Dear all,
I am trying to solve the following coupled system of PDEs using the mixed-dimensional branch:
- \Delta_\Gamma u = v|_\Gamma - 2u + g on \Gamma = \partial \Omega,
-\nabla v \cdot n = v|_\Gamma - u on \Gamma,
- \Delta v = 0 in \Omega = \{x \in \mathbb{R}^2 | \lVert x \rVert < 1\}
With g = 17x_1x_2, this system has the classical unique solution (u, v) with u(x) = 3x_1x_2 and v(x) = x_1x_2.
The weak form is given by
\int_\Gamma \nabla_\Gamma u_h \nabla_\Gamma \varphi_{u_h} d\sigma = \int_\Gamma (v|_\Gamma -u)\varphi_{u_h} + (-u + g) \varphi_{u_h} d\sigma,
\int_\Omega \nabla v_h \nabla_\Gamma \varphi_{v_h} dx = - \int_\Gamma (v|_\Gamma -u)\varphi_{v_h} d\sigma.
I was able to solve both of the decoupled systems. When i try to solve the coupled system, however, the solver does not converge, even with the exact solution as initial guess.
Any help is greatly appreciated!
Minimum working example:
# Exact solutions
exact_v = Expression("x[0]*x[1]", degree=2)
exact_u = Expression("3*x[0]*x[1]", degree=2)
class Bound(SubDomain):
return on_boundary
def coupled_bulk_surface():
mesh = Mesh("unitcircle.xml")
sub_domains = MeshFunction("size_t", mesh, "unitcircle_physical_region.xml")
boundary_parts = MeshFunction("size_t", mesh, "unitcircle_facet_region.xml")
marker = MeshFunction("size_t", mesh, mesh.topology().dim() - 1, 0)
marker.set_all(0)
bound = Bound()
bound.mark(marker, 1)
# Create submesh
submesh = MeshView.create(marker, 1)
# Setup formulation
V_b = FunctionSpace(submesh, "CG", 1)
W = MixedFunctionSpace(V, V_b)
g = Expression('17*x[0]*x[1]', degree=2)
z = Function(W)
v = z.sub(0)
u = z.sub(1)
(p, k) = TestFunctions(W)
# Define measures
dV = Measure("dx", domain=W.sub_space(0).mesh())
dL = Measure("dx", domain=W.sub_space(1).mesh())
# Variational formulation
F = dot(grad(u) , grad(k)) * dL + dot(grad(v), grad(p)) * dV - dot((v - u), k) * dL - dot((-u + g), k) * dL + dot((v - u), p) * dL
# Set exact solution as inital guess
v0 = interpolate(exact_v, V)
assign(z.sub(0), v0)
u0 = interpolate(exact_u, V_b)
assign(z.sub(1), u0)
# solve(F == 0, z)
# not working
# Error: Unable to successfully call PETSc function 'KSPSolve'.
# Reason: PETSc error code is: 56 (No support for this operation for this object type).
solve(F == 0, z, solver_parameters={"nonlinear_solver": "newton", "newton_solver": {"linear_solver": "gmres"}})
approx_v = z.sub(0)
approx_u = z.sub(1)
return (approx_v, approx_u)
# Main function
# Compute solution
(approx_v, approx_u) = coupled_bulk_surface()
Output:
python3 mwe.py
No Jacobian form specified for nonlinear mixed variational problem.
Differentiating residual form F to obtain Jacobian J = F'.
[problem] create list of residual forms OK
[problem] create list of jacobian forms OK, J_list size = 4
[MixedNonlinearVariationalProblem]::check_forms - To be implemented
Solving mixed nonlinear variational problem.
Newton iteration 0: r (abs) = 1.179e-01 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
File "mwe.py", line 69, in <module>
File "mwe.py", line 58, in coupled_bulk_surface
File "/usr/local/lib/python3.6/dist-packages/fenics_dolfin-2019.2.0.dev0-py3.6-linux-x86_64.egg/dolfin/fem/solving.py", line 233, in solve
File "/usr/local/lib/python3.6/dist-packages/fenics_dolfin-2019.2.0.dev0-py3.6-linux-x86_64.egg/dolfin/fem/solving.py", line 298, in _solve_varproblem
solver.solve()
RuntimeError:
*** Reason: Solution failed to converge in 10000 iterations (PETSc reason DIVERGED_ITS, residual norm ||r|| = 3.496623e-06).
*** Where: This error was encountered inside PETScKrylovSolver.cpp.
*** Process: 0
*** Git changeset: d7350469ca8a7a2d3ba3b5efd3cb34a5bea91853
