofs_phi, Q2_sub)
# Combine all velocity BCs
bcs = [bcu_inlet1, bcu_inlet2, bc_wall, bc_top, bc_phi_inlet]
u_drift = -D_gc * ufl.grad(phi_g) / (phi_g + 1e-8)
u_g = u_l
rho_g = (p_ref + p) * M_hydrogen / (R * T)
continuity = (
    rho_l * (phi_l - phi_l_n) + rho_g * (phi_g - phi_g_n)
) / dt * vp * ufl.dx + ufl.inner(
    ufl.div(rho_l * phi_l * u_l + rho_g * phi_g * u_g), vp
) * ufl.dx
gas_phase_transport = (
    (rho_g * (phi_g - phi_g_n)) / dt * vphi * ufl.dx
    + ufl.div(rho_g * phi_g * u_l) * vphi * ufl.dx
    + ufl.inner(D_gc * rho_g * ufl.grad(phi_g), ufl.grad(vphi)) * ufl.dx
    + mg_l * vphi * ufl.dx
momentum = (
    phi_l * rho_l * ufl.inner((u_l - u_l_n) / dt, vu) * ufl.dx
    + phi_l * mu_l * ufl.inner(ufl.grad(u_l), ufl.grad(vu)) * ufl.dx
    + phi_l * rho_l * ufl.inner(ufl.grad(u_l), ufl.grad(vu)) * ufl.dx  # Fixed
    + p * ufl.div(vu) * ufl.dx
    - phi_l * rho_l * ufl.inner(g, vu) * ufl.dx
F = momentum + continuity + gas_phase_transport
problem = NonlinearProblem(F, upphi, bcs=bcs)
solver.convergence_criterion = "residual"
solver.rtol = 1e-8
solver.report = True
# PETSc solver options
ksp = solver.krylov_solver
opts = PETSc.Options()
opts[f"{option_prefix}ksp_type"] = "gmres"
opts[f"{option_prefix}ksp_rtol"] = 1.0e-10
opts[f"{option_prefix}pc_type"] = "hypre"
opts[f"{option_prefix}pc_hypre_type"] = "boomeramg"
opts[f"{option_prefix}pc_hypre_boomeramg_max_iter"] = 1
opts[f"{option_prefix}pc_hypre_boomeramg_cycle_type"] = "v"
ksp.setFromOptions()
dolfinx.log.set_log_level(dolfinx.log.LogLevel.INFO)
import os
# Save directory
save_dir = "results/"
os.makedirs(save_dir, exist_ok=True)
# Initialize VTX writers
vtx_u = VTXWriter(MPI.COMM_WORLD, f"{save_dir}u.bp", [Function(V_sub)])
vtx_p = VTXWriter(MPI.COMM_WORLD, f"{save_dir}p.bp", [Function(Q1_sub)])
vtx_phi = VTXWriter(MPI.COMM_WORLD, f"{save_dir}phi_g.bp", [Function(Q2_sub)])
vtx_u.write(t)
vtx_p.write(t)
vtx_phi.write(t)
# Time loop
while t < float(final_t):
    n, converged = solver.solve(upphi)
    assert converged
    u, p, phi_g = upphi.split()
    print("phi_g min/max:", phi_g.x.array.min(), phi_g.x.array.max())
    vtx_u.write(t)
    vtx_p.write(t)
    vtx_phi.write(t)
    print(f"Time = {t:.2f}, iterations = {n}, u[0] = {u.x.array[0]:.3e}")
    upphi_n.x.array[:] = upphi.x.array
    t += float(dt)
vtx_u.close()
vtx_p.close()
vtx_phi.close()
and the unchanging output until it reaches the max number of iterations:
[2025-04-24 14:19:30.102] [info] Newton iteration 0: r (abs) = 7142.13717233418 (tol = 1e-10), r (rel) = inf (tol = 1e-08)
[2025-04-24 14:19:30.331] [info] PETSc Krylov solver starting to solve system.
[2025-04-24 14:19:31.013] [info] Newton iteration 1: r (abs) = 41517.80332674378 (tol = 1e-10), r (rel) = 614.353097327223 (tol = 1e-08)
[2025-04-24 14:19:31.234] [info] PETSc Krylov solver starting to solve system.
[2025-04-24 14:19:31.445] [info] Newton iteration 2: r (abs) = 41517.80332674378 (tol = 1e-10), r (rel) = 614.353097327223 (tol = 1e-08)
[2025-04-24 14:19:31.663] [info] PETSc Krylov solver starting to solve system.
