Hello fenicsx users !
I was looking to find the minimum of a vector in parallel. From the outset, it seemed that this tutorial provided just the trick I needed.
Indeed it seems fully parallelised and it includes a maximum calculation. However, running this code in my dolfinx docker container gives different results depending on the number of processors :
root@container_id:/home/shared# mpirun -n 2 python3 tuto1.py
Error_L2 : 5.82e-03
Error_max : 1.33e-15
Error_L2 : 5.82e-03
root@container_id:/home/shared# mpirun -n 10 python3 tuto1.py
Error_L2 : 2.52e-03
Error_L2 : 2.62e-03
Error_max : 6.66e-16
Error_L2 : 2.62e-03
Error_max : 1.78e-15
Error_L2 : 2.62e-03
Error_L2 : 2.52e-03
Error_max : 1.11e-15
Error_L2 : 2.62e-03
Error_L2 : 2.62e-03
Error_L2 : 2.62e-03
Error_L2 : 2.62e-03
Error_max : 1.55e-15
Error_L2 : 2.62e-03
root@container_id:/home/shared# python3 tuto1.py
Error_L2 : 8.24e-03
Error_max : 2.66e-15
It seems compute_point_values is local. Anyone knows a way to make that a global calculation ?
Here’s tuto1.py code for convenience (by the way @dokken I think dolfinx.mesh.CellType is deprecated I had to take it out to get the code to run) :
import numpy
from dolfinx.generation import UnitSquareMesh
mesh = UnitSquareMesh(MPI.COMM_WORLD, 8, 8)
from dolfinx.fem import FunctionSpace
V = FunctionSpace(mesh, ("CG", 1))
uD = Function(V)
uD.interpolate(lambda x: 1 + x[0]**2 + 2 * x[1]**2)
fdim = mesh.topology.dim - 1
# Create facet to cell connectivity required to determine boundary facets
from dolfinx.cpp.mesh import compute_boundary_facets
mesh.topology.create_connectivity(fdim, mesh.topology.dim)
boundary_facets = numpy.where(numpy.array(compute_boundary_facets(mesh.topology)) == 1)[0]
from dolfinx.fem import locate_dofs_topological, DirichletBC
boundary_dofs = locate_dofs_topological(V, fdim, boundary_facets)
bc = DirichletBC(uD, boundary_dofs)
u = ufl.TrialFunction(V)
from dolfinx.fem import Constant
f = Constant(mesh, -6)
a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = f * v * ufl.dx
from dolfinx.fem import LinearProblem
uh = problem.solve()
V2 = FunctionSpace(mesh, ("CG", 2))
uex = Function(V2)
uex.interpolate(lambda x: 1 + x[0]**2 + 2 * x[1]**2)
from dolfinx.fem import assemble_scalar
L2_error = ufl.inner(uh - uex, uh - uex) * ufl.dx
error_L2 = numpy.sqrt(assemble_scalar(L2_error))
u_vertex_values = uh.compute_point_values()
u_ex_vertex_values = uex.compute_point_values()
error_max = numpy.max(numpy.abs(u_vertex_values - u_ex_vertex_values))
print(f"Error_L2 : {error_L2:.2e}")
print(f"Error_max : {error_max:.2e}")
