Thank you for your prompt response! Here are all my unfinished codes and grid files.
mesh = Mesh('test.xml')
boundary = MeshFunction("size_t", mesh, "test_facet_region.xml")
subdomains = MeshFunction("size_t", mesh, "test_physical_region.xml")
VT = FunctionSpace(mesh, "CG", 1)
T_ = TestFunction(VT)
dT = TrialFunction(VT)
Delta_T = Function(VT, name="Temperature increase")
ds = Measure('ds', domain=mesh, subdomain_data=boundary)
dx = Measure('dx', domain=mesh, subdomain_data=subdomains)
lambda_m = 0.0214
aT = dot(lambda_m * grad(dT), grad(T_)) * dx(22)
LT = Constant(0) * T_ * dx(22)
bcT = [DirichletBC(VT, Constant(950.15), boundary, 20),
DirichletBC(VT, Constant(1000), boundary, 19)]
solve(aT == LT, Delta_T, bcT)
submesh_m_T = SubMesh(mesh, subdomains, 22)
VT_m = FunctionSpace(submesh_m_T, 'P', 1)
Delta_T_m = interpolate(Delta_T, VT_m)
Q = VectorFunctionSpace(mesh, 'P', 1)
w = TrialFunction(Q)
v = TestFunction(Q)
aQ = inner(w, v)*dx(22)
LQ = inner(-lambda_m*grad(Delta_T), v)*dx(22)
flux = Function(Q)
solve(aQ == LQ, flux)
I have created a simple grid example, here is the XML file:
test.xml:
<?xml version="1.0" encoding="UTF-8"?>
<dolfin xmlns:dolfin="http://www.fenicsproject.org">
<mesh celltype="triangle" dim="2">
<vertices size="84">
<vertex index="0" x="-1.0000000000000000e+00" y="0.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="1" x="0.0000000000000000e+00" y="1.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="2" x="1.0000000000000000e+00" y="0.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="3" x="0.0000000000000000e+00" y="-1.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="4" x="-2.0000000000000000e+00" y="0.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="5" x="0.0000000000000000e+00" y="2.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="6" x="2.0000000000000000e+00" y="0.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="7" x="0.0000000000000000e+00" y="-2.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="8" x="-3.0000000000000000e+00" y="0.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="9" x="0.0000000000000000e+00" y="3.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="10" x="3.0000000000000000e+00" y="0.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="11" x="0.0000000000000000e+00" y="-3.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="12" x="-4.0000000000000000e+00" y="0.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="13" x="0.0000000000000000e+00" y="4.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="14" x="4.0000000000000000e+00" y="0.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="15" x="0.0000000000000000e+00" y="-4.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="16" x="-7.0710678118654768e-01" y="7.0710678118654746e-01" z="0.0000000000000000e+00"/>
<vertex index="17" x="7.0710678118654735e-01" y="7.0710678118654768e-01" z="0.0000000000000000e+00"/>
<vertex index="18" x="7.0710678118654757e-01" y="-7.0710678118654746e-01" z="0.0000000000000000e+00"/>
<vertex index="19" x="-7.0710678118654746e-01" y="-7.0710678118654757e-01" z="0.0000000000000000e+00"/>
<vertex index="20" x="-1.8477590650225739e+00" y="7.6536686473017934e-01" z="0.0000000000000000e+00"/>
<vertex index="21" x="-1.4142135623730949e+00" y="1.4142135623730949e+00" z="0.0000000000000000e+00"/>
<vertex index="22" x="-7.6536686473018067e-01" y="1.8477590650225730e+00" z="0.0000000000000000e+00"/>
