Why does compute_gradient execution time increase with each epoch?
I am encountering an issue where the execution time for the compute_gradient function in dolfin-adjoint increases as the epochs progress.
Here is the relevant portion of my code:
L = assemble(0.5 * inner(diff_neum_func, diff_neum_func) * dx)
control_k = Control(k_func)
dLdk = compute_gradient(L, control_k)
Even though the same data is used across all epochs, the compute_grad_time increases as follows:
  • Epoch 1: compute_grad_time = 0:05:51
  • Epoch 2: compute_grad_time = 0:06:24
  • Epoch 3: compute_grad_time = 0:06:59
  • Epoch 4: compute_grad_time = 0:07:29
Environment Information:
  • dolfin-adjoint Version: 2023.3.0
  • FEniCS Packages:
    • fenics-dolfin: 2019.2.0.64.dev0
    • fenics-ufl-legacy: 2022.3.0
    • fenics-fiat: 2019.2.0.dev0
    • fenics-ffc: 2019.2.0.dev0
    • fenics-dijitso: 2019.2.0.dev0
Here’s what I’ve investigated:
  1. I attempted to reset the computation graph using tape.reset() or clear_tape, but encountered ImportError.
  2. The same dataset is repeatedly used, so data complexity does not increase.
Could someone help explain why the execution time of compute_gradient keeps increasing with each epoch and suggest a potential solution? Your help would be greatly appreciated!
I referred to an answer in the thread Program killed when running compute_gradient on transient problem and updated my code as follows:
# Gradient computation
compute_grad_start_time = time.time()
dLdk = ReducedFunctional(L, control_k)
compute_grad_end_time = time.time()
# Retrieve vector values
vector_start_time = time.time()
grad_L_k = dLdk.derivative().vector().get_local().mean()
vector_end_time = time.time()
However, even with this modification, the execution time continues to increase as the epochs progress. Specifically, the vector_time grows as follows:
  • Epoch 1: vector_time = 0:05:52
  • Epoch 2: vector_time = 0:06:24
  • Epoch 3: vector_time = 0:06:56
  • Epoch 4: vector_time = 0:07:24
Without a reproducible example it is hard to give any guidance.
I have created a simplified version of the code with a reduced dataset to investigate a performance issue. However, I noticed that vector_time increases with each epoch, even in this simplified setup.
Below is the code I used, along with comments explaining each section.
Code
from fenics_adjoint import *
import torch
import torch.nn as nn
import time, datetime
from tqdm import tqdm
import gc
# Set logging level to WARNING to suppress information messages
set_log_level(LogLevel.WARNING)
# Define the boundary condition function
def boundary(x, on_boundary):
    return on_boundary
# Define a function to generate coefficient function k(x)
def make_k(x):
    return np.ones_like(x)
# Generate Dirichlet boundary condition (u_bc) and source term (f) expressions
def generate_u_bc_and_f(a, b):
    u_bc_expr = Expression('cos(a*pi*x[0]) * cos(b*pi*x[1])',
                           degree=3, pi=np.pi, a=a, b=b)
    f_expr = Expression('(a*a + b*b)*pi*pi*cos(a*pi*x[0])*cos(b*pi*x[1])',
    return u_bc_expr, f_expr
# Define a simple neural network for k(x)
class kx_Net(nn.Module):
    def __init__(self, layers):
        super(kx_Net, self).__init__()
        self.linears = nn.ModuleList([nn.Linear(layers[i], layers[i+1]) for i in range(len(layers)-1)])
        self.activation = nn.ReLU()
    def forward(self, x):
        for i in range(len(self.linears)-1):
            x = self.linears[i](x)
            x = self.activation(x)
        k = self.linears[-1](x)
        return k
# Function to manually update model gradients
def manual_update_model_gradients(model, grad_L_theta):
    for param, grad in zip(model.parameters(), grad_L_theta):
        if param.grad is None:
            param.grad = torch.zeros_like(param)
        param.grad.add_(grad)
# Function to solve the FEniCS problem
def solve_fenics_problem(k, V, u_bc_expr, f_expr):
    Solves the FEniCS problem and extracts Neumann data.
