A problem about Boundary condition setting
Hi,I am learning to use fenics to solve 3D heat conduction problems.When I was replicating the code,I met some difficulties. The simulation object is a simple model consisting of an air region, a wire region and a substrate. The question is how to set the boundary conditions so that the air dissipates the heat from the substrate and the heated area. When I set the Constant temperature boundary at the top of the air area and the bottom of the substrate,I get the following error
Discontinuous type Coefficient must be restricted.
  File "/mnt/write_air.py", line 156, in <module>
    problem = NonlinearVariationalProblem(weak_form, TsteadyVsteady, bcs, J = Jacsteady)
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/problem.py", line 157, in __init__
    F = Form(F, form_compiler_parameters=form_compiler_parameters)
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/form.py", line 44, in __init__
    mpi_comm=mesh.mpi_comm())
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/jit/jit.py", line 50, in mpi_jit
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/jit/jit.py", line 100, in ffc_jit
  File "/usr/lib/python3/dist-packages/ffc/jitcompiler.py", line 217, in jit
    module = jit_build(ufl_object, module_name, parameters)
  File "/usr/lib/python3/dist-packages/ffc/jitcompiler.py", line 133, in jit_build
    generate=jit_generate)
  File "/usr/lib/python3/dist-packages/dijitso/jit.py", line 165, in jit
    header, source, dependencies = generate(jitable, name, signature, params["generator"])
  File "/usr/lib/python3/dist-packages/ffc/jitcompiler.py", line 66, in jit_generate
    prefix=module_name, parameters=parameters, jit=True)
  File "/usr/lib/python3/dist-packages/ffc/compiler.py", line 143, in compile_form
    prefix, parameters, jit)
  File "/usr/lib/python3/dist-packages/ffc/compiler.py", line 185, in compile_ufl_objects
    analysis = analyze_ufl_objects(ufl_objects, kind, parameters)
  File "/usr/lib/python3/dist-packages/ffc/analysis.py", line 90, in analyze_ufl_objects
    for form in forms)
  File "/usr/lib/python3/dist-packages/ffc/analysis.py", line 90, in <genexpr>
    for form in forms)
  File "/usr/lib/python3/dist-packages/ffc/analysis.py", line 174, in _analyze_form
    do_apply_restrictions=True)
  File "/usr/lib/python3/dist-packages/ufl/algorithms/compute_form_data.py", line 321, in compute_form_data
    form = apply_restrictions(form)
  File "/usr/lib/python3/dist-packages/ufl/algorithms/apply_restrictions.py", line 165, in apply_restrictions
    only_integral_type=integral_types)
  File "/usr/lib/python3/dist-packages/ufl/algorithms/map_integrands.py", line 47, in map_integrand_dags
    form, only_integral_type)
  File "/usr/lib/python3/dist-packages/ufl/algorithms/map_integrands.py", line 28, in map_integrands
    for itg in form.integrals()]
  File "/usr/lib/python3/dist-packages/ufl/algorithms/map_integrands.py", line 28, in <listcomp>
  File "/usr/lib/python3/dist-packages/ufl/algorithms/map_integrands.py", line 35, in map_integrands
    return itg.reconstruct(function(itg.integrand()))
  File "/usr/lib/python3/dist-packages/ufl/algorithms/map_integrands.py", line 46, in <lambda>
    return map_integrands(lambda expr: map_expr_dag(function, expr, compress),
  File "/usr/lib/python3/dist-packages/ufl/corealg/map_dag.py", line 26, in map_expr_dag
    result, = map_expr_dags(function, [expression], compress=compress)
  File "/usr/lib/python3/dist-packages/ufl/corealg/map_dag.py", line 73, in map_expr_dags
    r = handlers[v._ufl_typecode_](v)
  File "/usr/lib/python3/dist-packages/ufl/algorithms/apply_restrictions.py", line 88, in reference_value
    g = self(f)
  File "/usr/lib/python3/dist-packages/ufl/corealg/multifunction.py", line 89, in __call__
    return self._handlers[o._ufl_typecode_](o, *args)
  File "/usr/lib/python3/dist-packages/ufl/algorithms/apply_restrictions.py", line 134, in coefficient
    return self._require_restriction(o)
  File "/usr/lib/python3/dist-packages/ufl/algorithms/apply_restrictions.py", line 47, in _require_restriction
    error("Discontinuous type %s must be restricted." % o._ufl_class_.__name__)
  File "/usr/lib/python3/dist-packages/ufl/log.py", line 158, in error
ufl.log.UFLException: Discontinuous type Coefficient must be restricted.
The code is shown below
from scipy import interpolate as sci_interpolate
msh = meshio.read("Sample.msh")
print("Available cell types in msh.cells:")
for cell in msh.cells:
    print(f"Cell type: {cell.type}, Number of cells: {len(cell.data)}")
tetra_cells = [cells.data for cells in msh.cells if cells.type == "tetra"]
triangle_cells = [cells.data for cells in msh.cells if cells.type == "triangle"]
if tetra_cells:
    cells = np.vstack(np.array(tetra_cells))
    tetra_data = msh.cell_data_dict["gmsh:physical"]["tetra"]
    tetra_mesh = meshio.Mesh(points=msh.points, cells=[("tetra", cells)], cell_data={"name_to_read": [tetra_data]})
    meshio.xdmf.write("mesh_test0.xdmf", tetra_mesh)
    raise ValueError("No tetra cells found in the mesh!")
if triangle_cells:
    facet_cells = np.vstack(np.array(triangle_cells))
    facet_data = msh.cell_data_dict["gmsh:physical"]["triangle"]
    facet_mesh = meshio.Mesh(points=msh.points, cells=[("triangle", facet_cells)], cell_data={"name_to_read": [facet_data]})
    meshio.xdmf.write("facet_mesh_test0.xdmf", facet_mesh)
    raise ValueError("No triangle cells found in the mesh!")
# Use dolfin below.
mesh = Mesh()
# Read mesh.
with XDMFFile("mesh_test0.xdmf") as infile:
    infile.read(mesh)
with XDMFFile("facet_mesh_test0.xdmf") as infile:
mvc2 = MeshValueCollection("size_t", mesh, 3)
    infile.read(mvc2, "name_to_read")
cf = cpp.mesh.MeshFunctionSizet(mesh, mvc2)
dx = Measure("dx", domain=mesh,subdomain_data=cf)
# External surface
ds = Measure("ds", domain=mesh, subdomain_data=mf)
# Internal surface
dS = Measure("dS", domain=mesh, subdomain_data=mf)
