Hello,
Thank you so much for taking the time to respond to my post.
- The facets are as expected.
- The pressure solution has its largest error near the bottom of the domain, almost like the outflow condition for u makes the pressure struggle. This is what the error looks like at the most refined level:
- I personally struggle (a lot) with changing between coordinate systems. Since I have to run various more complicated examples in cylindrical coordinates and compare to Cartesian, I wanted to prevent future mistakes by always writing 3x3 tensors, as the cylindrical tensor has an extra term. I could also change the variational formulation to include that term, so it’s really the same. I should have made them 2D for the MWE, sorry about that.
I finally ran an incompressible problem, and you’re right. The error for the velocity and the pressure now behaves as needed. I based the manufactured solution on this post in steady state. I was aware that there are some issues for compressible flow, I was focused on other aspects of my solution and didn’t connect the dots.
Thank you!
