Use write_function of xdmf in timeloop in parallel
Version:
fenics-dolfinx 0.9
installed via spack
spack add fenics-dolfinx+petsc+adios2 py-fenics-dolfinx cflags="-O3" fflags="-O3"
I tried to use fenicsx in parallel and i am confused how to use the write_function of xdmf the right way on mutiple ranks.
While the write_function works in parallel outside of the time loop, inside the time loop i get only results from rank 0 written to the file (see pictures).
MWE:
from dolfinx import fem, mesh, log, io
domain = mesh.create_unit_square(MPI.COMM_WORLD, nx=4, ny=4, cell_type=mesh.CellType.triangle, ghost_mode=mesh.GhostMode.none)
#FunctionSpace Output
DG0 = fem.functionspace(domain, ("DG", 0))
rank_mpi = fem.Function(DG0)
F = fem.Function(DG0)
rank_mpi.x.array[:] = MPI.COMM_WORLD.Get_rank()
F.x.array[:] = 1.0
t = 0
with io.XDMFFile(MPI.COMM_WORLD, "mpi_test.xdmf", "w") as xdmf:
     xdmf.write_mesh(domain)
     F.name = "test"
     rank_mpi.name = "rank"
     xdmf.write_function(rank_mpi)
for n in range(10):
     t += 0.1
     xdmf.write_function(F, t)
     xdmf.write_function(rank_mpi, t)
     print("rank", rank_mpi.x.array[:])
Am I missing something fundamental here?
best regards
I think you close the file before the loop (with statement in Python | GeeksforGeeks)
Consider:
    MPI.COMM_WORLD,
    nx=4,
    ny=4,
    ghost_mode=mesh.GhostMode.none,
# FunctionSpace Output
F.x.array[:] = 1.0
t = 0
xdmf = io.XDMFFile(MPI.COMM_WORLD, "mpi_test.xdmf", "w")
F.name = "test"
for n in range(10):
    t += 0.1
xdmf.close()
@evdkmv thanks a lot for the catch, this solved the problem:D