subdomains = cf
boundary_parts = mf
# Volumes
# 1 thin film
# 2 heater wire
# 3 air
# Surfaces
# 4 left end heater wire.
# 5 right end heater wire.
# 6 heater_front
# 7 "heater_behind"
# 8 "heater_top"
# 9 Interface between wire and thin film.
# 10 "thin_film_top"
# 11 Thin film bottom
# 12 "air_top"
# 13 "air_left"
# 14 "air_front"
# 15 "air_behind"
# 16 "air_right"
dx_air=dx(subdomain_id=3)
dx_thin_film = dx(subdomain_id=1)
dx_wire = dx(subdomain_id=2)
ds_bottom_thin_film = ds(subdomain_id=11)
dS_interface=dS(subdomain_id=9)
ME = FunctionSpace(mesh, P1*P1)
h_air_film = Constant(5.0)  #Heat exchange coefficient W/(m²·K)
h_air_wire = Constant(5.0)  #Heat exchange coefficient W/(m²·K)
T_ref = 300.0
kappa_air = Constant(0.025)  # Thermal conductivity W/(m·K)
Dens_air = Constant(1.225)  # density kg/m^3
cp_air = Constant(1005)  #  Heat Capacity J/(kg·K)
kappa_wire = Constant(75.0)
kappa_thin_film = Constant(7.8)
rho_interpolated = sci_interpolate.InterpolatedUnivariateSpline([10,400], [2.25e-9, 1.14e-7], k=1) # linear interpolation
current = Constant(90e-1)
J_0 = current / assemble(1 * dS(4))
dTsteadyVsteady = TrialFunction(ME)
usteady, vsteady = TestFunctions(ME)
TsteadyVsteady = Function(ME)
Tsteady, Vsteady = split(TsteadyVsteady)
rho_steady = project(float(rho_interpolated(T_ref)),V)
rho_thin_film = project(5.0e-3,V)
TsteadyVsteady_init=Expression((T_ref,'0.225'),degree=1)
TsteadyVsteady.interpolate(TsteadyVsteady_init)
J_injected = J_0
J_local = -(1.0/rho_steady)*grad(Vsteady)
J_thin_film = -(1.0/rho_thin_film)*grad(Vsteady)
convection_term_film = h_air_film * (Tsteady - T_ref) * usteady * dS(subdomain_id=10)
convection_term_wire = h_air_wire * (Tsteady - T_ref) * usteady * dS(subdomain_id=8)
Fourier_terms = -dot(kappa_wire * grad(Tsteady), grad(usteady)) * dx_wire - dot(kappa_thin_film * grad(Tsteady), grad(usteady)) * dx_thin_film  - dot(kappa_air * grad(Tsteady), grad(usteady)) * dx_air
Joule_term = dot(rho_steady*J_local, J_local) * usteady*dx_wire + dot(rho_thin_film*J_thin_film, J_thin_film) * usteady*dx_thin_film# Add Joule heat in thin film.
FsteadyT = Fourier_terms + Joule_term  + convection_term_wire + convection_term_film
FsteadyV = dot(1.0/rho_steady * grad(Vsteady), grad(vsteady))*dx_wire + J_injected * vsteady * ds(4) + dot(1.0/rho_thin_film * grad(Vsteady), grad(vsteady))*dx_thin_film
weak_form = FsteadyT + FsteadyV
Jacsteady = derivative(weak_form,TsteadyVsteady,dTsteadyVsteady)
V_left = Constant(0.0)
bc0 = DirichletBC(ME.sub(0), T_ref, boundary_parts, 11)
bc1 = DirichletBC(ME.sub(1), V_left, boundary_parts, 4)
bc_air = DirichletBC(ME.sub(0), T_ref, boundary_parts, 12)
#bc_air_2 = DirichletBC(ME.sub(0), T_ref, boundary_parts, 13)
#bc_air_3 = DirichletBC(ME.sub(0), T_ref, boundary_parts, 14)
#bc_air_4 = DirichletBC(ME.sub(0), T_ref, boundary_parts, 15)
#bc_air_5 = DirichletBC(ME.sub(0), T_ref, boundary_parts, 16)
bcs = [bc0, bc1, bc_air]
solver.solve()
Thank you very much.
Searching the forum / google for the error message, you’ll find that it relates to specifying which side of an interface should be evaluated, if you want to integrate a double-valued function.
In your case, I assume it goes wrong in the lines
which probably should look something like:
convection_term_film = h_air_film * (Tsteady("+") - T_ref) * usteady("+") * dS(subdomain_id=10)
convection_term_wire = h_air_wire * (Tsteady("-") - T_ref) * usteady("-") * dS(subdomain_id=8)
I’m sure that’s not entirely correct yet, but it may give you a handle on figuring out exactly how to fix your formulation.
Thank you for your reply!
I change the code and it works, but there is a problem that the computation does not converge. I think the boundary conditions are still wrong. The error message is as follows:
  File "/mnt/write_air.py", line 157, in <module>
    solver.solve()
RuntimeError:
*** Error:   Unable to solve nonlinear system with NewtonSolver.
*** Reason:  Newton solver did not converge because maximum number of iterations reached.
*** Where:   This error was encountered inside NewtonSolver.cpp.
*** Process: 0
*** Git changeset:  unknown
