Non-linear stationary heat quation in 3D
Hi there,
I’m trying to solve the heat equation in 3D without Dirichlet-BC and two Neumann-BC’s. One represents a spatially constant heat inflow that is applied to a subdomain of the boundary. The other non-linear term represents the heat radiation.
However the solver does not converge. I’m not too familiar with non-linear PDE’s, so my question is how to look for the problem.
Here you see a minimum example:
def bottom(x, on_boundary):
    return x[2]<-.99 and on_boundary
def top(x, on_boundary):
    return x[2]> .99 and on_boundary
class Top(SubDomain):
    def __init__(self):
        super().__init__()
    def inside(self,x, on_boundary):
        return top(x, on_boundary)
# define mesh and functionspace
mesh    = BoxMesh(Point(-1,-1,-1), Point(1,1,1),10,10,10)
V       = FunctionSpace(mesh, 'CG', 1)
# mark subdomain
sub_domains = MeshFunction('size_t', mesh, mesh.topology().dim()-1)
sub_domains.set_all(0)
top_domain = Top()
top_domain.mark(sub_domains, 1)
ds = Measure('ds', domain=mesh, subdomain_data=sub_domains)
# define and solve variational formulation
u0  = Constant(293.15)
u   = Function(V)
v   = TestFunction(V)
F   =   inner(grad(u) ,grad(v)) * dx + (u**4-u0**4)*v*ds - v*ds(1)
solve(F == 0, u,  solver_parameters={"newton_solver":{"relative_tolerance": 1e-6}})
Modify your initial guess to be closer to your wanted temperature. Use for instance:
u.vector()[:] = 200
before you solve and the newton solver will converge
Now it works, thanks!
