Hi everyone. I am implementing a P2-P0 incompressible formulation with a fieldsplit preconditioner with a Nest matrix for efficiency, and because there is no static condensation in fenics (2019). My problem runs in serial but fails to converge in parallel, so I’m guessing that the problem lies in ghost nodes or somewhere in the reordering? Here is the MWE (sorry for the length), hopefully someone will see a problem, as I do not. Anyone with experience in such type of applications? I have looked at the Nest interface in 2019, but can’t see how to use i) SNES and ii) set a fieldsplit in the snes.ksp.pc object.
Thanks!
parameters["form_compiler"]["quadrature_degree"] = 3
parameters["mesh_partitioner"] = "ParMETIS"
parameters["reorder_dofs_serial"] = False # Already checked, this is not part of the problem.
denom = 6.0
# Set options for KSP
PETSc.Options().setValue("-ksp_type", "gmres")
PETSc.Options().setValue("-ksp_atol", 1e-12)
PETSc.Options().setValue("-ksp_rtol", 1e-6)
PETSc.Options().setValue("-pc_type", "fieldsplit")
PETSc.Options().setValue("-snes_monitor", None)
PETSc.Options().setValue("-ksp_monitor", None)
PETSc.Options().setValue("-snes_linesearch_type", "basic")
# Fieldsplit specs, using full everywhere for debug.
PETSc.Options().setValue("-pc_fieldsplit_type", "schur")
PETSc.Options().setValue("-pc_fieldsplit_schur_fact_type", "full")
PETSc.Options().setValue("-pc_fieldsplit_schur_precondition", "full") # selfp | a11
# KSP 0
PETSc.Options().setValue("-fieldsplit_0_ksp_type", "preonly") # preonly | gmres
PETSc.Options().setValue("-fieldsplit_0_pc_type", "lu")
# KSP 1
PETSc.Options().setValue("-fieldsplit_1_ksp_type", "preonly")
PETSc.Options().setValue("-fieldsplit_1_pc_type", "lu") # hypre!
# Model params
N = 2
u_deg = 2
nx = (N+1)*2
ny = (N+1)*1
lx = 8 # m
ly = 1 # m
theta = pi/denom
mesh = UnitSquareMesh(nx, ny)
Vu = VectorFunctionSpace(mesh, 'CG', u_deg)
Vp = FunctionSpace(mesh, 'DG', 0)
if MPI.COMM_WORLD.rank == 0:
dofs_tot = Vu.dim() + Vp.dim()
print("Problem dofs = {} ({} + {}), dofs/core = {}".format(dofs_tot,
Vu.dim(), Vp.dim(), dofs_tot / MPI.COMM_WORLD.size), flush=True)
# Mark boundary subdomians
left = CompiledSubDomain("near(x[0], side) && on_boundary", side=0.0)
right = CompiledSubDomain("near(x[0], side) && on_boundary", side=lx)
# Define Dirichlet boundary (x = 0 or x = lx)
c = Constant(("0.0", "0.0"))
r = Expression(("scale*0.0",
"scale*(y0 + (x[1] - y0)*cos(theta) - x[1])"),
scale=0.5, y0=0.5, theta=theta, degree=1)
bcl = DirichletBC(Vu, c, left)
bcr = DirichletBC(Vu, r, right)
bcs = [bcl, bcr]
ap = 9000 # Pa
bp = 9000 # Pa
# Define functions
du, dp = TrialFunction(Vu), TrialFunction(Vp)
v, q = TestFunction(Vu), TestFunction(Vp)
u, p = Function(Vu), Function(Vp)
sol = PETSc.Vec().createNest([u.vector().vec().copy(), p.vector().vec().copy()])
# Kinematics
d = mesh.geometry().dim()
I = Identity(d) # Identity tensor
J = det(F)
H = J * inv(F).T
# Problem definition
psi = Constant(ap) * (inner(F, F) - d) + Constant(bp) * \
(inner(H, H)) - Constant(4 * bp + 2 * ap) * ln(J)
Pi = psi*dx - p * (J - 1) * dx
Res_u = derivative(Pi, u, v)
