What does apply_lifting exactly do?
I am observing that apply_lifting is relatively slow. The time it takes is comparable to the assembly of the vector itself.
MWE
import dolfinx.fem.petsc
import pyvista
comm = MPI.COMM_WORLD
rank = comm.Get_rank()
def main():
    def q(u):
        return 1 + u**2
    nelems = 10000
    domain = dolfinx.mesh.create_unit_interval(MPI.COMM_WORLD, nelems)
    u_ufl = 1 + 2 * x[0]
    f = - ufl.div(q(u_ufl) * ufl.grad(u_ufl))
    def u_exact(x):
        return eval(str(u_ufl))
    V = dolfinx.fem.functionspace(domain, ("Lagrange", 1))
    u_D = dolfinx.fem.Function(V)
    u_D.interpolate(u_exact)
    domain.topology.create_connectivity(fdim, fdim + 1)
    boundary_facets = dolfinx.mesh.exterior_facet_indices(domain.topology)
    bc = dolfinx.fem.dirichletbc(u_D, dolfinx.fem.locate_dofs_topological(V, fdim, boundary_facets))
    uh = dolfinx.fem.Function(V)
    F = q(uh) * ufl.dot(ufl.grad(uh), ufl.grad(v)) * ufl.dx - f * v * ufl.dx
    J = ufl.derivative(F, uh)
    residual = dolfinx.fem.form(F)
    jacobian = dolfinx.fem.form(J)
    du = dolfinx.fem.Function(V)
    A = dolfinx.fem.petsc.create_matrix(jacobian)
    L = dolfinx.fem.petsc.create_vector(residual)
    solver.setOperators(A)
    i = 0
    error = dolfinx.fem.form(ufl.inner(uh - u_ufl, uh - u_ufl) * ufl.dx(metadata={"quadrature_degree": 4}))
    L2_error = []
    du_norm = []
    max_iterations = 25
    while i < max_iterations:
        # Assemble Jacobian and residual
        with L.localForm() as loc_L:
            loc_L.set(0)
        A.zeroEntries()
        dolfinx.fem.petsc.assemble_matrix(A, jacobian, bcs=[bc])
        dolfinx.fem.petsc.assemble_vector(L, residual)
        L.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
        L.scale(-1)
        # Compute b - J(u_D-u_(i-1))
        dolfinx.fem.petsc.apply_lifting(L, [jacobian], [[bc]], x0=[uh.x.petsc_vec], alpha=1)
        # Set du|_bc = u_{i-1}-u_D
        dolfinx.fem.petsc.set_bc(L, [bc], uh.x.petsc_vec, 1.0)
        L.ghostUpdate(addv=PETSc.InsertMode.INSERT_VALUES, mode=PETSc.ScatterMode.FORWARD)
        # Solve linear problem
        solver.solve(L, du.x.petsc_vec)
        du.x.scatter_forward()
        # Update u_{i+1} = u_i + delta u_i
        uh.x.array[:] += du.x.array
        i += 1
        # Compute norm of update
        correction_norm = du.x.petsc_vec.norm(0)
        # Compute L2 error comparing to the analytical solution
        L2_error.append(np.sqrt(domain.comm.allreduce(dolfinx.fem.assemble_scalar(error), op=MPI.SUM)))
        du_norm.append(correction_norm)
        print(f"Iteration {i}: Correction norm {correction_norm}, L2 error: {L2_error[-1]}")
        if correction_norm < 1e-10:
            break
if __name__=="__main__":
    from line_profiler import LineProfiler
    lp = LineProfiler()
    lp_wrapper = lp(main)
    lp_wrapper()
    profiling_file = f"profiling_rank{rank}.txt"
    with open(profiling_file, 'w') as pf:
        lp.print_stats(stream=pf)
, which I basely copied from this tutorial from @dokken and imported the LineProfiler library to obtain profiling results. In particular, for this 1D 10K elements example:
Timer unit: 1e-09 s
Total time: 69.9461 s
Line #      Hits         Time  Per Hit   % Time  Line Contents
    60        10        1e+10    1e+09     20.5          dolfinx.fem.petsc.assemble_vector(L, residual)
    65        10 7422697952.0    7e+08     10.6          dolfinx.fem.petsc.apply_lifting(L, [jacobian], [[bc]], x0=[uh.x.petsc_vec], alpha=1)
using a Developper compiled version of the latest dolfinx ran from the test-env container. The weird thing for me is that for this example with order 1 elements, only two entries of the RHS vector should be modified by apply_lifting but it still takes half the time it takes assemble_vector to assemble 10K elements. So I am wondering what is apply_lifting actually doing. I past the profiling dump here in case anyone is interested in comparing:
Timer unit: 1e-09 s
File: /root/shared/jorgensd_nr_example_dirichlet/main.py
Function: main at line 13
    13                                           def main():
    14         1    2002979.0    2e+06      0.0      def q(u):
    15                                                   return 1 + u**2
    16
    17         1      50000.0  50000.0      0.0      nelems = 10000
    18         1 8136370529.0    8e+09     11.6      domain = dolfinx.mesh.create_unit_interval(MPI.COMM_WORLD, nelems)
    19         1    3159787.0    3e+06      0.0      x = ufl.SpatialCoordinate(domain)
    20         1   17659926.0    2e+07      0.0      u_ufl = 1 + 2 * x[0]
    21         1   57820158.0    6e+07      0.1      f = - ufl.div(q(u_ufl) * ufl.grad(u_ufl))
    22
    23         1      41700.0  41700.0      0.0      def u_exact(x):
    24                                                   return eval(str(u_ufl))
    25
    26         1  280213824.0    3e+08      0.4      V = dolfinx.fem.functionspace(domain, ("Lagrange", 1))
    27         1   57316960.0    6e+07      0.1      u_D = dolfinx.fem.Function(V)
    28         1 2015771241.0    2e+09      2.9      u_D.interpolate(u_exact)
    29         1     211899.0 211899.0      0.0      fdim = domain.topology.dim - 1
    30         1   37620242.0    4e+07      0.1      domain.topology.create_connectivity(fdim, fdim + 1)
    31         1   14590039.0    1e+07      0.0      boundary_facets = dolfinx.mesh.exterior_facet_indices(domain.topology)
    32         1  101360975.0    1e+08      0.1      bc = dolfinx.fem.dirichletbc(u_D, dolfinx.fem.locate_dofs_topological(V, fdim, boundary_facets))
    33
    34         1    5075178.0    5e+06      0.0      uh = dolfinx.fem.Function(V)
    35         1    4625481.0    5e+06      0.0      v = ufl.TestFunction(V)
    36         1  140063512.0    1e+08      0.2      F = q(uh) * ufl.dot(ufl.grad(uh), ufl.grad(v)) * ufl.dx - f * v * ufl.dx
    37         1   77671074.0    8e+07      0.1      J = ufl.derivative(F, uh)
    38         1 6058416009.0    6e+09      8.7      residual = dolfinx.fem.form(F)
    39         1  287922433.0    3e+08      0.4      jacobian = dolfinx.fem.form(J)
    40
    41         1    8652710.0    9e+06      0.0      du = dolfinx.fem.Function(V)
    42         1  670876085.0    7e+08      1.0      A = dolfinx.fem.petsc.create_matrix(jacobian)
    43         1  384135142.0    4e+08      0.5      L = dolfinx.fem.petsc.create_vector(residual)
    44         1    9427903.0    9e+06      0.0      solver = PETSc.KSP().create(domain.comm)
    45         1   30273988.0    3e+07      0.0      solver.setOperators(A)
    46
    47         1      26799.0  26799.0      0.0      i = 0
    48         1  187641566.0    2e+08      0.3      error = dolfinx.fem.form(ufl.inner(uh - u_ufl, uh - u_ufl) * ufl.dx(metadata={"quadrature_degree": 4}))
    49         1      15900.0  15900.0      0.0      L2_error = []
    50         1      39399.0  39399.0      0.0      du_norm = []
    51
    52         1      12800.0  12800.0      0.0      max_iterations = 25
    53        10     448797.0  44879.7      0.0      while i < max_iterations:
    54                                                   # Assemble Jacobian and residual
    55        20   20229711.0    1e+06      0.0          with L.localForm() as loc_L:
    56        10   60706273.0    6e+06      0.1              loc_L.set(0)
    57        10  112133110.0    1e+07      0.2          A.zeroEntries()
    58        10        2e+10    2e+09     25.9          dolfinx.fem.petsc.assemble_matrix(A, jacobian, bcs=[bc])
    59        10   74877648.0    7e+06      0.1          A.assemble()
    61        10   69274559.0    7e+06      0.1          L.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
