Hi Everyone,
I am trying to quantify the error in my code for Darcy flow through a unit square. The 2 equations for this flow are: u_bar = -K * grad p and div (u_bar) = 0;
Given: K = max(0.10, exp(-pow(10 y-1.0 sin(10*x)-5.0, 2)) * I. Where I is an identity matrix, u_bar represents velocity, p represents pressure and the flow uses pressure boundary conditions with p = 1 at x = 0 and p = 0 at x = 1.
Now using the method of manufactured solutions, I selected the analytical expression for pressure to be p = 1 - x^2. I am in the process of iterating between different mesh sizes and comparing their corresponding L2 error and to do this, I generated a plot of log L2 error against log DOF.
This is where I have problems. As the mesh size is increased, the error trend shows that it is decreasing but also increases intermittently and fails to converge. I suspect the numerical differentiation on the right hand side of the variational formulation may be causing this problem but even so, I am stuck on what to do to proceed and I am still new to FEniCS.
Please see the code below and let me know where I got it wrong and what I can do to make the error converge.
from ufl import nabla_div, max_value
import sympy as sym
x, y = sym.symbols('x[0], x[1]')
# Creating mesh and defining function space
E = []
DOF = []
for m in range (5, 300, 25):
mesh = UnitSquareMesh(m, m)
# Defining Exact Solution for Pressure Distribution
p_e = Expression('1 - x[0]*x[0]', degree=2)
# Defining Dirichlet boundary
p_L = Constant(1.0)
def boundary_L(x, on_boundary):
bc_L = DirichletBC(V, p_L, boundary_L)
p_R = Constant(0.0)
def boundary_R(x, on_boundary):
return on_boundary and near(x[0], 1)
bc_R = DirichletBC(V, p_R, boundary_R)
bcs = [bc_L, bc_R]
# Defining variational problem
p = TrialFunction(V)
d = 2
I = Identity(d)
x, y = SpatialCoordinate(mesh)
M = max_value(Constant(0.10), exp(-(10*y-1.0*sin(10*x)-5.0)**2))
K = M*I
a = dot(K*grad(p), grad(v))*dx
f1 = as_vector((-2*x, 0))
f = nabla_div(dot(-K, f1))
L = inner(f, v)*dx
# Computing solutions
p = Function(V)
solve(a == L, p, bcs)
u_bar = -K*grad(p)
# Projecting the Velocity profile
W = VectorFunctionSpace(mesh, 'P', 1)
u_bar1 = project(u_bar, W)
# Evaluating difference between Numerical pressure, p and Exact pressure, p_e
p_e_f = interpolate(p_e, V)
diff_p = Function(V)
diff_p.vector()[:] = p.vector() - p_e_f.vector()
# Computing Error in L2 norm for Pressure
E1 = errornorm(p_e, p, 'L2')
print('E1 =', E1)
E.append(E1)
DOF.append(len(V.dofmap().dofs()))
print(E)
print(DOF)
Ea = np.array(E)
DOFa = np.array(DOF)
LogEa = np.log(Ea)
LogDOFa = np.log(DOFa)
print(LogEa)
print(LogDOFa)
x = np.log(DOF)
y = np.log(E)
plt.plot(x,y)