<vertex index="23" x="7.6536686473018001e-01" y="1.8477590650225730e+00" z="0.0000000000000000e+00"/>
<vertex index="24" x="1.4142135623730949e+00" y="1.4142135623730949e+00" z="0.0000000000000000e+00"/>
<vertex index="25" x="1.8477590650225730e+00" y="7.6536686473018078e-01" z="0.0000000000000000e+00"/>
<vertex index="26" x="1.8477590650225730e+00" y="-7.6536686473017956e-01" z="0.0000000000000000e+00"/>
<vertex index="27" x="1.4142135623730949e+00" y="-1.4142135623730949e+00" z="0.0000000000000000e+00"/>
<vertex index="28" x="7.6536686473017967e-01" y="-1.8477590650225730e+00" z="0.0000000000000000e+00"/>
<vertex index="29" x="-7.6536686473017945e-01" y="-1.8477590650225730e+00" z="0.0000000000000000e+00"/>
<vertex index="30" x="-1.4142135623730949e+00" y="-1.4142135623730949e+00" z="0.0000000000000000e+00"/>
<vertex index="31" x="-1.8477590650225730e+00" y="-7.6536686473017979e-01" z="0.0000000000000000e+00"/>
<vertex index="32" x="-2.8531695488854609e+00" y="9.2705098312484191e-01" z="0.0000000000000000e+00"/>
<vertex index="33" x="-2.4270509831248428e+00" y="1.7633557568774190e+00" z="0.0000000000000000e+00"/>
<vertex index="34" x="-1.7633557568774201e+00" y="2.4270509831248419e+00" z="0.0000000000000000e+00"/>
<vertex index="35" x="-9.2705098312484269e-01" y="2.8531695488854600e+00" z="0.0000000000000000e+00"/>
<vertex index="36" x="9.2705098312484169e-01" y="2.8531695488854609e+00" z="0.0000000000000000e+00"/>
<vertex index="37" x="1.7633557568774190e+00" y="2.4270509831248428e+00" z="0.0000000000000000e+00"/>
<vertex index="38" x="2.4270509831248419e+00" y="1.7633557568774201e+00" z="0.0000000000000000e+00"/>
<vertex index="39" x="2.8531695488854600e+00" y="9.2705098312484302e-01" z="0.0000000000000000e+00"/>
<vertex index="40" x="2.8531695488854600e+00" y="-9.2705098312484324e-01" z="0.0000000000000000e+00"/>
<vertex index="41" x="2.4270509831248410e+00" y="-1.7633557568774210e+00" z="0.0000000000000000e+00"/>
<vertex index="42" x="1.7633557568774181e+00" y="-2.4270509831248441e+00" z="0.0000000000000000e+00"/>
<vertex index="43" x="9.2705098312483991e-01" y="-2.8531695488854618e+00" z="0.0000000000000000e+00"/>
<vertex index="44" x="-9.2705098312484269e-01" y="-2.8531695488854600e+00" z="0.0000000000000000e+00"/>
<vertex index="45" x="-1.7633557568774210e+00" y="-2.4270509831248410e+00" z="0.0000000000000000e+00"/>
<vertex index="46" x="-2.4270509831248428e+00" y="-1.7633557568774181e+00" z="0.0000000000000000e+00"/>
<vertex index="47" x="-2.8531695488854618e+00" y="-9.2705098312484002e-01" z="0.0000000000000000e+00"/>
<vertex index="48" x="-3.8997116487272940e+00" y="8.9008373582525713e-01" z="0.0000000000000000e+00"/>
<vertex index="49" x="-3.6038754716096770e+00" y="1.7355349564702320e+00" z="0.0000000000000000e+00"/>
<vertex index="50" x="-3.1273259298721201e+00" y="2.4939592074349330e+00" z="0.0000000000000000e+00"/>
<vertex index="51" x="-2.4939592074349348e+00" y="3.1273259298721192e+00" z="0.0000000000000000e+00"/>
<vertex index="52" x="-1.7355349564702329e+00" y="3.6038754716096761e+00" z="0.0000000000000000e+00"/>
<vertex index="53" x="-8.9008373582525835e-01" y="3.8997116487272940e+00" z="0.0000000000000000e+00"/>
<vertex index="54" x="8.9008373582525691e-01" y="3.8997116487272940e+00" z="0.0000000000000000e+00"/>
<vertex index="55" x="1.7355349564702320e+00" y="3.6038754716096770e+00" z="0.0000000000000000e+00"/>