    62        10   15525009.0    2e+06      0.0          L.scale(-1)
    63
    64                                                   # Compute b - J(u_D-u_(i-1))
    66                                                   # Set du|_bc = u_{i-1}-u_D
    67        10   35894777.0    4e+06      0.1          dolfinx.fem.petsc.set_bc(L, [bc], uh.x.petsc_vec, 1.0)
    68        10   21038173.0    2e+06      0.0          L.ghostUpdate(addv=PETSc.InsertMode.INSERT_VALUES, mode=PETSc.ScatterMode.FORWARD)
    69
    70                                                   # Solve linear problem
    71        10 1229572810.0    1e+08      1.8          solver.solve(L, du.x.petsc_vec)
    72        10    9607860.0 960786.0      0.0          du.x.scatter_forward()
    73
    74                                                   # Update u_{i+1} = u_i + delta u_i
    75        10   14458225.0    1e+06      0.0          uh.x.array[:] += du.x.array
    76        10     212400.0  21240.0      0.0          i += 1
    77
    78                                                   # Compute norm of update
    79        10    9343964.0 934396.4      0.0          correction_norm = du.x.petsc_vec.norm(0)
    80
    81                                                   # Compute L2 error comparing to the analytical solution
    82        10 9756239235.0    1e+09     13.9          L2_error.append(np.sqrt(domain.comm.allreduce(dolfinx.fem.assemble_scalar(error), op=MPI.SUM)))
    83        10     288500.0  28850.0      0.0          du_norm.append(correction_norm)
    84
    85        10   38677879.0    4e+06      0.1          print(f"Iteration {i}: Correction norm {correction_norm}, L2 error: {L2_error[-1]}")
    86        10     462300.0  46230.0      0.0          if correction_norm < 1e-10:
    87         1     217600.0 217600.0      0.0              break
Looked a bit more into it. So inside of apply_lifting it spends 1/3 of the time “packing coefficients” and 2/3 in the c++ apply_lifting.
   332        10       7600.0    760.0      0.0      x0 = [] if x0 is None else x0
   333        10       4100.0    410.0      0.0      constants = (
   334        20      24099.0   1205.0      0.0          [
   335        10     250498.0  25049.8      0.3              _pack_constants(form._cpp_object) if form is not None else np.array([], dtype=b.dtype)
   336        20       6600.0    330.0      0.0              for form in a
   337                                                   ]
   338        10       3600.0    360.0      0.0          if constants is None
   339                                                   else constants
   340                                               )
   341        10       3800.0    380.0      0.0      coeffs = (
   342        20   27053587.0    1e+06     36.0          [{} if form is None else _pack_coefficients(form._cpp_object) for form in a]
   343        10       4300.0    430.0      0.0          if coeffs is None
   344                                                   else coeffs
   345                                               )
   346        20      17999.0    900.0      0.0      _a = [None if form is None else form._cpp_object for form in a]
   347        30      40500.0   1350.0      0.1      _bcs = [[bc._cpp_object for bc in bcs0] for bcs0 in bcs]
   348        10   47811522.0    5e+06     63.6      _cpp.fem.apply_lifting(b, _a, constants, coeffs, _bcs, x0, alpha)
Would appreciate any insight. It is not an urgent matter.
I’ve written out what apply lifting does in detail at:
https://jsdokken.com/FEniCS-workshop/src/form_compilation/alternate_form.html#lifting
There is also an alternative approach for lifting sketched out in
https://jsdokken.com/FEniCS-workshop/src/deep_dive/lifting.html#alternative-lifting-procedure
