I recently moved from dolfinx 0.6.0 to dolfinx 0.7.3, by installing adios4dolfinx ADIOS4DOLFINx - A framework for checkpointing in DOLFINx — ADIOS2Wrappers via conda.
In the following example, I create a mesh via GMSH and define cell and surface tags.
I then import everything in dolfinx by using io.gmshio.model_to_mesh.
Finally, I save mesh, cell tags and facet tags in a XDMF file.
I run the script in parallel, for instance by using mpirun -n 5.
My problem:
I would like to read back the same mesh and meshtags, distributed in the same fashion among the 5 ranks. It worked out of the box with dolfinx 0.6.0, but it does not seem to be the case with dolfinx 0.7.3.
In the following example, the boundary dofs distributed among the 5 ranks are different when:
I save the mesh and then compute
boundary_dofs(save = True) -
I load mesh and meshtags from the
XDMFfile and then compute theboundary_dofs(save = False)
I tried to do a similar thing by using adios4dolfinx but I run into the same issue.
Could you please help me?
Many thanks
from dolfinx import io, fem
import os, shutil, sys
import petsc4py
petsc4py.init(sys.argv)
comm = MPI.COMM_WORLD
dim = 3
volume_tag = 1
surface_tag = 10
save = True
test_dir = os.path.join(os.getcwd(),'test')
if save:
# Save mesh and meshtags
if comm.rank == 0:
print('Saving ...', flush = True)
if os.path.isdir(test_dir):
shutil.rmtree(test_dir)
os.makedirs(test_dir)
# Create mesh
gmsh.option.setNumber("General.Terminal", 0)
model = gmsh.model()
model.add("Domain")
model.occ.addBox(0, 0, 0, 8, 8, 8)
model.occ.synchronize()
model.addPhysicalGroup(dim, [1], volume_tag)
model.setPhysicalName(dim, volume_tag, "Domain volume")
boundary_dimtags = model.getBoundary([(dim, 1)], oriented=False)
model.addPhysicalGroup(dim-1, [dt[1] for dt in boundary_dimtags], tag=surface_tag)
model.setPhysicalName(dim-1, surface_tag, "Domain surface")
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", 8/13)
model.mesh.generate(dim)
domain, cell_tags, facet_tags = io.gmshio.model_to_mesh(model, comm, rank=0, gdim=dim)
with io.XDMFFile(comm, test_dir+'/domain.xdmf', "w") as xdmf:
xdmf.write_mesh(domain)
cell_tags.name = "cell_tags"
facet_tags.name = "facet_tags"
xdmf.write_meshtags(cell_tags, domain.geometry)
xdmf.write_meshtags(facet_tags, domain.geometry)
xdmf.close()
# Load mesh and meshtags
if comm.rank == 0:
print('Loading ...', flush = True)
with io.XDMFFile(comm, test_dir+'/domain.xdmf', "r") as xdmf:
domain = xdmf.read_mesh()
tdim = domain.topology.dim
fdim = tdim - 1
cell_tags = xdmf.read_meshtags(domain, name = "cell_tags")
facet_tags = xdmf.read_meshtags(domain, name = "facet_tags")
assert cell_tags.name == "cell_tags"
assert facet_tags.name == "facet_tags"
# Compute boundary_dofs
Vp = fem.FunctionSpace(domain,("CG", 1))
boundary_dofs = fem.locate_dofs_topological(Vp, domain.topology.dim-1, facet_tags.find(surface_tag))
# boundary_dofs is different when the mesh is computed versus loaded
print('Rank = {}, self.boundary_dofs = {}\n\n'.format(comm.rank, boundary_dofs))
