How can one store the deformation field and the stresses in the same XDMF file such that one can deform the geometry by the deformation field and color the result by the stress field in ParaView?
Essentially, I want the same visualization that is done with pyvista in the linear elasticity tutorial but in ParaView.
I tried the following (adapted from the linear elasticity tutorial):
import pyvista
from dolfinx import mesh, fem, plot, io, default_scalar_type
L = 1
W = 0.2
mu = 1
rho = 1
delta = W / L
gamma = 0.4 * delta**2
beta = 1.25
lambda_ = beta
g = gamma
domain = mesh.create_box(
MPI.COMM_WORLD,
[np.array([0, 0, 0]), np.array([L, W, W])],
[20, 6, 6],
cell_type=mesh.CellType.hexahedron,
V = fem.functionspace(domain, ("Lagrange", 1, (domain.geometry.dim,)))
def clamped_boundary(x):
return np.isclose(x[0], 0)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets), V)
return ufl.sym(ufl.grad(u))
def sigma(u):
u = ufl.TrialFunction(V)
f = fem.Constant(domain, default_scalar_type((0, 0, -rho * g)))
problem = LinearProblem(
a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"}
uh = problem.solve()
s = sigma(uh) - 1.0 / 3 * ufl.tr(sigma(uh)) * ufl.Identity(len(uh))
von_Mises = ufl.sqrt(3.0 / 2 * ufl.inner(s, s))
V_von_mises = fem.functionspace(domain, ("DG", 0))
stress_expr = fem.Expression(von_Mises, V_von_mises.element.interpolation_points())
stresses = fem.Function(V_von_mises)
stresses.interpolate(stress_expr)
with io.XDMFFile(domain.comm, "result.xdmf", "w") as xdmf:
xdmf.write_mesh(domain)
uh.name = "Deformation"
xdmf.write_function(uh)
stresses.name = "Von Mises"
xdmf.write_function(stresses)
However, in Paraview, I can only color the deformed geometry by the deformation field, but not by the stresses. I suppose the problem is that there are multiple blocks in the XDMF that cannot interact in this way.
