Unknown ufl object type VectorElement
I have fenics 2019.1.0 version installed in ubuntu 22. I am running the Incompressible Navier-Stokes equations for channel flow (tutorial example), but getting the following error:
“Unknown ufl object type VectorElement”
which points to this line of code " V = VectorFunctionSpace(mesh, ‘P’, 2)"
Please what I’m I doing wrong?
Code:
from future import print_function
“import matplotlib.pyplot as plt”
T = 5.0 # final time
num_steps = 500 # number of time steps
mu = 1 # kinematic viscosity
rho = 1 # density
Create mesh and define function spaces
mesh = UnitSquareMesh(16, 16)
Q = FunctionSpace(mesh, ‘P’, 1)
Define boundaries
inflow = ‘near(x[0], 0)’
outflow = ‘near(x[0], 1)’
walls = ‘near(x[1], 0) || near(x[1], 1)’
Define boundary conditions
bcu_noslip = DirichletBC(V, Constant((0, 0)), walls)
bcp_inflow = DirichletBC(Q, Constant(8), inflow)
bcp_outflow = DirichletBC(Q, Constant(0), outflow)
bcu = [bcu_noslip]
bcp = [bcp_inflow, bcp_outflow]
Define trial and test functions
p = TrialFunction(Q)
q = TestFunction(Q)
Define functions for solutions at previous and current time steps
u_n = Function(V)
u_ = Function(V)
p_n = Function(Q)
p_ = Function(Q)
Define expressions used in variational forms
U = 0.5 * (u_n + u)
f = Constant((0, 0))
k = Constant(dt)
mu = Constant(mu)
rho = Constant(rho)
Define strain-rate tensor
return sym(nabla_grad(u))
Define stress tensor
def sigma(u, p):
return 2 * mu * epsilon(u) - p * Identity(len(u))
Define variational problem for step 1
F1 = rho * dot((u - u_n) / k, v) * dx +
rho * dot(dot(u_n, nabla_grad(u_n)), v) * dx
+ inner(sigma(U, p_n), epsilon(v)) * dx
+ dot(p_n * n, v) * ds - dot(mu * nabla_grad(U) * n, v) * ds
- dot(f, v) * dx
a1 = lhs(F1)
L1 = rhs(F1)
Define variational problem for step 2
a2 = dot(nabla_grad(p), nabla_grad(q)) * dx
L2 = dot(nabla_grad(p_n), nabla_grad(q)) * dx - (1 / k) * div(u_) * q * dx
Define variational problem for step 3
a3 = dot(u, v) * dx
L3 = dot(u_, v) * dx - k * dot(nabla_grad(p_ - p_n), v) * dx
Assemble matrices
A1 = assemble(a1)
A2 = assemble(a2)
A3 = assemble(a3)
Apply boundary conditions to matrices
[bc.apply(A1) for bc in bcu]
[bc.apply(A2) for bc in bcp]
Time-stepping
t = 0
for n in range(num_steps):
# Update current time
b1 = assemble(L1)
# [bc.apply(b1) for bc in bcu]
solve(A1, u_.vector(), b1)
b2 = assemble(L2)
[bc.apply(b2) for bc in bcp]
solve(A2, p_.vector(), b2)
b3 = assemble(L3)
solve(A3, u_.vector(), b3)
# Plot solution
velocity = plot(u_)
# Compute error
u_e = Expression(('4*x[1]*(1.0 - x[1])', '0'), degree=2)
u_e = interpolate(u_e, V)
error = np.abs(np.array(u_e.vector()) - np.array(u_.vector())).max()
print('t = %.2f: error = %.3g' % (t, error))
print('max u:', np.array(u_.vector()).max())
# Update previous solution
u_n.assign(u_)
p_n.assign(p_)
Hold plot
interactive()
Thanks for helping in advance
How Did you install dolfin?
I installed it via command line using:
sudo apt install dolphin
Thanks.
