Dear all,
I am having a problem when computing an inner product over the domain boundaries.
My code runs without errors, but I think that the output is wrong because I am combining functions that belong to different finite element spaces.
The definition of the function space and solution vector is:
<\boldsymbol{\sigma}, \boldsymbol{\mathcal{U}}>_{\Gamma} = \int_{\Gamma} \left[\left(p\hat{\boldsymbol{n}} + \frac{1}{Re}\hat{\boldsymbol{n}} \cdot \nabla \boldsymbol{u} \right) \cdot \boldsymbol{\mathcal{U}}\right] d\Gamma
where p is pressure, \boldsymbol{u} is velocity, \hat{\boldsymbol{n}} is the unit normal vector to the boundaries, \boldsymbol{\mathcal{U}} is the velocity at the boundaries and \Gamma defines the boundaries.
# Function Space
el1 = ufl.VectorElement("Lagrange", domain.ufl_cell(), 2)
el2 = ufl.FiniteElement("Lagrange", domain.ufl_cell(), 1)
mel = ufl.MixedElement([el1, el2])
Y = fem.FunctionSpace(domain, mel)
# Solution vector
q_n = fem.Function(Y)
u_n = q_n.sub(0)
p_n = q_n.sub(1)
Then, I compute the inner product as follows:
Fun = fem.form( ufl.inner((p_n*n + (1/Re)*ufl.dot(n,ufl.grad(u_n))), v)*ufl.ds )
Fun_assemble = MPI.COMM_WORLD.gather(fem.assemble_scalar(Fun), root=0)
As I said, my belief is that I’m not projecting p_n into the function space of u_n, but it might also be that I’m not expressing the inner product properly.
Does anybody know what I am doing wrong?
Please, find below a minimal example:
from dolfinx import fem, mesh, io, plot, cpp, graph
rank = MPI.COMM_WORLD.rank
# Define mesh
domain = mesh.create_rectangle(MPI.COMM_WORLD, [[0, 0],[1, 0.1]], [100, 10])
n = ufl.FacetNormal(domain)
# Define function space
# Define boundaries
def boundary_function_L(x):
return np.isclose(x[0], 0)
def boundary_function_R(x):
return np.isclose(x[0], 1)
def boundary_function_B(x):
return np.isclose(x[1], 0)
def boundary_function_T(x):
return np.isclose(x[1], 0.1)
# Define solution vector
u_n = q_n.sub(0)
p_n = q_n.sub(1)
u, p = ufl.TrialFunctions(Y)
v, q = ufl.TestFunctions(Y)
# Inner product
Re = 100
Note that here Fun_assemble is going to be zero because u_n and p_n have been just initialised, but in my full code it’s also zero even though u_n and p_n are different from zero.
Many thanks in advance.