Res_p = derivative(Pi, p, q)
Jac_uu = derivative(Res_u, u, du)
Jac_up = derivative(Res_u, p, dp)
Jac_pu = derivative(Res_p, u, du)
Jac_pp = derivative(Res_p, p, dp)
class SNESProblem():
def __init__(self, FFs, JJs, uu, pp, bbcs):
self.Ls = FFs
self.Js = JJs
self.bcs = bbcs
self.bcs0 = [DirichletBC(_bc) for _bc in bbcs]
for bc in self.bcs0:
bc.homogenize()
self.u = uu
self.p = pp
def assemble_F(self, FF):
# if MPI.COMM_WORLD.rank == 0:
Fu, Fp = FF.getNestSubVecs()
assemble(self.Ls[0], tensor=PETScVector(Fu))
assemble(self.Ls[1], tensor=PETScVector(Fp))
bc.apply(PETScVector(Fu))
Fu.assemble()
FF.assemble() # Something is not getting updated otherwise
def assemble_J(self, JJ):
Juu = JJ.getNestSubMatrix(0, 0)
Jup = JJ.getNestSubMatrix(0, 1)
Jpu = JJ.getNestSubMatrix(1, 0)
Jpp = JJ.getNestSubMatrix(1, 1)
Juu.setBlockSize(d)
Jpp.setBlockSize(1)
assemble(self.Js[0], tensor=PETScMatrix(Juu))
assemble(self.Js[1], tensor=PETScMatrix(Jup))
assemble(self.Js[2], tensor=PETScMatrix(Jpu))
assemble(self.Js[3], tensor=PETScMatrix(Jpp))
MM = Juu.getDiagonal().sum() / Juu.getSize()[0]
indexes = [*bc.get_boundary_values().keys()]
Juu.zeroRows(indexes, diag=MM)
Jup.zeroRows(indexes, diag=0.0)
Juu.assemble()
Jup.assemble()
JJ.assemble()
def F(self, snes, xx, FF):
xu, xp = xx.getNestSubVecs()
xu.copy(self.u.vector().vec())
xp.copy(self.p.vector().vec())
self.u.vector().apply("")
self.p.vector().apply("")
self.assemble_F(FF)
def J(self, snes, xx, JJ, PP):
self.assemble_J(JJ)
for bc in bcs:
solu = sol.getNestSubVecs()[0]
bc.apply(PETScVector(solu))
# Create indexes by hand... not working.
# dofs_s = Vu.dofmap().dofs()
# dofs_p = Vp.dofmap().dofs()
# LL = Vu.dim()
# dofs_p = [i + LL for i in dofs_p]
# is_0 = PETSc.IS().createGeneral(dofs_s)
# is_1 = PETSc.IS().createGeneral(dofs_p)
b = PETSc.Vec().createNest([u.vector().vec().copy(), p.vector().vec().copy()])
uu_temp = PETScMatrix()
up_temp = PETScMatrix()
pu_temp = PETScMatrix()
pp_temp = PETScMatrix()
assemble(Jac_uu, tensor=uu_temp)
assemble(Jac_up, tensor=up_temp)
assemble(Jac_pu, tensor=pu_temp)
assemble(Jac_pp, tensor=pp_temp)
ru, rp = b.getNestSubVecs()
assemble(Res_u, tensor=PETScVector(ru))
assemble(Res_p, tensor=PETScVector(rp))
uu_temp.mat().setBlockSize(d)
pp_temp.mat().setBlockSize(1)
J_mat = PETSc.Mat().createNest([[uu_temp.mat(), up_temp.mat()], [
pu_temp.mat(), pp_temp.mat()]]) # Nested matrix
is_0, is_1 = J_mat.getNestISs()[0]
b.assemble()
J_mat.assemble()
problem = SNESProblem([Res_u, Res_p], [Jac_uu, Jac_up, Jac_pu, Jac_pp], u, p, bcs, is_0, is_1)
MM = uu_temp.mat().getDiagonal().sum() / len(is_0.getIndices())
for bc in bcs:
BC = DirichletBC(bc)
BC.homogenize()
# BC.apply(uu_temp)
BC.apply(PETScVector(ru))
uu_temp.mat().zeroRows(indexes, diag=MM)
up_temp.mat().zeroRows(indexes, diag=0.0)
snes = PETSc.SNES().create(MPI.COMM_WORLD)
snes.setFunction(problem.F, b)
snes.setJacobian(problem.J, J_mat)
# Set up fieldsplit
ksp = snes.getKSP()
pc = ksp.getPC()
pc.setType("fieldsplit")
pc.setFieldSplitIS(("0", is_0), ("1", is_1))
# Setup and solve
snes.setFromOptions()
snes.ksp.setFromOptions()
snes.solve(None, sol)