I cannot reproduce your issue on a clean ubuntu 22.04 system:
 docker run -ti -v ${PWD}:/root/shared  --rm  ubuntu:22.04
apt-get update
apt-get install -y software-properties-common
add-apt-repository ppa:fenics-packages/fenics
apt-get install -y fenics
cd /root/shared/
cat mwe.py
python3 mwe55.py
yielding
V = VectorFunctionSpace(mesh, "P", 2)
and
 python3 -c "import dolfin; print(dolfin.__version__)"
yielding
2019.2.0.dev0
Please add full traceback of your error message, and please encapsulate all code or output as
```python
# add code here
```bash
Add terminal output here
Okay
Thank you very much, I tried with anaconda and it has worked now.
So thanks so much.
Hi I have a similar error:
I installed dolfin and
yields
2019.2.0.dev0
but running the poisson.py from the tutorial:
FEniCS tutorial demo program: Poisson equation with Dirichlet conditions.
Test problem is chosen to give an exact solution at all nodes of the mesh.
  -Laplace(u) = f    in the unit square
            u = u_D  on the boundary
  u_D = 1 + x^2 + 2y^2
    f = -6
mesh = UnitSquareMesh(8, 8)
# Define boundary condition
u_D = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]', degree=2)
def boundary(x, on_boundary):
    return on_boundary
f = Constant(-6.0)
a = dot(grad(u), grad(v))*dx
L = f*v*dx
# Compute solution
solve(a == L, u, bc)
# Plot solution and mesh
plot(u)
plot(mesh)
# Save solution to file in VTK format
vtkfile = File('poisson/solution.pvd')
vtkfile << u
# Compute error in L2 norm
error_L2 = errornorm(u_D, u, 'L2')
# Compute maximum error at vertices
vertex_values_u_D = u_D.compute_vertex_values(mesh)
error_max = np.max(np.abs(vertex_values_u_D - vertex_values_u))
# Print errors
print('error_L2  =', error_L2)
print('error_max =', error_max)
# Hold plot
yields this output:
Unknown ufl object type FiniteElement
  File "/home/kb/Documents/fenics-tutorial/src/vol1/python/./poisson.py", line 18, in <module>
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/function/functionspace.py", line 33, in __init__
    self._init_convenience(*args, **kwargs)
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/function/functionspace.py", line 100, in _init_convenience
    self._init_from_ufl(mesh, element, constrained_domain=constrained_domain)
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/function/functionspace.py", line 42, in _init_from_ufl
    ufc_element, ufc_dofmap = ffc_jit(element, form_compiler_parameters=None,
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/jit/jit.py", line 50, in mpi_jit
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/jit/jit.py", line 100, in ffc_jit
  File "/home/kb/.local/lib/python3.10/site-packages/ffc/jitcompiler.py", line 214, in jit
    kind, module_name = compute_jit_prefix(ufl_object, parameters)
  File "/home/kb/.local/lib/python3.10/site-packages/ffc/jitcompiler.py", line 156, in compute_jit_prefix
    error("Unknown ufl object type %s" % (ufl_object.__class__.__name__,))
  File "<string>", line 1, in <lambda>
  File "/home/kb/.local/lib/python3.10/site-packages/ufl/log.py", line 172, in error
Exception: Unknown ufl object type FiniteElement
I would be thankful for any input.
