You are making some major assumptions here that simply cannot be held by DOLFINx
This is because:
- Only simple function spaces has the same number of dofs as the mesh geometry
- The input ordering does not make sense once one wants to run in parallel.
More information about this has been discussed in:
Consider the following MWE to map a vertex->mesh node->original_input_position
pp = np.array([[0.5, 1], [2, 1], [3, 1.5], [3.5, 2.5], [2.2, 2], [1, 2.2]])
ee = np.array([[0, 1, 5], [1, 4, 5], [1, 2, 4], [2, 3, 4]])
plt.triplot(pp[:, 0], pp[:, 1], ee)
plt.show()
gdim = 2
shape = "triangle"
degree = 1
cell = ufl.Cell(shape, geometric_dimension=gdim)
domain = ufl.Mesh(ufl.VectorElement("Lagrange", cell, degree))
cells = np.array(ee, dtype=np.int32)
mesh = dolfinx.mesh.create_mesh(MPI.COMM_WORLD, cells, pp, domain)
V = dolfinx.fem.FunctionSpace(mesh, ("CG", 1))
dofs = V.tabulate_dof_coordinates()[:, 0:2]
geom_loc_to_org = mesh.geometry.input_global_indices
vertices = np.arange(mesh.topology.index_map(0).size_local, dtype=np.int32)
top_to_geom = dolfinx.cpp.mesh.entities_to_geometry(mesh, 0, vertices, False).reshape(-1)
for ii in range(len(vertices)):
geom_node= top_to_geom[vertices[ii]]
original_pos = geom_loc_to_org[top_to_geom[ii]]
assert np.allclose(pp[original_pos,:], mesh.geometry.x[geom_node, :mesh.geometry.dim])
print(f"{pp[original_pos,:]=}, {mesh.geometry.x[geom_node, :]=}")
The reason for
vertex->mesh node is that DOLFINx supports isoparametric mesh elements (i.e. you can have higher order cells that have more nodes than just vertices).
