Hey guys,
first of all: this is my very first Topic so if there are any mistakes/ comments from your side to match this forums rules, please let me know:
I am currently working on my bachelors thesis which involves solving the NSE with fenics. Since I am not that experiences with numeric methods i am trying to get to know this software better by solving random (mostly easy) equations and working my way up to NSE.
Now i got the following code which gives me :
ERROR
File “RAW.py”, line 107, in
xdmf_file_u.write(u, t_start)
ValueError: vector::reserve
CODE
from future import print_function
import fenics
from fenics import XDMFFile
from fenics import derivative
Umgebung definieren
l1 = 1
l2 = 1
domain = Rectangle(Point(0, 0), Point(2*l1, l2))
Mesh definieren
mesh = generate_mesh(domain, 128)
Element definieren
P1 = FiniteElement(“P”, triangle, 1)
Funktionsraum erstellen
V = FunctionSpace(mesh, P1)
Zeitdiskretisierung
f = Constant(5)
t_start = 0.0
TZeit = 1/f # Anzahl der Oszillationen
num_steps = 25
dt = TZeit/ (num_steps)
Funktionen definieren
u_n = Function(V)
w = TestFunction(V)
Anfangsbedingungen + Projektion der Anfangslösung
u_init = Constant(19.0)
u_n = project(u_init, V) # source term
Randbedingungen (Schallwelle)
amplitudeu = Constant(1)
Schallwelle = Expression((‘u_init + amplitudeu * sin(2 * pi * f * t_start)’), amplitudeu=amplitudeu, f=f, t_start=t_start, u_init=u_init, degree=1, domain=mesh)
tol = 1E-14
def boundary_Dl(x, on_boundary):
if on_boundary:
if near(x[0], 0, tol):
return True
return False
return False
bcl = DirichletBC(V, Schallwelle, boundary_Dl)
Gleichung in Variationalform
F = inner(nabla_grad(u) - nabla_grad(u_n), nabla_grad(w)) * dx
a = lhs(F)
L = rhs(F)
pvd files erstellen
xdmf_file_u = XDMFFile(‘RAWtest/u.xdmf’)
Lösungsprozess
for n in range(num_steps):
solve(a == L , u, bcl)
# Speicherprzozess
# nächster Schritt
t_start += dt
Schallwelle.t_start = t_start
u_n.assign(u)
I think the problem is related to solving the eq. F for u and putting those results in a xdmf before assigning u to u_n for the next time step. There are examples for creating another function for example u_ which acts as a place holder just for saving purposes but so far I have not realised how to correctly impliment that and if that even is a solution for my problem. Thanks for everyone reading this (:
