@niewiarowski Hi, sorry for the intrusion but were you able to figure this out? I’m getting the exact same problem:
Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations 1
Apparently, SNES is not picking up the residual function correctly for some reason, these are the linesearch iterations:
Line search: gnorm after quadratic fit 2.031122937974e-01
Line search: Cubic step no good, shrinking lambda, current gnorm 2.031122937974e-01 lambda=1.0000000000000002e-02
Line search: Cubic step no good, shrinking lambda, current gnorm 2.031122937974e-01 lambda=1.0000000000000002e-03
Line search: Cubic step no good, shrinking lambda, current gnorm 2.031122937974e-01 lambda=1.0000000000000003e-04
Line search: Cubic step no good, shrinking lambda, current gnorm 2.031122937974e-01 lambda=1.0000000000000004e-05
Line search: Cubic step no good, shrinking lambda, current gnorm 2.031122937974e-01 lambda=1.0000000000000004e-06
Line search: Cubic step no good, shrinking lambda, current gnorm 2.031122937974e-01 lambda=1.0000000000000005e-07
Line search: Cubic step no good, shrinking lambda, current gnorm 2.031122937974e-01 lambda=1.0000000000000005e-08
Line search: Cubic step no good, shrinking lambda, current gnorm 2.031122937974e-01 lambda=1.0000000000000005e-09
Line search: Cubic step no good, shrinking lambda, current gnorm 2.031122937974e-01 lambda=1.0000000000000006e-10
Line search: Cubic step no good, shrinking lambda, current gnorm 2.031122937974e-01 lambda=1.0000000000000006e-11
Line search: Cubic step no good, shrinking lambda, current gnorm 2.031122937974e-01 lambda=1.0000000000000006e-12
Line search: Cubic step no good, shrinking lambda, current gnorm 2.031122937974e-01 lambda=1.0000000000000007e-13
Best!
Nicolas
