Hi everyone,
I am currently trying to solve a heat equation problem where I want the values of some constants within my heat equation to change when the temperature at a node of my mesh exceed some value (shown as Tmelting in my code). Currently, I am attempting to implement this via a conditional function:
assign(kappa, project(conditional(gt(T, Tmelting), kappa_l, kappa_s), Space, solver_type = "mumps", form_compiler_parameters={"cpp_optimize": True, "representation":"uflacs", "quadrature_degree": 2} ))
# kappa_l = value of kappa if T > Tmelt
# kappa_s = value of kappa if T < Tmelt
Where kappa, kappa_l and kappa_s are all tensors. My aim with this code is to have the value of kappa change from kappa_s to kappa_l when T > Tmelt and have this new value fed back into the weak form for the next time step in my problem. However I am currently getting an error code:
File "target3D_surface2.py", line 193, in <module>
AttributeError: 'float' object has no attribute '_cpp_object'
Orginially I assumed this was from the floats I had previously used for kappa_l and kappa_s instead of the tensors required by the project function, but now I am now sure. Could anybody be able to help with determining the root of the error?
The relevant code is shown below:
#from mshr import *
from ufl import as_tensor
from ufl import Index
import math
parameters["allow_extrapolation"] = True
set_log_level(20)
#Configure for dimensions of system
#----------THERMAL--PROPERTIES--(Solid)--------
kappa_s = 138.0 #conductivity [W/m K]
c_s = 277.17 #Specific Heat Capacity [J/kg K]
rho_s = 10000.0 #Density [kg/m^3]
tau_T = 0.0 #Temperature Gradient Lag
tau_q = 0.0 #Heat Flux Lag
alpha_s = 5.1162e+7 #absorption coefficient (m^-1)
epsilon_s = 0.05 # material emissivity
#----------THERMAL--PROPERTIES--(liquid)--------
Tmelting = 2896.0
kappa_l = 80.0 #conductivity [W/m K]
c_l = 350.0 #Specific Heat Capacity [J/kg K]
rho_l = 9330.0 #Density [kg/m^3]
alpha_l = 5.1162e+7 #absorption coefficient (m^-1)
epsilon_l = 0.2 # material emissivity
pi = 3.141592653589793
T_am = 300 #ambient vacuum temperature (K)
T_a4 = T_am**4
sigma = 5.67E-8 # W/(m**2.K**4) S-B Constant
Pmax = 200 #peak power of laser in W
w = 0.56e-3 #m
Iden = Pmax / (pi*w*w) #Intensity
Laser = Expression('B*A*Iden*exp(-pow((x[0] - 0), 2)/(w*w)-pow((x[1]-0), 2)/(w*w))',degree=2, A=1, Iden=Iden, w= w, B = 1) #power (w2 localises the z-coordinates)
data = 'mesh_2mm'
mesh = Mesh()
hdf = HDF5File(mesh.mpi_comm(), data+'.h5', 'r')
hdf.read(mesh, '/mesh', False)
cells = MeshFunction('size_t', mesh, 3)
hdf.read(cells, '/cells')
facets = MeshFunction('size_t', mesh, 2)
hdf.read(facets, '/facets')
Space = FunctionSpace(mesh, 'P', 1) #define finite element function space, defined via basis functions
VectorSpace = VectorFunctionSpace(mesh, 'P', 1)
da = Measure('ds', domain=mesh, subdomain_data = facets, metadata = {'quadrature_degree': 2}) #area element
dv = Measure('dx', domain=mesh, subdomain_data = cells, metadata = {'quadrature_degree': 2}) #volume element
T = Function(Space)
T0 = Function(Space)
T_init = Expression('Tambient', degree=1, Tambient=300.)
T = project(T_init, Space)
assign(T0,T)
V = TestFunction(Space) # Test Function used for FEA
dT = TrialFunction(Space) # Temperature Derivative
q0 = Function(VectorSpace) # heat flux at previous time step
i = Index()
G = as_tensor(T.dx(i), (i)) #gradient of T
G0 = as_tensor(T0.dx(i), (i)) # gradient of T at previous time step
#assign initial values for weak form
kappa = kappa_s #conductivity [W/m K]
c = c_s #Specific Heat Capacity [J/kg K]
rho = rho_s #Density [kg/m^3]
epsilon = epsilon_s # material emissivity
A = epsilon
es = epsilon*sigma
q = as_tensor(dtime/(dtime + tau_q) * (tau_q/dtime*q0[i] - kappa*(1+tau_T/dtime)*G[i] + kappa*tau_T/dtime*G0[i]),(i)) #heat
F = (rho*c/dtime*(T-T0)*V - q[i]*V.dx(i)) * dv + es*(T**4 - T_a4)*V*da - A*Laser*V*da(2) #final form to solve
Gain = derivative(F, T, dT) # Gain will be used as the Jacobian required to determine the evolution of a dynamic system
problem = NonlinearVariationalProblem(F, T, [], Gain)
solver.parameters["newton_solver"]["relative_tolerance"] = 1E-3
solver.parameters["newton_solver"]["absolute_tolerance"] = 1E-4
solver.parameters["newton_solver"]["convergence_criterion"] = "residual"
solver.parameters["newton_solver"]["error_on_nonconvergence"] = True
solver.parameters["newton_solver"]["linear_solver"] = "gmres"
solver.parameters["newton_solver"]["lu_solver"]["symmetric"] = False
solver.parameters["newton_solver"]["maximum_iterations"] = 100
solver.parameters["newton_solver"]["preconditioner"] = "amg"
solver.parameters["newton_solver"]["relaxation_parameter"] = 1.05
solver.parameters["newton_solver"]["report"] = False
solver.parameters["newton_solver"]["krylov_solver"]["nonzero_initial_guess"] = True
solver.parameters["newton_solver"]["krylov_solver"]["relative_tolerance"] = 1E-5
solver.parameters["newton_solver"]["krylov_solver"]["absolute_tolerance"] = 1E-6
solver.parameters["newton_solver"]["krylov_solver"]["monitor_convergence"] = False
solver.parameters["newton_solver"]["krylov_solver"]["maximum_iterations"] = 100000
file_T = File('/test/solution.pvd')
t = 0
solver.solve()
kappa = as_tensor(kappa,())
kappa_s = as_tensor(kappa_s,())
kappa_l = as_tensor(kappa_l,())
c = as_tensor(c,())
rho = as_tensor(rho,())
epsilon = as_tensor(epsilon,())
file_T << (T,t)
assign(q0, project(q, VectorSpace, solver_type= "bicgstab", form_compiler_parameters={"cpp_optimize": True, "representation": "uflacs", "quadrature_degree": 2} ) )
assign(T0, T)