<vertex index="56" x="2.4939592074349330e+00" y="3.1273259298721201e+00" z="0.0000000000000000e+00"/>
<vertex index="57" x="3.1273259298721192e+00" y="2.4939592074349348e+00" z="0.0000000000000000e+00"/>
<vertex index="58" x="3.6038754716096761e+00" y="1.7355349564702329e+00" z="0.0000000000000000e+00"/>
<vertex index="59" x="3.8997116487272940e+00" y="8.9008373582525857e-01" z="0.0000000000000000e+00"/>
<vertex index="60" x="3.8997116487272940e+00" y="-8.9008373582525757e-01" z="0.0000000000000000e+00"/>
<vertex index="61" x="3.6038754716096770e+00" y="-1.7355349564702320e+00" z="0.0000000000000000e+00"/>
<vertex index="62" x="3.1273259298721192e+00" y="-2.4939592074349339e+00" z="0.0000000000000000e+00"/>
<vertex index="63" x="2.4939592074349339e+00" y="-3.1273259298721192e+00" z="0.0000000000000000e+00"/>
<vertex index="64" x="1.7355349564702329e+00" y="-3.6038754716096770e+00" z="0.0000000000000000e+00"/>
<vertex index="65" x="8.9008373582525779e-01" y="-3.8997116487272940e+00" z="0.0000000000000000e+00"/>
<vertex index="66" x="-8.9008373582525735e-01" y="-3.8997116487272940e+00" z="0.0000000000000000e+00"/>
<vertex index="67" x="-1.7355349564702320e+00" y="-3.6038754716096770e+00" z="0.0000000000000000e+00"/>
<vertex index="68" x="-2.4939592074349339e+00" y="-3.1273259298721201e+00" z="0.0000000000000000e+00"/>
<vertex index="69" x="-3.1273259298721192e+00" y="-2.4939592074349339e+00" z="0.0000000000000000e+00"/>
<vertex index="70" x="-3.6038754716096761e+00" y="-1.7355349564702329e+00" z="0.0000000000000000e+00"/>
<vertex index="71" x="-3.8997116487272940e+00" y="-8.9008373582525802e-01" z="0.0000000000000000e+00"/>
<vertex index="72" x="-5.4942547073534298e-01" y="1.3264304229624859e+00" z="0.0000000000000000e+00"/>
<vertex index="73" x="1.3264304229624859e+00" y="5.4942547073534276e-01" z="0.0000000000000000e+00"/>
<vertex index="74" x="-1.3264304229624859e+00" y="5.4942547073534231e-01" z="0.0000000000000000e+00"/>
<vertex index="75" x="5.4942547073534231e-01" y="1.3264304229624859e+00" z="0.0000000000000000e+00"/>
<vertex index="76" x="-1.3264304229624859e+00" y="-5.4942547073534265e-01" z="0.0000000000000000e+00"/>
<vertex index="77" x="1.3264304229624859e+00" y="-5.4942547073534231e-01" z="0.0000000000000000e+00"/>
<vertex index="78" x="5.4942547073534265e-01" y="-1.3264304229624859e+00" z="0.0000000000000000e+00"/>
<vertex index="79" x="-5.4942547073534254e-01" y="-1.3264304229624859e+00" z="0.0000000000000000e+00"/>
<vertex index="80" x="-2.4460499275078971e+00" y="2.4460499275078962e+00" z="0.0000000000000000e+00"/>
<vertex index="81" x="2.4460499275078962e+00" y="2.4460499275078971e+00" z="0.0000000000000000e+00"/>
<vertex index="82" x="2.4460499275078962e+00" y="-2.4460499275078962e+00" z="0.0000000000000000e+00"/>
<vertex index="83" x="-2.4460499275078962e+00" y="-2.4460499275078971e+00" z="0.0000000000000000e+00"/>
</vertices>
<cells size="96">
<triangle index="0" v0="24" v1="73" v2="17"/>
<triangle index="1" v0="21" v1="72" v2="16"/>
<triangle index="2" v0="16" v1="74" v2="21"/>
<triangle index="3" v0="17" v1="75" v2="24"/>
<triangle index="4" v0="4" v1="74" v2="0"/>
<triangle index="5" v0="0" v1="76" v2="4"/>
<triangle index="6" v0="2" v1="73" v2="6"/>
<triangle index="7" v0="1" v1="72" v2="5"/>
<triangle index="8" v0="18" v1="77" v2="27"/>
<triangle index="9" v0="5" v1="75" v2="1"/>
