Why do non-interacting cylinders bend in unintuitive direction under identical forces?
I have two cylinders which are not supposed to interact with each other (yet). I apply a pressure at the right face of both cylinders. Why do they curve like this instead of going straight?
If I remove the second cylinder it looks like this (as expected)
If I move them further away from each other this effect increases as well as the elongation only in x direction
It does not matter where I put the 2nd cylinder, the direction in which it gets deformed is always the same. Here I put the 2nd cylinder on the z axis and still the first one is deformed in negative y and negative z direction.
This is my code to reproduce this:
import numpy as np # type: ignore
from ufl import sym, grad, Identity, tr, inner, Measure, TestFunction, TrialFunction # type: ignore
from mpi4py import MPI # type: ignore
from dolfinx import fem, io, mesh
from dolfinx.fem.petsc import assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
from dolfinx.fem import locate_dofs_geometrical, DirichletBC
from petsc4py import PETSc # type: ignore
import matplotlib.pyplot as plt # type: ignore
pressure_value = 8.0
E = 10 # Young's modulus
radius = 1
radius_2 = 1
length = 10
gmsh.option.setNumber("General.Terminal", 0)
gdim = 3
# add first cylinder
gmsh.model.add("cylinder")
cylinder_tag = gmsh.model.occ.addCylinder(0, 0, 0, length, 0, 0, radius)
gmsh.model.occ.synchronize()
gmsh.model.addPhysicalGroup(gdim, [cylinder_tag], 0)
surfaces = gmsh.model.getBoundary([(3, cylinder_tag)], oriented=False, recursive=False)
right_face_tag = surfaces[1][1]
gms.model.addPhysicalGroup(gdim - 1, [right_face_tag], 1)
gmsh.model.setPhysicalName(gdim - 1, 1, "Right")
left_face_tag = surfaces[0][1]
gmsh.model.addPhysicalGroup(gdim - 1, [left_face_tag], 2)
gmsh.model.setPhysicalName(gdim - 1, 2, "Left")
lateral_surface_tags = [surf[1] for surf in surfaces[2:]]
gmsh.model.addPhysicalGroup(gdim - 1, lateral_surface_tags, 3)
gmsh.model.setPhysicalName(gdim - 1, 3, "Lateral")
# add second cylinder
second_cylinder_tag = gmsh.model.occ.addCylinder(0, 0,20*radius, length, 0, 0, radius_2)
gmsh.model.addPhysicalGroup(gdim, [second_cylinder_tag], 1)
surfaces = gmsh.model.getBoundary([(3, second_cylinder_tag)], oriented=False, recursive=False)
second_right_face_tag = surfaces[1][1]
gmsh.model.addPhysicalGroup(gdim - 1, [second_right_face_tag], 4)
gmsh.model.setPhysicalName(gdim - 1, 4, "secondRight")
second_left_face_tag = surfaces[0][1]
gmsh.model.addPhysicalGroup(gdim - 1, [second_left_face_tag], 5)
gmsh.model.setPhysicalName(gdim - 1, 5, "secondLeft")
second_lateral_surface_tags = [surf[1] for surf in surfaces[2:]]
gmsh.model.addPhysicalGroup(gdim - 1, second_lateral_surface_tags, 6)
gmsh.model.setPhysicalName(gdim - 1, 6, "secondLateral")
domain, _, facets = io.gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=gdim)
gmsh.finalize()
shape = (gdim,)
# Define the function space
V = fem.functionspace(domain, ("P", 2, shape))
u_h = fem.Function(V, name="Displacement")
# Define strain and stress tensors
return sym(grad(u))
def sigma(u):
return E * epsilon(u)
pressure_force = fem.Constant(domain, np.array([pressure_value, 0, 0]))
dx = Measure("dx", domain=domain) # Volume measure
ds = Measure("ds", domain=domain, subdomain_data=facets) # Surface measure for boundaries
right_face = 1
right_face_second = 4
# Define the boundary conditions
def left(x):