Thanks and BR Philipp
i have same problem, using legacy fenics
code:
import random
from dolfin import FiniteElement, FunctionSpace
for i in range(1, 10):
mesh_file = f"result_{i}.xml"
domains_file = f"result_{i}physical_region.xml"
boundaries_file = f"result
{i}_facet_region.xml"
mesh = Mesh(mesh_file)
domains = MeshFunction("size_t", mesh, domains_file)
boundaries = MeshFunction("size_t", mesh, boundaries_file)
g = Constant(0.0)
boundary_markers = boundaries.array()
boundary1_marker = 1
boundary2_marker = 2
boundary_subdomains = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
boundary_subdomains.set_all(0)
boundaries.array()[:] = boundary_subdomains.array()[:]
bc1 = DirichletBC(V, g, boundary_subdomains, boundary1_marker)
bc2 = DirichletBC(V, g, boundary_subdomains, boundary2_marker)
k_expr = Expression("sin(x[0])*cos(x[1])", degree=2)
k = Function(V)
k.interpolate(k_expr)
f = Constant(1)
a = Constant(1) * inner(grad(u), grad(v)) * dx
L = f * v * dx
u_sol = Function(V)
k_val = random.uniform(-1, 1)
k_expr = Expression("sin(x[0])*cos(x[1]) * {}".format(k_val), degree=2)
print("k = {}".format(k(0.5, 0.5)))
solve(a == L, u_sol, [bc1, bc2])
print("u = {}".format(u_sol(0.5, 0.5)))
file_u = File(f"u_{i}.pvd")
file_k = File(f"k_{i}.pvd")
file_u << u_sol
file_k << k
Error:
File /usr/lib/petsc/lib/python3/dist-packages/dolfin/function/functionspace.py:100, in FunctionSpace._init_convenience(self, mesh, family, degree, form_degree, constrained_domain, restriction) 93 def _init_convenience(self, mesh, family, degree, form_degree=None, 94 constrained_domain=None, restriction=None): 95 96 # Create UFL element 97 element = ufl.FiniteElement(family, mesh.ufl_cell(), degree, 98 form_degree=form_degree) → 100 self._init_from_ufl(mesh, element, constrained_domain=constrained_domain)
afaik I installed it that way:
sudo apt-get update
sudo apt-get install --no-install-recommends fenics
I’m working on a Ubuntu 22.04.2 LTS system
Why are you using
Is there an version inconsistency? What is the full traceback of your error message.
In the above
Uses a mixture of global and local packages.
So you would recommend to reinstall fenics?
Which way of installing is recommended?
I don’t have a preferred version.
Delete /home/kb/.local/lib/python3.10/site-packages. Never (ever) use pip to install package suites. It is unable to maintain version dependencies. Installation methods are summarised at GitHub - FEniCS/dolfinx: Next generation FEniCS problem solving environment.
sudo apt-get install fenics fenicsx
this solved the issue, thank you so much!
Hi everyone,
I am currently trying to make fenics work, however I have the following consistent problem when I compile the demo poisson.py code :
hwloc/linux: Ignoring PCI device with non-16bit domain.
Pass --enable-32bits-pci-domain to configure to support such devices
(warning: it would break the library ABI, don’t enable unless really needed).
So I have the same problem with unknown ufl but also this problem linked to hwloc. Does someone have an idea on how to fix this ? I am on Ubuntu and tried to install fenics as described on the installation page with Ubuntu packages.
Thanks, have a nice day
Please state what version of FEniCS (legacy or DOLFINx) and what release of any of those versions you are using (20xy.z.w for legacy and x.y.z) for DOLFINx.
If I am not mistaking, it is the FEniCS legacy 2019.2.0.dev0 version I am using
Possibly you are trying to use new ufl with the legacy dolfin.
Make sure you access ufl_legacy instead,
cf. Announcement: ufl_legacy and legacy dolfin
But if you are starting a new project, consider using dolfinx instead.
Let us know if ufl_legacy fixes your issue.
I think ufl_legacy fixed one problem, thank you !
But, with the following code :
from ufl_legacy import *
    return on_boundary
f = Constant(-6.0)
L = f*v*dx
# Compute solution
plt.plot(u)
plt.plot(mesh)
vtkfile << u
# Print errors
# Hold plot
I still have the following error :
(warning: it would break the library ABI, don't enable unless really needed).
  File "/home/juvanderhaeg/Documents/Projet python/fen_test.py", line 19, in <module>
TypeError: FunctionSpace.__init__() takes 3 positional arguments but 4 were given
You should be really careful with wildcard imports. There is no reason (and dangerous) to have two packages with wildcard import. Please remove from ufl_legacy import * or move it above the fenics import, as both packages are using the same namespace
Please, can you explain how have you solved it by Anaconda?