<triangle index="10" v0="6" v1="77" v2="2"/>
<triangle index="11" v0="3" v1="78" v2="7"/>
<triangle index="12" v0="7" v1="79" v2="3"/>
<triangle index="13" v0="27" v1="78" v2="18"/>
<triangle index="14" v0="30" v1="76" v2="19"/>
<triangle index="15" v0="19" v1="79" v2="30"/>
<triangle index="16" v0="6" v1="73" v2="25"/>
<triangle index="17" v0="5" v1="72" v2="22"/>
<triangle index="18" v0="22" v1="72" v2="21"/>
<triangle index="19" v0="20" v1="74" v2="4"/>
<triangle index="20" v0="4" v1="76" v2="31"/>
<triangle index="21" v0="7" v1="78" v2="28"/>
<triangle index="22" v0="25" v1="73" v2="24"/>
<triangle index="23" v0="23" v1="75" v2="5"/>
<triangle index="24" v0="24" v1="75" v2="23"/>
<triangle index="25" v0="27" v1="77" v2="26"/>
<triangle index="26" v0="26" v1="77" v2="6"/>
<triangle index="27" v0="21" v1="74" v2="20"/>
<triangle index="28" v0="29" v1="79" v2="7"/>
<triangle index="29" v0="28" v1="78" v2="27"/>
<triangle index="30" v0="31" v1="76" v2="30"/>
<triangle index="31" v0="30" v1="79" v2="29"/>
<triangle index="32" v0="16" v1="72" v2="1"/>
<triangle index="33" v0="17" v1="73" v2="2"/>
<triangle index="34" v0="18" v1="78" v2="3"/>
<triangle index="35" v0="3" v1="79" v2="19"/>
<triangle index="36" v0="19" v1="76" v2="0"/>
<triangle index="37" v0="1" v1="75" v2="17"/>
<triangle index="38" v0="0" v1="74" v2="16"/>
<triangle index="39" v0="2" v1="77" v2="18"/>
<triangle index="40" v0="65" v1="15" v2="11"/>
<triangle index="41" v0="11" v1="15" v2="66"/>
<triangle index="42" v0="8" v1="71" v2="12"/>
<triangle index="43" v0="8" v1="12" v2="48"/>
<triangle index="44" v0="13" v1="9" v2="53"/>
<triangle index="45" v0="54" v1="9" v2="13"/>
<triangle index="46" v0="59" v1="14" v2="10"/>
<triangle index="47" v0="10" v1="14" v2="60"/>
<triangle index="48" v0="8" v1="47" v2="71"/>
<triangle index="49" v0="11" v1="43" v2="65"/>
<triangle index="50" v0="66" v1="44" v2="11"/>
<triangle index="51" v0="54" v1="36" v2="9"/>
<triangle index="52" v0="48" v1="32" v2="8"/>
<triangle index="53" v0="40" v1="10" v2="60"/>
<triangle index="54" v0="9" v1="35" v2="53"/>
<triangle index="55" v0="59" v1="10" v2="39"/>
<triangle index="56" v0="70" v1="47" v2="46"/>
<triangle index="57" v0="64" v1="43" v2="42"/>
<triangle index="58" v0="39" v1="38" v2="58"/>
<triangle index="59" v0="67" v1="45" v2="44"/>
<triangle index="60" v0="33" v1="32" v2="49"/>
<triangle index="61" v0="35" v1="34" v2="52"/>
<triangle index="62" v0="37" v1="36" v2="55"/>
<triangle index="63" v0="61" v1="41" v2="40"/>
<triangle index="64" v0="68" v1="45" v2="67"/>
<triangle index="65" v0="58" v1="38" v2="57"/>
<triangle index="66" v0="52" v1="34" v2="51"/>
<triangle index="67" v0="62" v1="41" v2="61"/>
<triangle index="68" v0="50" v1="33" v2="49"/>
<triangle index="69" v0="56" v1="37" v2="55"/>
<triangle index="70" v0="64" v1="42" v2="63"/>
<triangle index="71" v0="70" v1="46" v2="69"/>
<triangle index="72" v0="65" v1="43" v2="64"/>
<triangle index="73" v0="71" v1="47" v2="70"/>
<triangle index="74" v0="49" v1="32" v2="48"/>
<triangle index="75" v0="53" v1="35" v2="52"/>
<triangle index="76" v0="55" v1="36" v2="54"/>
<triangle index="77" v0="61" v1="40" v2="60"/>
<triangle index="78" v0="67" v1="44" v2="66"/>
<triangle index="79" v0="59" v1="39" v2="58"/>
<triangle index="80" v0="56" v1="81" v2="37"/>
<triangle index="81" v0="38" v1="81" v2="57"/>