    # Define Dirichlet boundary condition
    u_bc = DirichletBC(V, u_bc_expr, boundary)
    # Define the variational problem
    F = k * dot(grad(u), grad(v)) * dx - f_expr * v * dx
    a, L = lhs(F), rhs(F)
    # Solve the FEniCS problem
    u_sol = Function(V)
    A, b = assemble_system(a, L, u_bc)
    solve(A, u_sol.vector(), b)
    # Free memory by deleting temporary objects
    del u_bc, u, v, F, a, L, A, b
    return u_sol
# Mesh and function space setup
mesh = UnitSquareMesh(256, 256)
# Prepare data
data_num = 2**8
dof_coordinates = V.tabulate_dof_coordinates().reshape((-1, 2))
dof_coordinates_tensor = torch.tensor(dof_coordinates, dtype=torch.float32)
k_exact = make_k(dof_coordinates_tensor[:,[0]])
k_exact_func = Function(V)
k_exact_func.vector().set_local(k_exact[:,0])
# Random parameters for generating u_bc and f
rand_para = np.random.uniform(0, 2, (data_num, 2))
EPOCHS = 5
# Training loop
def Train(V, data_num, epoch):
    pbar = tqdm(range(data_num), desc=f"Epoch {epoch}/{EPOCHS}")
    compute_grad_time = vector_time = 0
    for batch_idx in pbar:
        a, b = rand_para[batch_idx]
        # Zero out gradients for the optimizer
        optimizer_k.zero_grad()
        # Compute k(x) using the neural network
        k_tensor = model_k(dof_coordinates_tensor)
        k_func = Function(V)
        k_func.vector().set_local(k_tensor[:,0].detach().cpu().numpy())
        # Solve the FEniCS problems
        u_bc_expr, f_expr = generate_u_bc_and_f(a, b)
        u_output = solve_fenics_problem(k_func, V, u_bc_expr, f_expr)
        target_u = solve_fenics_problem(k_exact_func, V, u_bc_expr, f_expr)
        # Define Neumann flux expressions
        neum_output_func = k_func * u_output
        neum_exact_func = k_exact_func * target_u
        # Compute the difference in Neumann flux
        diff_neum_func = neum_output_func - neum_exact_func
        # Define the loss function
        # Compute gradients and update model parameters
        grad_k_theta = torch.autograd.grad(outputs=k_tensor.sum(), inputs=model_k.parameters())
        grad_L_theta = [grad_L_k * gk for gk in grad_k_theta]
        manual_update_model_gradients(model_k, grad_L_theta)
        optimizer_k.step()
        # Update timing metrics
        compute_grad_time += compute_grad_end_time - compute_grad_start_time
        vector_time += vector_end_time - vector_start_time
        # Free memory
        del target_u, k_func, u_bc_expr, f_expr, u_output, neum_output_func, neum_exact_func, diff_neum_func, control_k, dLdk
    gc.collect()
    return compute_grad_time, vector_time
# Define neural network architecture
layers = [2, 100, 100, 1]
model_k = kx_Net(layers)
optimizer_k = torch.optim.Adam(model_k.parameters(), lr=0.001)
# Run training loop
for epoch in range(1, EPOCHS + 1):
    compute_grad_time, vector_time = Train(V, data_num, epoch)
    print(f"compute_grad_time = {str(datetime.timedelta(seconds=int(compute_grad_time)))}")
    print(f"vector_time = {str(datetime.timedelta(seconds=int(vector_time)))}")
Results
Here are the training results:
Epoch 1/5:
compute_grad_time = 0:00:00
vector_time = 0:01:28
Epoch 2/5:
vector_time = 0:01:32
Epoch 3/5:
vector_time = 0:01:35
Epoch 4/5:
vector_time = 0:01:38
Epoch 5/5:
vector_time = 0:01:42
Questions
  1. Could there be a memory or computation graph accumulation issue in ReducedFunctional or dLdk.derivative()?
  2. Are there any optimizations or best practices to prevent this increasing runtime in FEniCS-adjoint?
Any insights or suggestions would be greatly appreciated. Thank you! :blush:
Solution
The issue of increasing execution time was caused by the tape in FEniCS, which accumulates data as automatic differentiation is performed. To address this, I resolved the problem by clearing the tape at the end of each epoch. This prevents the tape from accumulating unnecessary data and avoids the increase in training time.
Below is the modified code. By adding the following two lines:
tape = get_working_tape()
tape.clear_tape()
the tape is reset after every epoch, solving the issue.
# Key section of the modified code
# Other code omitted...
# Clear the tape at the end of each epoch
    tape.clear_tape()
After applying this modification, I confirmed that the training time does not increase with subsequent epochs.
Note
This issue is related to the memory accumulation in the tape when using the fenics_adjoint library for automatic differentiation. Clearing the tape with tape.clear_tape() at the end of each epoch effectively prevents this problem.
Thank you! :slight_smile:
