Hi all,
Up to now, I have been working with CG1 elements on a triangular mesh. To visualize the solution, I have been saving to XDMF and loading the function into Paraview.
However, now I would like to raise the degree of the function space to, for example, second degree. I simply modified the code below by changing deg to 2. Everything seems to be OK, as the number of DOF’s in the new function f increases with the same underlying (unit circle) mesh with 31 vertices.
However, I would like to visualize this in a similar manner as I did, by exporting to xdmf and importing in paraview. When I run the mwe below, it saves a *.xdmf file with the following contents:
<?xml version="1.0"?>
<!DOCTYPE Xdmf SYSTEM "Xdmf.dtd" []>
<Xdmf Version="3.0" xmlns:xi="http://www.w3.org/2001/XInclude">
<Domain>
<Attribute Name="real_u_abs" AttributeType="Scalar" Center="Node">
<DataItem Dimensions="31 1" Format="HDF">ftest.h5:/Function/real_u_abs/0</DataItem>
</Xdmf>
As you can see above, the function is saved with in an array of 31 elements, the number of vertices, and not the number of dof’s in my function space. Is there a way I can save this with all dof’s?
from dolfinx import FunctionSpace, Function
with XDMFFile(MPI.COMM_SELF, f"meshes/circle.xdmf", "r") as infile:
mesh = infile.read_mesh(name="Grid")
cell_tags = infile.read_meshtags(mesh, name="Grid")
deg = 2
V = FunctionSpace(mesh, ("CG", deg))
f = Function(V)
f.interpolate(lambda x: np.sqrt(1.0001 - x[0]**2 - x[1]**2))
with XDMFFile(MPI.COMM_SELF, "results/test.xdmf", "w") as xdmf:
xdmf.write_mesh(mesh)
xdmf.write_function(f)
- Wouter
