How to extract (vector valued) displacement magnitude + questionable highest stress not in contact area
Hello everyone,
I am working on a hyperelastic contact model using an analytically defined circular indenter within the penalty approach.
Question 1: How can i automatically evaluate maximum displacements and stresses in general?
This Example in the FEniCS legacy used the dot product and a projection for accomplishing this task. How can it be done using FEniCSx?
Displacements
Question 2: How can the highest stress occour inside the bar? Paraview automatically visulizes the stress tensor using a maginitude (unusual?) - How can I avoid it? Should I only use the normal projection for contact stresses?
Cauchy Stress
Here’s the MWE as short as possible
from dolfinx import fem, mesh, log
from petsc4py.PETSc import ScalarType, Options
from dolfinx import nls
# domain geometries
length = 0.25
height = 0.02
# dimensions of stiff indenter
D = 0.15
center_x = length / 2
center_y = (height + (D/2)) -  0.01
# build rectangular domain
domain = mesh.create_rectangle(MPI.COMM_WORLD, [[0.0, 0.0],[length, height]], [40, 9])
n = ufl.FacetNormal(domain)
def bottom(x):
    return np.isclose(x[1], 0)
def top(x):
    return np.isclose(x[1], height)
tdim = domain.topology.dim
fdim = tdim - 1
bottom_facets = mesh.locate_entities_boundary(domain,fdim,bottom)
top_facets = mesh.locate_entities_boundary(domain,fdim,top)
marked_facets = np.hstack([bottom_facets, top_facets])
marked_values = np.hstack([np.full_like(bottom_facets, 1), np.full_like(top_facets, 2)])
facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
metadata = {"quadrature_degree":4}
ds = ufl.Measure('ds',domain=domain, subdomain_data=facet_tag, metadata=metadata)
V = fem.VectorFunctionSpace(domain, ("CG",1))
u = fem.Function(V, name="Displacement")
du = ufl.TrialFunction(V)
# fixed bottom as dirichlet bc
u_zero = np.array((0,)*domain.geometry.dim, dtype=ScalarType)
bc = fem.dirichletbc(u_zero, fem.locate_dofs_topological(V, fdim, facet_tag.find(1)), V)
# definition of gap function - circular indenter
def gapp(u, x):
    R = ufl.sqrt(pow(((x[0] - center_x) + u[0]), 2) + pow(((x[1] - center_y) + u[1]), 2))
    return  R - (D/2)
# maculay bracket for contact enforcement
def maculay(x):
    return (x+abs(x))/2
# test and trial functions
u_ = ufl.TestFunction(V)
######### kinematic #########
# Spatial dimension
d = len(u)
# Identity tensor
I = ufl.variable(ufl.Identity(d))
# Deformation gradient
F = ufl.variable(I + ufl.grad(u))
# Right Cauchy-Green tensor
C = ufl.variable(F.T * F)
Ic = ufl.variable(ufl.tr(C))
J  = ufl.variable(ufl.det(F))
# hyperelastic material properties, according to demo
E = ScalarType(1.0e4)
nu = ScalarType(0.3)
mu = fem.Constant(domain, E/(2*(1 + nu)))
lmbda = fem.Constant(domain, E*nu/((1 + nu)*(1 - 2*nu)))
psi = (mu / 2) * (Ic - 3) - mu * ufl.ln(J) + (lmbda / 2) * (ufl.ln(J))**2
P = ufl.diff(psi, F)
S = 2 * ufl.diff(psi, C)
# create XDMF output
xdmf = XDMFFile(domain.comm, "ironing/output.xdmf", "w")
xdmf.write_mesh(domain)
# penalty stiffness for the contact
pen = fem.Constant(domain, ScalarType(1e6))
# weak formulation to solve for the nonlinear problem
form = ufl.inner(ufl.grad(u_), P)*dx + pen * ufl.inner(u_, n*maculay(-gapp(x, u)))*ds(2)
# set up nonlinear problem to solve
Jac = ufl.derivative(form, u, du)
problem = fem.petsc.NonlinearProblem(form, u, bcs=[bc], J=Jac)
solver = nls.petsc.NewtonSolver(domain.comm, problem)
# Set Newton solver options
solver.atol = 1e-6
solver.rtol = 1e-6
solver.report = True
ksp = solver.krylov_solver
opts = Options()
ksp.setFromOptions()
# solver logging on
# solver solve
w, converged = solver.solve(u)
assert(converged)
xdmf.write_function(u)
print(f"Number of interations: {w:d}")
# postprocessing: True stress / Cauchy stress
V_stress = fem.TensorFunctionSpace(domain, ("DG", 0))
cauchy_stress = (1./J) * F*S*F.T
stress_expr = fem.Expression(cauchy_stress, V_stress.element.interpolation_points())
cauchystress = fem.Function(V_stress, name="CauchyStress")
cauchystress.interpolate(stress_expr)
xdmf.write_function(cauchystress)
xdmf.close()
Thanks in advance!
See Electromagnetics example FEniCSx and
