Visualization of time dependent problem using pyvista
I am new to fenics software and i’m trying out the fenicsx tutorial. While solving the “diffusion of a gaussian function”. I didn’t get any plots even though the code run fine without any errors. Can anyone please tell me why i can’t see the images. I have attached my screenshot.
Thankyou in advance for your help
2022-11-18T08:00:00Z
Have you tested: Pyvista mesh plot not working with fenicsx - #2 by dokken
Yeah, I have tested with the code of @charithjeewantha. I got the same image of what he got
But when I change the backend from ‘pythreejs’ to ‘ipyvktlink’
I am getting this
The following two codes together worked for me
pyvista.set_jupyter_backend("ipyvtklink")
pyvista.start_xvfb()
Thank you so much it worked for me as well. When I use both codes
@dokken
I have solved the gaussian diffusion equation again. Now I am getting plots. I don’t know the exactly how it gets solved. But I’m thinking maybe I haven’t installed libraries this link helpful for me to solve it