[2025-04-24 14:19:31.865] [info] Newton iteration 3: r (abs) = 41517.80332674378 (tol = 1e-10), r (rel) = 614.353097327223 (tol = 1e-08)
[2025-04-24 14:19:32.081] [info] PETSc Krylov solver starting to solve system.
[2025-04-24 14:19:32.283] [info] Newton iteration 4: r (abs) = 41517.80332674378 (tol = 1e-10), r (rel) = 614.353097327223 (tol = 1e-08)
What happens if you use a direct solver rather than gmres on the whole system? I’m expecting that the lack of convergence between Newton iterations that you’re seeing is actually due to a lack of convergence of your linear solver.
Hi Nate,
Thanks for your reply. I assume the direct solver is the default, so if I comment out:
I now get this:
[2025-04-24 16:22:50.604] [info] Newton iteration 0: r (abs) = 7142.13717233418 (tol = 1e-10), r (rel) = inf (tol = 1e-08)
[2025-04-24 16:22:50.843] [info] PETSc Krylov solver starting to solve system.
[2025-04-24 16:22:51.206] [info] Newton iteration 1: r (abs) = 39183.7096065598 (tol = 1e-10), r (rel) = 581.4645299766764 (tol = 1e-08)
[2025-04-24 16:22:51.431] [info] PETSc Krylov solver starting to solve system.
[2025-04-24 16:22:51.653] [info] Newton iteration 2: r (abs) = -nan (tol = 1e-10), r (rel) = -nan (tol = 1e-08)
[2025-04-24 16:22:51.886] [info] PETSc Krylov solver starting to solve system.
[2025-04-24 16:22:52.386] [info] Newton iteration 3: r (abs) = -nan (tol = 1e-10), r (rel) = -nan (tol = 1e-08)
[2025-04-24 16:22:52.608] [info] PETSc Krylov solver starting to solve system.
[2025-04-24 16:22:53.092] [info] Newton iteration 4: r (abs) = -nan (tol = 1e-10), r (rel) = -nan (tol = 1e-08)
[2025-04-24 16:22:53.311] [info] PETSc Krylov solver starting to solve system.
[2025-04-24 16:22:53.800] [info] Newton iteration 5: r (abs) = -nan (tol = 1e-10), r (rel) = -nan (tol = 1e-08)
[2025-04-24 16:22:54.021] [info] PETSc Krylov solver starting to solve system.
[2025-04-24 16:22:54.539] [info] Newton iteration 6: r (abs) = -nan (tol = 1e-10), r (rel) = -nan (tol = 1e-08)
[2025-04-24 16:22:54.901] [info] PETSc Krylov solver starting to solve system.
[2025-04-24 16:22:55.561] [info] Newton iteration 7: r (abs) = -nan (tol = 1e-10), r (rel) = -nan (tol = 1e-08)
[2025-04-24 16:22:55.887] [info] PETSc Krylov solver starting to solve system.
[2025-04-24 16:22:56.373] [info] Newton iteration 8: r (abs) = -nan (tol = 1e-10), r (rel) = -nan (tol = 1e-08)
[2025-04-24 16:22:56.595] [info] PETSc Krylov solver starting to solve system.
[2025-04-24 16:22:57.075] [info] Newton iteration 9: r (abs) = -nan (tol = 1e-10), r (rel) = -nan (tol = 1e-08)
It looks like it updates the 1st iteration residual, and then stays at -nan. Any suggestions where to go from here?
A direct solver typically is not the default. Try a ksp_type of preonly and pc_type of lu. See also PCFactorSetMatSolverType — PETSc 3.23.0 documentation to select a package/type which can support your null block.
I tried changing ksp_type to preonly, and then tried changing pc_type to lu and cholesky - both jumped to -nan on the second iteration and fails to converge.
Not sure if this is relevant, but I have a similar working model in FEniCS. Is there any way to use the same solver settings here in my Dolfinx code? If not, are there any other suggested steps?
Fenics code:
import fenics as f
width = 0.5
height = 1
mesh = f.RectangleMesh(f.Point(0, 0), f.Point(width, height), 100, 100)
# plt.figure()
# plt.plot(mesh)
V_ele = f.VectorElement("CG", mesh.ufl_cell(), 2)
Q_ele = f.FiniteElement("CG", mesh.ufl_cell(), 1)
W = f.FunctionSpace(mesh, f.MixedElement([V_ele, Q_ele, Q_ele]))
upphi = f.Function(W)
upphi_n = f.Function(W)
vu, vp, vphi = f.TestFunctions(W)
u_l, p, phi_g = f.split(upphi)
u_l_n, p_n, phi_g_n = f.split(upphi_n)
phi_l = 1 - phi_g
D_gc = 0.01  # drift diffusion coeff
u_slip = f.Constant((0.0, 1e-2))
u_drift = -D_gc * f.grad(phi_g) / (phi_g + 1e-16)
u_g = u_l + u_drift + u_slip
p_ref = 1e5 # atmosphere
density_pressure = p_ref + p
M_hydogen = 2.02e-3 # kg/mol
T = 500 # room temp
R = 8.31 # J/molK
rho_l = 2729.3 - 0.73*T
rho_g = density_pressure*M_hydogen / (R*T)  # TODO see COMSOL guide for actual expression
mg_l = f.Constant(1e-5)  # m/s
mu_l = 4E-4 *np.exp(4170/T)  # dynamic visosity
g = f.Constant((0.0, -9.81))
F = f.Constant((0.0, 0.0))
dt = f.Constant(1)
continuity = (
) / dt * vp * f.dx + f.inner(
    f.div(rho_l * phi_l * u_l + rho_g * phi_g * u_g), vp
) * f.dx
    (rho_g * (phi_g - phi_g_n)) / dt * vphi * f.dx
    + f.div(rho_g * phi_g * u_g) * vphi * f.dx  # Use u_g instead of u_l + u_slip
    + f.inner(D_gc * rho_g * f.grad(phi_g), f.grad(vphi)) * f.dx
    + mg_l * vphi * f.dx
momentum = (
    phi_l * rho_l * f.inner((u_l - u_l_n) / dt, vu) * f.dx
    + phi_l * mu_l * f.inner(f.grad(u_l), f.grad(vu)) * f.dx
    + phi_l * rho_l * f.dot(f.dot(f.grad(u_l), u_l), vu) * f.dx
    + p * f.div(vu) * f.dx
    - phi_l * rho_l * f.inner(g, vu) * f.dx
    - f.inner(F, vu) * f.dx
# Construct facet markers
bndry = f.MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
for facet in f.facets(mesh):
    mp = facet.midpoint()
    if f.near(mp[1], 0.0):  # bottom wall
        bndry[facet] = 1
    if f.near(mp[1], 0.0) and width * 0.46 < mp[0] < width * 0.48:  # bottom inlet
        bndry[facet] = 2
    if f.near(mp[1], 0.0) and width * 0.52 < mp[0] < width * 0.54:  # bottom inlet
        bndry[facet] = 2
    elif f.near(mp[1], height):  # top
        bndry[facet] = 3
    elif f.near(mp[0], 0.0) or f.near(mp[0], width):  # walls
        bndry[facet] = 1
f.XDMFFile("facets.xdmf").write(bndry)
# boundary conditions
non_slip = f.DirichletBC(W.sub(0), f.Constant((0.0, 0.0)), bndry, 1)
# pressure_top = f.DirichletBC(W.sub(1), f.Constant(1), bndry, 3)
n = f.FacetNormal(mesh)
slip_bc = f.DirichletBC(W.sub(0).sub(1), f.Constant(0.0), bndry, 3)  # Enforces no vertical velocity at top
inlet_gas = f.DirichletBC(W.sub(2), f.Constant(0.1), bndry, 2)
# bcs = [non_slip, pressure_top, inlet_gas]
bcs = [non_slip, slip_bc, inlet_gas]
file_velocity = f.XDMFFile("velocity.xdmf")
file_pressure = f.XDMFFile("pressure.xdmf")
flie_phi = f.XDMFFile("gas_fraction.xdmf")
t = 0
while t < 60:
    f.solve(F==0, upphi, bcs)
    file_velocity.write(u, t)
    file_pressure.write(p, t)
    flie_phi.write(phi_g, t)
    upphi_n.assign(upphi)
    print(f"Time = {t}")
    t += float(dt)
Cholesky factorisation expects an SPD matrix. I wouldn’t expect that to work for your system.
It may help to carefully go through your script, simplifying it step-by-step until you can produce a meaningful solution. Then build it back up making sure you can produce the expected result.
Okay, I will try that. And just to verify I am updating my variables correctly, am I missing any key steps in the time loop?
vtx_u.write(t)
vtx_p.write(t)
vtx_phi.write(t)
# Time loop
    assert converged
    vtx_u.write(t)
    vtx_p.write(t)
    vtx_phi.write(t)
    t += float(dt)
vtx_u.close()
vtx_p.close()
vtx_phi.close()
