A problem about the function near()
Hello, everyone;
I am trying to write code for Circular cylinder. Thear are two ways to set boundary conditions.
This is my code:
#create mesh
domain1 = Rectangle(Point(0.0, 0.0), Point(10.0, 1.0))
domain2 = Circle(Point(0.5, 0.5), 0.25)
mesh = generate_mesh(domain1 - domain2, 100)
x = SpatialCoordinate(mesh)
#plot(mesh)
#define boundary
class Right(SubDomain):
        return on_boundary and near(x[0], 10.0)
class Left(SubDomain):
        return on_boundary and near(x[0], 0.0)
class Bottom(SubDomain):
        return on_boundary and near(x[1], 0.0)
class Top(SubDomain):
        return on_boundary and near(x[1], 1.0)
class Internal_Boundary(SubDomain):
        return on_boundary and near((x[0]-0.5)**2 + (x[1]-0.5)**2-0.25**2, 0)
        #return on_boundary and x[0]>0.2 and x[0]<0.8 and x[1]>0.2 and x[1] <0.8
bottom = Bottom()
top = Top()
left = Left()
right = Right()
internal_boundary = Internal_Boundary()
#boundary marks
bmf = MeshFunction("size_t", mesh, mesh.topology().dim()-1, 0)
bmf.set_all(0)
bottom.mark(bmf, 1)
right.mark(bmf, 2)
top.mark(bmf, 3)
left.mark(bmf, 4)
internal_boundary.mark(bmf, 5)
ds = Measure("ds", domain= mesh, subdomain_data= bmf)
print(assemble(1*ds(5)))
In this code,
I want to use
or
to define the internal cricle boundary, but why the first seem to be true (Boundary Integral is pi/2) and the second way seem to be false(Boundary Integral is 0.).
Thanks!
This is because your mesh is very coarse, and thus the accuracy of the circle is reduced. Increasing the tolerance in near solves the problem:
#create mesh
        return near((x[0]-0.5)**2 + (x[1]-0.5)**2, 0.25**2, 1e-2) and on_boundary
#boundary marks
bmf = MeshFunction("size_t", mesh, mesh.topology().dim()-1)
File("mesh.pvd")<< bmf
