I’m working with a Point Load at the end of the beam, not a distributed load. I tried to point it out with the variable T = Constant((0, 1000, 0))
In your initial code, you have never referred to a coordinate where the end load should be applied to. The T defines the vector of the distributed load. For implementation of a clamped beam under end load you may want to have a look at this discussion
