I’m learning how to update a Dirichlet BC in a time-dependent simulation. I have a moving wall displacing fluid as it moves. The full script is as follows:
from vedo.dolfin import ProgressBar, plot
import random
class top_wall(SubDomain):
return near(x[1], H)
class bottom_wall(SubDomain):
return near(x[1], 0)
#=============== Space and time parameters
L = 2*np.pi # Length of channel
H = 1 # Height of channel
Time = 1 # Total time
num_steps = 100 # number of time steps
dt = Time / num_steps # time step size
# Fluid parameters
mu = 1 # kinematic viscosity
rho = 1 # density
#=============== Create mesh
channel = Rectangle(Point(0,0), Point(L, H))
mesh = generate_mesh(channel, 40)
top = top_wall()
bottom = bottom_wall()
bmesh = BoundaryMesh(mesh, "exterior", True)
bmf = MeshFunction("size_t", bmesh, 0)
bmf.set_all(0)
top.mark(bmf, 1) # mark moving boundary
#=============== Create variational formulation
Q = FunctionSpace(mesh, 'P', 1)
# Apply boundary condition
noslip = DirichletBC(V, Constant((0, 0)), bottom)
moving_wall = DirichletBC(V, Constant((0, 0)), top)
bcu = [noslip, moving_wall]
p = TrialFunction(Q)
q = TestFunction(Q)
# Define functions for solutions at previous and current time steps
u_n = Function(V)
u_ = Function(V)
p_n = Function(Q)
p_ = Function(Q)
U = 0.5*(u_n + u)
f = Constant((0, 0))
k = Constant(dt)
mu = Constant(mu)
rho = Constant(rho)
# Define strain-rate tensor
return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
return 2*mu*epsilon(u) - p*Identity(len(u))
# Define variational problem for step 1
F1 = rho*dot((u - u_n) / k, v)*dx + \
rho*dot(dot(u_n, nabla_grad(u_n)), v)*dx \
+ inner(sigma(U, p_n), epsilon(v))*dx \
+ dot(p_n*n, v)*ds - dot(mu*nabla_grad(U)*n, v)*ds \
- dot(f, v)*dx
a1 = lhs(F1)
L1 = rhs(F1)
a2 = dot(nabla_grad(p), nabla_grad(q))*dx
L2 = dot(nabla_grad(p_n), nabla_grad(q))*dx - (1/k)*div(u_)*q*dx
a3 = dot(u, v)*dx
L3 = dot(u_, v)*dx - k*dot(nabla_grad(p_ - p_n), v)*dx
# Assemble matrices
A1 = assemble(a1)
A2 = assemble(a2)
A3 = assemble(a3)
# Apply boundary conditions to matrices
[bc.apply(A1) for bc in bcu]
t = 0.0
for n in range(num_steps):
# Update current time
b1 = assemble(L1)
[bc.apply(b1) for bc in bcu]
solve(A1, u_.vector(), b1)
b2 = assemble(L2)
# [bc.apply(b2) for bc in bcp]
solve(A2, p_.vector(), b2)
b3 = assemble(L3)
solve(A3, u_.vector(), b3)
wall_vel = []
for i in range(bmesh.num_vertices()):
if (bmf[i] == 1): # The moving boundary is marked with #1
x_old = bmesh_coordinates()[i,0]
y_old = bmesh_coordinates()[i,1]
# Move mesh
bmesh.coordinates()[i,1] -= 0.001
x_new = bmesh_coordinates()[i,0] # it will always be the same in this MWE
y_new = bmesh_coordinates()[i,1]
# Store boundary velocity
wall_vel.append([(x_new - x_old)/dt, (y_new - y_old)/dt])
# Update the boundary velocity data -> update moving_wall with wall_vel
moving_wall.assign(np.asarray(wall_vel))
ALE.move(mesh, bmesh)
mesh.smooth()
I apologize for the not-so-small MWE, I didn’t know how to represent this issue without providing a general overview of how the boundaries are being defined and how the system is being solved. I’ve found some examples that uses Expressions to update boundary values, but I still didn’t figure out how to assign an entire array into the boundary velocity value as time goes. Also, is it good to define the boundaries as python classes for time-varying boundary conditions?
Any sugestions will be of great value.
