2D poisson problem with piecewise function f
Hello everyone. I am quite new to coding and this problem has been bugging me for a long time.
I am trying to code a boundary value problem in the unit square mesh, however, I have a problem defining the function properly.
Created on Mon Dec 20 21:30:34 2021
@author: Shirley
FEniCS tutorial demo program: Poisson equation with Dirichlet conditions.
Test problem is chosen to give an exact solution at all nodes of the mesh.
  -Laplace(u) = f    in the unit square
            u = u_D  on the boundary
  u_D = 0
         ( 1 \in \Omega'
    f = {
         ( 0 \in  \Omega - \Omega'
mesh = UnitSquareMesh(8, 8)
# Define boundary condition
u_D = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]', degree=2)
def boundary(x, on_boundary):
    return on_boundary
tol = 1E-14
class Omega_1(SubDomain):
        return ( (x[0] >= 0.35 + tol) &  (x[0] <= 0.7 + tol) & (x[1] >= 0.35 + tol) & (x[1] <= 0.7 + tol) )
class Omega_1_bdry_left(SubDomain):
        return ( (x[0] >= 0.34 + tol) &  (x[0] < 0.35 + tol) & (x[1] >= 0.34 + tol) & (x[1] <= 0.71 + tol) )
class Omega_1_bdry_right(SubDomain):
        return ( (x[0] >= 0.7 + tol) &  (x[0] < 0.71 + tol) & (x[1] >= 0.34 + tol) & (x[1] <= 0.71 + tol) )
class Omega_1_bdry_bottom(SubDomain):
        return ( (x[0] >= 0.35 + tol) &  (x[0] < 0.7 + tol) & (x[1] >= 0.34 + tol) & (x[1] <= 0.35 + tol) )
class Omega_1_bdry_top(SubDomain):
        return ( (x[0] >= 0.35 + tol) &  (x[0] < 0.7 + tol) & (x[1] >= 0.7 + tol) & (x[1] <= 0.71 + tol) )
# class Omega_2(SubDomain):
#     def inside(self, x, on_boundary):
#         return x[1] >= 0.5 - tol
p1 = Constant(1.0)
p2 = Constant(0.0)
f = Expression(' ( (x[0] >= 0.35 + DOLFIN_EPS)&&(x[0] <= 0.7 + DOLFIN_EPS)&&(x[1] >= 0.35 + DOLFIN_EPS)&&(x[1] <= 0.7 + DOLFIN_EPS) ) ? p1 : ( ( (x[0] < 0.35 + DOLFIN_EPS)&&(x[0] > 0.7 + DOLFIN_EPS)&&(x[1] < 0.35 + DOLFIN_EPS)&&(x[1] > 0.7 + DOLFIN_EPS) ) ? p2 : 0 ) ) ',
             p1=p1, p2=p2, degree=2 )
# f = Constant(-6.0)
a = dot(grad(u), grad(v))*dx
L = f*v*dx
# Compute solution
solve(a == L, u, bc)
# Plot solution and mesh
plot(u)
plot(mesh)
# Save solution to file in VTK format
vtkfile = File('poisson/solution.pvd')
vtkfile << u
# Compute error in L2 norm
error_L2 = errornorm(u_D, u, 'L2')
# Compute maximum error at vertices
vertex_values_u_D = u_D.compute_vertex_values(mesh)
error_max = np.max(np.abs(vertex_values_u_D - vertex_values_u))
# Print errors
print('error_L2  =', error_L2)
print('error_max =', error_max)
# Hold plot
I get this error, but I don’t know why:
File “/Users/Shirley/Downloads/PrgrmngMtrs/fiat-master/test/plsworktest.py”, line 71, in
f = Expression(’ ( (x[0] >= 0.35 + DOLFIN_EPS)&&(x[0] <= 0.7 + DOLFIN_EPS)&&(x[1] >= 0.35 + DOLFIN_EPS)&&(x[1] <= 0.7 + DOLFIN_EPS) ) ? p1 : ( ( (x[0] < 0.35 + DOLFIN_EPS)&&(x[0] > 0.7 + DOLFIN_EPS)&&(x[1] < 0.35 + DOLFIN_EPS)&&(x[1] > 0.7 + DOLFIN_EPS) ) ? p2 : 0 ) ) ',
File “/Users/Shirley/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/dolfin/function/expression.py”, line 400, in init
File “/Users/Shirley/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/dolfin/function/jit.py”, line 158, in compile_expression
File “/Users/Shirley/opt/anaconda3/envs/fenicsproject/lib/python3.10/site-packages/dolfin/jit/jit.py”, line 170, in compile_class
raise RuntimeError(“Unable to compile C++ code with dijitso”)
Also, I have defined the function to be 1 at the subdomain Omega1 and it should be zero outside. I also defined a subdomain around Omega1 to set the function from 1 to 0. Is there a better way to do this?
The error occurs because you have an extra ‘)’ inside the expression. The correct f should be:
f = Expression(' ( (x[0] >= 0.35 + DOLFIN_EPS)&&(x[0] <= 0.7 + DOLFIN_EPS)&&(x[1] >= 0.35 + DOLFIN_EPS)&&(x[1] <= 0.7 + DOLFIN_EPS) ) ? p1 : ( ( (x[0] < 0.35 + DOLFIN_EPS)&&(x[0] > 0.7 + DOLFIN_EPS)&&(x[1] < 0.35 + DOLFIN_EPS)&&(x[1] > 0.7 + DOLFIN_EPS) ) ? p2 : 0 ) ',
Note that the second condition in this expression, i.e.
&& (x[0] > 0.7 + DOLFIN_EPS)
&& (x[1] < 0.35 + DOLFIN_EPS)
&& (x[1] > 0.7 + DOLFIN_EPS)
will always be false. The && operator is the C++ logical “and” operator. x[0] cannot simultaneously be less than 0.35 and greater than 0.7. It looks like you are trying to define a source term that is equal to 1 inside the subdomain \bigl( [0.35,0.7]\times[0.35,0.7]\bigr) and zero outside. If that is the case, the expression
f = Expression(' ( (x[0] >= 0.35 - DOLFIN_EPS)&&(x[0] <= 0.7 + DOLFIN_EPS)&&(x[1] >= 0.35 - DOLFIN_EPS)&&(x[1] <= 0.7 + DOLFIN_EPS) ) ? p1 : p2',
is sufficient to achieve what you desire. Note that I have altered some of the conditionals, i.e.
by subtracting DOLFIN_EPS instead of adding it. This allows the point 0.35 to be included in \Omega_1 rather than excluded.
The best way to do this would be to create a mesh that conforms with \Omega_1 (e.g., using gmsh), apply a marker to \Omega_1, then create a Measure to integrate the source term only over \Omega_1. Your current approach using an Expression will not create a piecewise function, since it must first be interpolated into a finite element space, and your mesh elements do not conform with the boundary of \Omega_1.