<triangle index="82" v0="34" v1="80" v2="51"/>
<triangle index="83" v0="46" v1="83" v2="69"/>
<triangle index="84" v0="68" v1="83" v2="45"/>
<triangle index="85" v0="62" v1="82" v2="41"/>
<triangle index="86" v0="42" v1="82" v2="63"/>
<triangle index="87" v0="50" v1="80" v2="33"/>
<triangle index="88" v0="33" v1="80" v2="34"/>
<triangle index="89" v0="37" v1="81" v2="38"/>
<triangle index="90" v0="41" v1="82" v2="42"/>
<triangle index="91" v0="45" v1="83" v2="46"/>
<triangle index="92" v0="51" v1="80" v2="50"/>
<triangle index="93" v0="69" v1="83" v2="68"/>
<triangle index="94" v0="57" v1="81" v2="56"/>
<triangle index="95" v0="63" v1="82" v2="62"/>
</cells>
</mesh>
</dolfin>
test_facet_region.xml:
<dolfin xmlns:dolfin="http://fenicsproject.org">
<mesh_function type="uint" dim="1" size="180">
<entity index="0" value="0"/>
<entity index="1" value="17"/>
<entity index="2" value="17"/>
<entity index="3" value="0"/>
<entity index="4" value="0"/>
<entity index="5" value="0"/>
<entity index="6" value="17"/>
<entity index="7" value="17"/>
<entity index="8" value="0"/>
<entity index="9" value="0"/>
<entity index="10" value="0"/>
<entity index="11" value="17"/>
<entity index="12" value="17"/>
<entity index="13" value="0"/>
<entity index="14" value="0"/>
<entity index="15" value="0"/>
<entity index="16" value="17"/>
<entity index="17" value="17"/>
<entity index="18" value="0"/>
<entity index="19" value="0"/>
<entity index="20" value="18"/>
<entity index="21" value="18"/>
<entity index="22" value="0"/>
<entity index="23" value="0"/>
<entity index="24" value="18"/>
<entity index="25" value="18"/>
<entity index="26" value="0"/>
<entity index="27" value="0"/>
<entity index="28" value="18"/>
<entity index="29" value="18"/>
<entity index="30" value="0"/>
<entity index="31" value="0"/>
<entity index="32" value="18"/>
<entity index="33" value="18"/>
<entity index="34" value="0"/>
<entity index="35" value="0"/>
<entity index="36" value="0"/>
<entity index="37" value="19"/>
<entity index="38" value="19"/>
<entity index="39" value="0"/>
<entity index="40" value="0"/>
<entity index="41" value="0"/>
<entity index="42" value="19"/>
<entity index="43" value="19"/>
<entity index="44" value="0"/>
<entity index="45" value="0"/>
<entity index="46" value="0"/>
<entity index="47" value="19"/>
<entity index="48" value="19"/>
<entity index="49" value="0"/>
<entity index="50" value="0"/>
<entity index="51" value="0"/>
<entity index="52" value="19"/>
<entity index="53" value="19"/>
<entity index="54" value="0"/>
<entity index="55" value="0"/>
<entity index="56" value="20"/>
<entity index="57" value="20"/>
<entity index="58" value="20"/>
<entity index="59" value="20"/>
<entity index="60" value="20"/>
<entity index="61" value="20"/>
<entity index="62" value="20"/>
<entity index="63" value="20"/>
<entity index="64" value="0"/>
<entity index="65" value="0"/>
<entity index="66" value="0"/>
<entity index="67" value="0"/>
<entity index="68" value="0"/>
<entity index="69" value="0"/>
<entity index="70" value="0"/>
<entity index="71" value="0"/>
<entity index="72" value="0"/>
<entity index="73" value="0"/>
<entity index="74" value="0"/>
<entity index="75" value="0"/>
<entity index="76" value="18"/>
<entity index="77" value="0"/>
<entity index="78" value="18"/>
<entity index="79" value="0"/>
<entity index="80" value="0"/>
<entity index="81" value="0"/>
<entity index="82" value="18"/>
