Hi, I’m a new user. I want to model a 1D heat equation with time varying Dirichlet BC and two subdomains: one that has a temperature dependent thermal conductivity, the other has a constant thermal conductivity. I have tried modifying the example problems based on the heat equation with subdomains and nonlinear Poisson equation, but I haven’t been able to successfully combine them. Here is what I have so far:
import sympy as sym
T = 2.0 # final time
num_steps = 10 # number of time steps
alpha = 3 # parameter alpha
beta = 5 # parameter beta
tol = DOLFIN_EPS
def k_0(u):
return 1+2*u
class K(Expression):
def set_k_values(self, k_0, k_1):
self.k_0, self.k_1 = k_0, k_1
def eval(self, value, x, u):
"Set value[0] to value at point x"
tol = 1E-14
if x[0] <= 0.5 + tol:
value[0] = self.k_0
value[0] = self.k_1
k_1 = 0.01
# Attempt at using C++ code snippet
#kappa = Expression('x[0] <= 0.5 + tol ? 1+1*u : k_1', degree=0,
#tol=tol, k_1=k_1, u=0)
kappa = K()
kappa.set_k_values(k_0,k_1)
meshpoints = 50
my_mesh = UnitIntervalMesh ( meshpoints )
V = FunctionSpace(my_mesh, 'P', 1)
# Define boundary condition
u_D = Expression('1 + beta*t',beta=beta, degree=1, t=0)
def boundary ( x ):
value = x[0] < DOLFIN_EPS
return value
# Define initial value
u_n = interpolate(u_D, V)
#u_n = project(u_D, V)
f = Constant(beta - 2 - 2*alpha)
F = u*v*dx + kappa*dt*dot(grad(u), grad(v))*dx - (u_n + dt*f)*v*dx
# Time-stepping
t = 0
for n in range(num_steps):
# Update current time
u_D.t = t
# Compute solution
solve(F==0, u, bc)
# Plot solution
plot(u)
# Compute error at vertices
# u_e = interpolate(u_D, V)
# error = np.abs(u_e.vector().array() - u.vector().array()).max()
# print('t = %.2f: error = %.3g' % (t, error))
# Update previous solution
u_n.assign(u)