return np.isclose(x[0], 0)
left_dofs = locate_dofs_geometrical(V, left)
bcs = [
fem.dirichletbc(np.zeros(3,), left_dofs, V) # keep the left face fixed
# Define the weak form
a = (inner(sigma(u), epsilon(v)) * dx)
L = inner(pressure_force, v) * (ds(right_face) + ds(right_face_second))
# in case of a single cylinder:
# L = inner(pressure_force, v) * ds(right_face)
bilinear_form = fem.form(a)
linear_form = fem.form(L)
A = assemble_matrix(bilinear_form, bcs=bcs)
b = create_vector(linear_form)
solver.setOperators(A)
problem = fem.petsc.LinearProblem(
a, L, u=u_h, bcs=bcs,
petsc_options={"ksp_type": "preonly", "pc_type": "lu"}
vtk = io.VTKFile(domain.comm, "results/dynamic/dynamic_cylinder.pvd", "w")
with b.localForm() as loc_b:
loc_b.set(0)
assemble_vector(b, linear_form)
apply_lifting(b, [bilinear_form], [bcs])
set_bc(b, bcs)
# Solve linear problem
solver.solve(b, u_h.x.petsc_vec)
u_h.x.scatter_forward()
vtk.write_function(u_h)
vtk.close()
Please note that your code is not runnable (as there are typos and missing indentation).
Secondly, fixing those and inspecting your variational form, it doesn’t look like a standard elasticity law, as you only have a(u,v) = \int_\Omega E \frac{1}{2}(\nabla u + \nabla u^T)\frac{1}{2}(\nabla v + \nabla v^T)~\mathrm{d}x.
What does this stem from, and what are the physically correct units for E and the pressure on the rhs?
Please also note that as your problem is posed on a very coarse mesh, it is probably not radially symmetric, which could cause forces in x and y direction.
The cylinders are also not identical.
You can see this by looking at your mesh:
In the end I want to do this:
\int_{\Omega} \left( \sigma(u) \cdot \epsilon(v) + \rho \frac{1}{\Delta t} \, u \cdot v \right) \, \text{d}x = \int_{\Omega} \rho \frac{1}{\Delta t} \, u_n \cdot v \, \text{d}x + \int_{\Gamma_{\text{right}}} f \cdot v \, \text{d}s
or static:
\int_\Omega \sigma(u) \cdot \epsilon(v) \, \text{d}x = \int_{\Gamma_{\text{right}}} f \cdot v \, \text{d}s
lambda_ = (E * nu) / ((1 + nu) * (1 - 2 * nu))
mu = E / (2 * (1 + nu))
    return sym(grad(u))
def sigma(u):
    return lambda_ * tr(epsilon(u)) * Identity(len(u)) + 2 * mu * epsilon(u)
a = (
    inner(sigma(u), epsilon(v)) * dx +
    (1 / dt) * rho * inner(u, v) * dx +
    friction_coefficient * inner(u, v) * ds(skin)
L = inner(pressure_force, v) * (ds(right_face)) + (1 / dt) * rho * inner(u_n, v) * dx
but for testing I set friction_coefficient = 0 and poisson ratio nu = 0 as well as dt to infinite (and therefore simplifying the equations). Did I make a mistake when defining these equations?
The pressure on the rhs and the Youngs modulus E are in pascal.
If I understand your reply correctly I should define my mesh in a way so that is it radially symmetric and this could fix my problem?
Thank you for your time.
I.e. your sigma is not correct.
Secondly, my point is that your mesh is
  1. Way too coarse to represent a cylinder
  2. Is not symmetric in the way you are thinking.
My full sigma is this:
def sigma(u):
Is this correct and if not what is the mistake?
When changing the mesh by setting these numbers I get better results. Is this the way to go or should I try something else?
gmsh.option.setNumber("Mesh.MeshSizeMax", 0.1)
gmsh.option.setNumber("Mesh.MeshSizeMin", 0.0001)
Thanks for helping me with this!
THe above sigma looks better, and also the mesh resolution look more sensible.