<entity index="83" value="0"/>
<entity index="84" value="18"/>
<entity index="85" value="0"/>
<entity index="86" value="0"/>
<entity index="87" value="0"/>
<entity index="88" value="18"/>
<entity index="89" value="0"/>
<entity index="90" value="18"/>
<entity index="91" value="0"/>
<entity index="92" value="0"/>
<entity index="93" value="0"/>
<entity index="94" value="18"/>
<entity index="95" value="0"/>
<entity index="96" value="18"/>
<entity index="97" value="0"/>
<entity index="98" value="0"/>
<entity index="99" value="0"/>
<entity index="100" value="19"/>
<entity index="101" value="0"/>
<entity index="102" value="0"/>
<entity index="103" value="19"/>
<entity index="104" value="0"/>
<entity index="105" value="0"/>
<entity index="106" value="0"/>
<entity index="107" value="19"/>
<entity index="108" value="0"/>
<entity index="109" value="0"/>
<entity index="110" value="0"/>
<entity index="111" value="0"/>
<entity index="112" value="0"/>
<entity index="113" value="19"/>
<entity index="114" value="0"/>
<entity index="115" value="0"/>
<entity index="116" value="19"/>
<entity index="117" value="0"/>
<entity index="118" value="0"/>
<entity index="119" value="0"/>
<entity index="120" value="19"/>
<entity index="121" value="0"/>
<entity index="122" value="0"/>
<entity index="123" value="0"/>
<entity index="124" value="0"/>
<entity index="125" value="0"/>
<entity index="126" value="19"/>
<entity index="127" value="0"/>
<entity index="128" value="0"/>
<entity index="129" value="19"/>
<entity index="130" value="0"/>
<entity index="131" value="0"/>
<entity index="132" value="0"/>
<entity index="133" value="19"/>
<entity index="134" value="0"/>
<entity index="135" value="0"/>
<entity index="136" value="0"/>
<entity index="137" value="0"/>
<entity index="138" value="0"/>
<entity index="139" value="19"/>
<entity index="140" value="0"/>
<entity index="141" value="0"/>
<entity index="142" value="19"/>
<entity index="143" value="0"/>
<entity index="144" value="0"/>
<entity index="145" value="0"/>
<entity index="146" value="19"/>
<entity index="147" value="0"/>
<entity index="148" value="0"/>
<entity index="149" value="0"/>
<entity index="150" value="0"/>
<entity index="151" value="0"/>
<entity index="152" value="20"/>
<entity index="153" value="20"/>
<entity index="154" value="20"/>
<entity index="155" value="0"/>
<entity index="156" value="20"/>
<entity index="157" value="0"/>
<entity index="158" value="20"/>
<entity index="159" value="20"/>
<entity index="160" value="20"/>
<entity index="161" value="20"/>
<entity index="162" value="0"/>
<entity index="163" value="20"/>
<entity index="164" value="0"/>
<entity index="165" value="20"/>
<entity index="166" value="20"/>
<entity index="167" value="20"/>
<entity index="168" value="20"/>
<entity index="169" value="0"/>
<entity index="170" value="20"/>
<entity index="171" value="0"/>
<entity index="172" value="20"/>
<entity index="173" value="20"/>
<entity index="174" value="20"/>
<entity index="175" value="20"/>
<entity index="176" value="0"/>
<entity index="177" value="20"/>
<entity index="178" value="0"/>
<entity index="179" value="20"/>
</mesh_function>
</dolfin>
test_physical_region.xml:
<mesh_function type="uint" dim="2" size="96">
<entity index="0" value="21"/>
<entity index="1" value="21"/>
<entity index="2" value="21"/>
<entity index="3" value="21"/>
<entity index="4" value="21"/>
<entity index="5" value="21"/>
