Why do I get error Error: 'Unable to evaluate function at point. Reason: The point is not inside the domain.' when trying to run my legacy FeNics scripts in parallel?
I have made a dummy example where i am solving for the electric potential in the 1m^3 domain enclosed by two 1m^2 capacitors at x=+/-0.5 held at V=+/-1V respectively. The code:
comm = MPI.COMM_WORLD
rank = comm.Get_rank()
def boundary(x):
    tolerance = 1E-12
    # Check if the x coordinate is -0.5 or 0.5
    if np.abs(x[0]-0.5)<tolerance or np.abs(x[0]+ 0.5)<tolerance:
        return 1
        return 0
def Pot(x):
    if x<0:
        return -1
    if x>0:
        return 1
domain = Box(Point(-0.5,-0.5,-0.5), Point(0.5,0.5,0.5))
mesh = generate_mesh(domain,20)
V = FunctionSpace(mesh, 'Lagrange', 1)
class MyExpression0(UserExpression):
    def eval(self, value, x):
        value[0] = Pot(x[0])
u_d = MyExpression0()
#defined the boundary condition
bc = DirichletBC(V, u_d, boundary)
f = Constant(0)
a = dot(grad(u), grad(v))*dx
L = f*v*dx
solve(a == L, u, bc)
runs fine using python without parallel processing. However, when I run mpirun -n python Capacitor.py , each of the N processes starts correctly, but each one fails with
*** Error: Unable to evaluate function at point.
*** Reason: The point is not inside the domain. Consider calling “Function::set_allow_extrapolation(true)” on this Function to allow extrapolation.
Does anyone have an idea why this might be?
Consider reading Problem with evaluation at a point in parallel.
I cannot reproduce your error with docker run -ti -v ${PWD}:/fenics/shared -w /fenics/shared --rm quay.io/fenicsproject/dev:latest.
I tested with 1,2,\dots, 10 processes with no error.
Please specify what version of FEniCS you are using.
Hey Dokken,
thanks for your reply. Here is the version of fenics im using:
fenics-basix 0.6.0
fenics-dijitso 2019.2.0.dev0
fenics-dolfin 2019.2.0.dev0
fenics-ffc 2019.2.0.dev0
fenics-fiat 2019.2.0.dev0
fenics-ufl-legacy 2022.3.0
and this is the version of mpi4py:
mpi4py 3.1.3
note that I’m running from ubuntu terminal not docker also.
I can’t reproduce the issue with:
 docker run -ti -v ${PWD}:/root/shared  --rm  ubuntu:22.04
and
apt-get update
apt-get install -y software-properties-common
add-apt-repository ppa:fenics-packages/fenics
apt-get update
apt-get install -y fenics --fix-missing
Weird, do you think it’s an issue with my MPI installation? I’ve managed to run python scripts using mpi that don’t use FeNics
As you haven’t specified what system you are running on or the commands you used to install dolfin, I cant reproduce your error and cannot get to the bottom of this
I’m running on ubuntu 22.04.2 via WSL and I (am 95% sure that) installed FeNics via the ubuntu installation process listed here https://fenicsproject.org/download/archive/.
Hey Dokken, sorry for the confusion, the error I was receiving was due to point evaluation after. However this script doesn’t run any faster than without mpiexec, in fact it just repeats the same calculation n times. Is it obvious to you what need to change to actually allow parallel computation?
See:
