2D Poisson with Vector Basis Functions
I am new to Fenicsx and FEM, I studied on tutorials and previous discussions but I could not solve this problem, it is a simple question for you but I would be very happy if you answer it, it is important for me. I want to solve the 2D Poisson problem in the relevant mesh I created and I want to keep the stiffness matrix, right-hand side and solution as a matrix form. I wrote a code like the one below for this, but I still get the error in the rest of the code. Also, will my code enable 2D Poisson solving using Nedelec basis functions on the relevant mesh? Also, how can I add the 0 or another Dirichlet boundary condition to this scenario ? Thanks
from dolfinx import mesh, fem, plot, io
from dolfinx.io import gmshio
import pyvista
import scipy.sparse
Initialize visualization
pyvista.start_xvfb()
def create_mesh_with_num_triangles(target_num_triangles):
if gmsh.isInitialized():
gmsh.finalize()
gmsh.model.add(“Mesh with target triangles”)
rectangle_tag = gmsh.model.occ.addRectangle(0, 0, 0, 1, 1)
gmsh.model.occ.synchronize()
average_edge_length = np.sqrt(2 / target_num_triangles)
gmsh.model.mesh.setSize(gmsh.model.getEntities(0), average_edge_length)
gmsh.model.mesh.generate(2)
gmsh.model.addPhysicalGroup(2, [rectangle_tag], 1)
gmsh.write(“target_mesh.msh”)
gmsh.finalize()
MPI.COMM_WORLD.Barrier()
return gmshio.read_from_msh(“target_mesh.msh”, MPI.COMM_WORLD, gdim=2)[0]
def visualize_mesh(mesh):
topology, cell_types, geometry = plot.vtk_mesh(mesh, mesh.geometry.dim)
grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
plotter = pyvista.Plotter()
plotter.view_xy()
if not pyvista.OFF_SCREEN:
plotter.show()
plotter.screenshot(“target_mesh.png”)
Create and visualize mesh
mesh = create_mesh_with_num_triangles(100)
Setup function space and problem
V = fem.FunctionSpace(mesh, ufl.FiniteElement(“Nedelec 1st kind H(curl)”, mesh.ufl_cell(), 1))
sigma = ufl.TrialFunction(V)
a = fem.form(ufl.inner(ufl.curl(sigma), ufl.curl(v)) * ufl.dx)
L = fem.form(ufl.inner(ufl.as_vector((1, 1)), v) * ufl.dx)
Assembly system
A = dolfinx.fem.petsc.assemble_matrix(dolfinx.fem.form(a))
b = fem.assemble_vector(L)
b.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE) # Ensure correct assembly
Solver setup
solver = PETSc.KSP().create(MPI.COMM_WORLD)
solver.setOperators(A)
u = fem.Function(V)
#Solve
solver.solve(b, u.vector)
Save solutions
with io.XDMFFile(MPI.COMM_WORLD, “solution.xdmf”, “w”) as xdmf:
xdmf.write_mesh(mesh)
xdmf.write_function(u)
Error: ---------------------------------------------------------------------------
AttributeError Traceback (most recent call last)
Cell In[16], line 56
54 A.assemble()
55 b = fem.assemble_vector(L)
—> 56 b.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE) # Ensure correct assembly
58 # Solver setup
59 solver = PETSc.KSP().create(MPI.COMM_WORLD)
AttributeError: ‘Vector’ object has no attribute ‘ghostUpdate’
I used 0.7.2. Dolfinx version.
Thank you,
Chen
Please format your code properly, otherwise it may be very hard to follow. Use “```” to get the right formatting.
For the specific error you get, you’d probably want to assemble b as b = fem.petsc.assemble_vector(L) (note the additional petsc), otherwise the output vector b is not in PETSc format, and hence you cannot use the PETSc-specific method ghostUpdate.
Thank you sir, I wrote this code to solve curl (curlE) = J and Homogeneous Dirichlet (zero values on the boundaries) boudary conditions. Code is attached to the below. My question is, error of this solution is closer to 1, what is my error in the code. I am new in Fenicsx, if you help me I will be very happy. I searched it but looks correct. Normalized L2 norm of the error: 0.9530089726246179
The code:
"def create_mesh_with_num_triangles(target_num_triangles):
gmsh.finalize()
gmsh.finalize()
plotter.view_xy()
plotter.show()
target_num_triangles = 100
mesh = create_mesh_with_num_triangles(target_num_triangles)
Define function space using Nedelec basis functions for H(curl) space
element = ufl.FiniteElement(“N1curl”, mesh.ufl_cell(), 1)
V = fem.FunctionSpace(mesh, element)
Define trial and test functions
E = ufl.TrialFunction(V)
Define source term (current density)
J = fem.Constant(mesh, PETSc.ScalarType((1.0, 0.0))) # Non-zero source term
Define variational problem
a = ufl.inner(ufl.curl(E), ufl.curl(v)) * ufl.dx
L = ufl.inner(J, v) * ufl.dx
Apply boundary conditions (homogeneous Dirichlet)
boundary_facets = dolfinx.mesh.locate_entities_boundary(mesh, mesh.topology.dim - 1, lambda x: np.full(x.shape[1], True))
boundary_dofs = fem.locate_dofs_topological(V, mesh.topology.dim - 1, boundary_facets)
zero_vec = fem.Function(V)
with zero_vec.vector.localForm() as loc:
loc.set(0.0)
bc = fem.dirichletbc(zero_vec, boundary_dofs)
Assemble system
a_form = fem.form(a)
L_form = fem.form(L)
A = fem.petsc.assemble_matrix(a_form, bcs=[bc])
b = fem.petsc.assemble_vector(L_form)
fem.petsc.apply_lifting(b, [a_form], [[bc]])
fem.petsc.set_bc(b, [bc])
Solve the system
solver.setType(PETSc.KSP.Type.CG)
solver.getPC().setType(PETSc.PC.Type.HYPRE)
solver.setTolerances(rtol=1e-8)
E_h = fem.Function(V)
solver.solve(b, E_h.vector)
E_h.x.scatter_forward()
Save the FEM solution vector
np.save(“solution_vector.npy”, E_h.vector.array)
Define the exact solution (since the exact solution for this problem is not trivial, we’ll use a known one)
E_exact_expr = ufl.as_vector((ufl.sin(ufl.pi * x[0]), ufl.sin(ufl.pi * x[1])))
Interpolate the exact solution into the function space
E_exact = fem.Function(V)
E_exact_expr = fem.Expression(E_exact_expr, V.element.interpolation_points(), mesh.comm)
E_exact.interpolate(E_exact_expr)
Save the exact solution vector
np.save(“exact_solution_vector.npy”, E_exact.vector.array)
Compute the error in the original Nedelec space
error = fem.Function(V)
error.vector.array = E_h.vector.array - E_exact.vector.array
Compute the L2 norm of the error in the Nedelec space
L2_error_form = ufl.inner(error, error) * ufl.dx
error_L2_local = fem.assemble_scalar(fem.form(L2_error_form))
error_L2 = np.sqrt(mesh.comm.allreduce(error_L2_local, op=MPI.SUM))
Compute the L2 norm of the exact solution in the Nedelec space
L2_exact_form = ufl.inner(E_exact, E_exact) * ufl.dx
exact_L2_local = fem.assemble_scalar(fem.form(L2_exact_form))
exact_L2 = np.sqrt(mesh.comm.allreduce(exact_L2_local, op=MPI.SUM))
Normalize the L2 error
normalized_L2_error = error_L2 / exact_L2
print(f"Normalized L2 norm of the error in Nedelec space: {normalized_L2_error}")
Compute the maximum error at any degree of freedom in the Nedelec space
error_max = np.max(np.abs(E_exact.vector.array - E_h.vector.array))
print(f"Maximum error in Nedelec space: {error_max}“)”
The code is still not properly formatted and not runnable (e.g., imports are missing). No one will be able to help if you keep posting your code this way.
Sorry, for that, code is:
import pyvista
import scipy.sparse
        gmsh.finalize()
    gmsh.model.add("Mesh with target triangles")
    gmsh.write("target_mesh.msh")
    gmsh.finalize()
    return gmshio.read_from_msh("target_mesh.msh", MPI.COMM_WORLD, gdim=2)[0]
    plotter.view_xy()
        plotter.show()
        plotter.screenshot("target_mesh.png")
# Create and visualize mesh
# Define function space using Nedelec basis functions for H(curl) space
element = ufl.FiniteElement("N1curl", mesh.ufl_cell(), 1)
# Define source term (current density)
# Apply boundary conditions (homogeneous Dirichlet)
    loc.set(0.0)
# Assemble system
# Solve the system
# Save the FEM solution vector
np.save("solution_vector.npy", E_h.vector.array)
# Define the exact solution (since the exact solution for this problem is not trivial, we'll use a known one)
# Interpolate the exact solution into the function space
# Save the exact solution vector
np.save("exact_solution_vector.npy", E_exact.vector.array)
# Compute the error in the original Nedelec space
# Compute the L2 norm of the error in the Nedelec space
# Compute the L2 norm of the exact solution in the Nedelec space
# Normalize the L2 error
# Compute the maximum error at any degree of freedom in the Nedelec space
print(f"Maximum error in Nedelec space: {error_max}")
I edited your latest post myself. Please go and have a look on how I did that, so that in future you don’t keep posting unformatted code.
General suggestions:
  • Are you really sure that J is the appropriate forcing term to have E_exact_expr as the exact solution? I haven’t done the math myself (I have never worked with curl/curl problems), but it’s worth double checking
  • If you are sure of what you wrote for J and E_exact_expr, what happens if you refine the mesh?
