Why does NonlinearProblem require derivative terms
Hi, I have a conceptual question regarding the use of NonlinearProblem.
I’ve created a simple working example where I have a phase field driven only by a double-well.
double_well = phi**2 * (1-phi)**2
I expected all regions with initial phi > 0.5 to become phi=1, and phi<0.5 to become phi=0, except for a small boundary. However, this is not what I observe, as phi continues to decrease over time.
The image below give the initial sine condition, the observed result, and the expected result respectively:
The expected result is what I obtain when I provide the derivative of the double-well, rather than the double-well term itself.
double_well_derivative = 2 * phi * (1-phi)**2 - 2 * phi**2 * (1-phi)
This is similar to how the cahn-hilliard tutorial provides the derivative of the chemical potential dfdc, rather than f itself. Why is this necessary, shouldn’t F be the function we aim to minimize, rather than its derivative?
Thank you!
Minimal example:
from dolfinx import mesh, fem, io, geometry
from dolfinx import default_real_type
from dolfinx.mesh import CellType, create_unit_square
dt = 2e-1
# Mesh
mesh_domain = create_unit_square(MPI.COMM_WORLD, 30, 30, CellType.triangle)
# Function spaces
V_a = fem.FunctionSpace(mesh_domain, ("CG", 1))
phi = fem.Function(V_a, name="phase")
phi_prev = fem.Function(V_a, name="phase_old")
v = ufl.TestFunction(V_a)
# No BCs
# Initial condition
phi.interpolate(lambda x: 0.5 + 0.5 * np.sin(x[0] * (2 * np.pi)))  # sine
phi.x.scatter_forward()
Phase field formulation: F = time derivative + double well
# ----- This definition does not lead to expected result: -----
# double_well = phi**2 * (1-phi)**2
# F = (phi - phi_prev) / dt * v * ufl.dx + double_well * v * ufl.dx
# ----- This does lead to expected result: -----
F = (phi - phi_prev) / dt * v * ufl.dx + double_well_derivative * v * ufl.dx
Solver setup
# Create nonlinear problem and Newton solver
problem = NonlinearProblem(F, phi)
solver.rtol = np.sqrt(np.finfo(default_real_type).eps) * 1e-2
# We can customize the linear solver used inside the NewtonSolver by
# modifying the PETSc options
ksp = solver.krylov_solver
opts = PETSc.Options()  # type: ignore
sys = PETSc.Sys()  # type: ignore
ksp.setFromOptions()
Solving & saving
file = XDMFFile(MPI.COMM_WORLD, "out.xdmf", "w")
file.write_mesh(mesh_domain)
t = 0.0
timesteps = 100
phi_prev.x.array[:] = phi.x.array
file.write_function(phi, -1)
for i in range(timesteps):
    r = solver.solve(phi)
    # Process & save solution
    file.write_function(phi, i)
file.close()
The NonlinearProblem class solves problems of the form F(u)=0 where F is a non-linear form. More precisely, we solve the nonlinear variational problem: Find u\in V such that:
\langle F(u), v \rangle =0 \quad \forall v\in V
In some instances, such a F can be derived from the optimality conditions of minimizing an associated energy functional:
u = \text{arg}\min_{\hat{u} \in V} E(\hat u)
In such a case, the optimality condition is that the directional derivative of u should be zero:
\langle D_u E(u), v\rangle=0 \quad \forall v \in V
In this case, F is exactly the derivative of the energy E.
Note that there are some cases where F does not necessarily derive from an underlying energy.
Thank you for the reply.
I think I get it, and my misunderstanding was that NonlinearProblem would minimize F:
u=\arg\min_{\hat u \in V} F(\hat u),
instead of find u to make F(u)=0.
A follow-up to make sure I understand the practical implications:
In 1D, for any additional term to my energy function that depends on u, i.e. E=...+g(u), I should include F=...+\dfrac{\partial g}{\partial u}. Is that right?
yes this is right. You can also simply use F = ufl.derivative(E, u, v) where v is a test function
