Using quadrature function space
Can anyone help me understand this warning? (I am trying to use quadrature function space)
Ignoring precision in integral metadata compiled using quadrature representation. Not implemented
Without any code to reproduce the error and a version specification of what dolfin you are using and how you installed it, it is hard to Give Amy guidance
I apologize for the delay. ( I am trying to convert the fenics tutorial on plasticity to displacement control problem) This is my code, in addition to this warning my code is diverging if the time step is not too small.
from matplotlib import pyplot
parameters["form_compiler"]["representation"] = 'quadrature'
import warnings
from ffc.quadrature.deprecation import QuadratureRepresentationDeprecationWarning
warnings.simplefilter("once", QuadratureRepresentationDeprecationWarning)
# material parameters
E = Constant(180e3)
nu = Constant(0.28)
lmbda = Constant(89633)
mu = Constant(70300)
sig0 = Constant(443)  # yield strength
H = Constant(300)  # hardening modulus
mesh = UnitSquareMesh(200,200)
top = CompiledSubDomain("near(x[1], 1.0) && on_boundary")
bot = CompiledSubDomain("near(x[1], 0.0) && on_boundary")
deg_u = 2
deg_stress = 2
V = VectorFunctionSpace(mesh, "CG", deg_u)
We = VectorElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, dim=4, quad_scheme='default')
W = FunctionSpace(mesh, We)
W0e = FiniteElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, quad_scheme='default')
W0 = FunctionSpace(mesh, W0e)
load = Expression("t", t = 0.0, degree=1)
bcbot= DirichletBC(V, Constant((0.0,0.0)), bot)
bctop = DirichletBC(V.sub(1), load, top)
bc_u = [bcbot,bctop]
boundaries.set_all(0)
top.mark(boundaries, 1)
ds = Measure("ds")(subdomain_data= boundaries)
sig = Function(W)
sig_old = Function(W)
n_elas = Function(W)
beta = Function(W0)
p = Function(W0, name="Cumulative plastic strain")
u = Function(V, name="Total displacement")
du = Function(V, name="Iteration correction")
Du = Function(V, name="Current increment")
v = TrialFunction(V)
u_ = TestFunction(V)
def eps(v):
    e = sym(grad(v))
    return as_tensor([[e[0, 0], e[0, 1], 0],
                      [e[0, 1], e[1, 1], 0],
                      [0, 0, 0]])
def sigma(eps_el):
    return lmbda*tr(eps_el)*Identity(3) + 2*mu*eps_el
def as_3D_tensor(X):
    return as_tensor([[X[0], X[3], 0],
                      [X[3], X[1], 0],
                      [0, 0, X[2]]])
ppos = lambda x: (x+abs(x))/2.
def proj_sig(deps, old_sig, old_p):
    sig_n = as_3D_tensor(old_sig)
    sig_elas = sig_n + sigma(deps)
    s = dev(sig_elas)
    sig_eq = sqrt(3/2.*inner(s, s))
    f_elas = sig_eq - sig0 - H*old_p
    dp = ppos(f_elas)/(3*mu+H)
    n_elas = s/sig_eq*ppos(f_elas)/f_elas
    beta = 3*mu*dp/sig_eq
    new_sig = sig_elas-beta*s
    return as_vector([new_sig[0, 0], new_sig[1, 1], new_sig[2, 2], new_sig[0, 1]]), \
           as_vector([n_elas[0, 0], n_elas[1, 1], n_elas[2, 2], n_elas[0, 1]]), \
           beta, dp
def sigma_tang(e):
    N_elas = as_3D_tensor(n_elas)
    return sigma(e) - 3*mu*(3*mu/(3*mu+H)-beta)*inner(N_elas, e)*N_elas-2*mu*beta*dev(e)
# Global problem and Newton-Raphson procedure
metadata = {"quadrature_degree": deg_stress, "quadrature_scheme": "default"}
dxm = dx(metadata=metadata)
a_Newton = inner(eps(v), sigma_tang(eps(u_)))*dxm
res = -inner(eps(u_), as_3D_tensor(sig))*dxm
    dv = TrialFunction(V)
    v_ = TestFunction(V)
    a_proj = inner(dv, v_)*dxm
    b_proj = inner(v, v_)*dxm
    solver.factorize()
    if u is None:
        solver.solve_local_rhs(u)
        return u
        return
u_r = 0.03
print("\n Loading: u_r ", float(u_r))
Nitermax, tol = 100, 1e-8  # parameters of the Newton-Raphson procedure
Nincr = 20
load_steps = np.linspace(0, 1.1, Nincr+1)[1:]**0.5
print("time step", Nincr)
for (i, t) in enumerate(load_steps):
    load.t = t*u_r
    A, Res = assemble_system(a_Newton, res, bc_u)
    nRes0 = Res.norm("l2")
    nRes = nRes0
    Du.interpolate(Constant((0, 0)))
    print("Increment:", str(i+1))
    niter = 0
    while nRes/nRes0 > tol and niter < Nitermax:
        solve(A, du.vector(), Res, "mumps")
        Du.assign(Du+du)
        deps = eps(Du)
        sig_, n_elas_, beta_, dp_ = proj_sig(deps, sig_old, p)
        local_project(sig_, W, sig)
        local_project(n_elas_, W, n_elas)
        local_project(beta_, W0, beta)
        nRes = Res.norm("l2")
        print("    Residual:", nRes)
        for bc in bc_u:
            bc.homogenize()
        niter += 1
    u.assign(u+Du)
    p.assign(p+local_project(dp_, W0))
    sig_old.assign(sig)
The code is using old compilation functionality with
which is missing some features.
I wouldn’t worry about the warning if you want to use DOLFIN with quadrature elements.
In general I would strongly suggest to use DOLFINx, see: The new DOLFINx solver is now recommended over DOLFIN
See for instance @bleyerj tutorial on: Welcome — Computational Mechanics Numerical Tours with FEniCSx for various topics in solid mechanics
Thank you for the suggestion.