<entity index="6" value="21"/>
<entity index="7" value="21"/>
<entity index="8" value="21"/>
<entity index="9" value="21"/>
<entity index="10" value="21"/>
<entity index="11" value="21"/>
<entity index="12" value="21"/>
<entity index="13" value="21"/>
<entity index="14" value="21"/>
<entity index="15" value="21"/>
<entity index="16" value="21"/>
<entity index="17" value="21"/>
<entity index="18" value="21"/>
<entity index="19" value="21"/>
<entity index="20" value="21"/>
<entity index="21" value="21"/>
<entity index="22" value="21"/>
<entity index="23" value="21"/>
<entity index="24" value="21"/>
<entity index="25" value="21"/>
<entity index="26" value="21"/>
<entity index="27" value="21"/>
<entity index="28" value="21"/>
<entity index="29" value="21"/>
<entity index="30" value="21"/>
<entity index="31" value="21"/>
<entity index="32" value="21"/>
<entity index="33" value="21"/>
<entity index="34" value="21"/>
<entity index="35" value="21"/>
<entity index="36" value="21"/>
<entity index="37" value="21"/>
<entity index="38" value="21"/>
<entity index="39" value="21"/>
<entity index="40" value="22"/>
<entity index="41" value="22"/>
<entity index="42" value="22"/>
<entity index="43" value="22"/>
<entity index="44" value="22"/>
<entity index="45" value="22"/>
<entity index="46" value="22"/>
<entity index="47" value="22"/>
<entity index="48" value="22"/>
<entity index="49" value="22"/>
<entity index="50" value="22"/>
<entity index="51" value="22"/>
<entity index="52" value="22"/>
<entity index="53" value="22"/>
<entity index="54" value="22"/>
<entity index="55" value="22"/>
<entity index="56" value="22"/>
<entity index="57" value="22"/>
<entity index="58" value="22"/>
<entity index="59" value="22"/>
<entity index="60" value="22"/>
<entity index="61" value="22"/>
<entity index="62" value="22"/>
<entity index="63" value="22"/>
<entity index="64" value="22"/>
<entity index="65" value="22"/>
<entity index="66" value="22"/>
<entity index="67" value="22"/>
<entity index="68" value="22"/>
<entity index="69" value="22"/>
<entity index="70" value="22"/>
<entity index="71" value="22"/>
<entity index="72" value="22"/>
<entity index="73" value="22"/>
<entity index="74" value="22"/>
<entity index="75" value="22"/>
<entity index="76" value="22"/>
<entity index="77" value="22"/>
<entity index="78" value="22"/>
<entity index="79" value="22"/>
<entity index="80" value="22"/>
<entity index="81" value="22"/>
<entity index="82" value="22"/>
<entity index="83" value="22"/>
<entity index="84" value="22"/>
<entity index="85" value="22"/>
<entity index="86" value="22"/>
<entity index="87" value="22"/>
<entity index="88" value="22"/>
<entity index="89" value="22"/>
<entity index="90" value="22"/>
<entity index="91" value="22"/>
<entity index="92" value="22"/>
<entity index="93" value="22"/>
<entity index="94" value="22"/>
<entity index="95" value="22"/>
</mesh_function>
</dolfin>
I have already solved the temperature field and heat flux field for the external annulus. Now the problem is to utilize the known gap heat transfer coefficient (h), the flux (q) on the inner boundary of the external annulus, and the temperature (T2) to obtain the temperature distribution (T1) on the outer boundary of the internal annulus (q=h(T1-T2)), and to use it as the Dirichlet boundary condition for solving the internal annulus. Do you have any other suggestions?
