Hi, I wrote a program to solve the flow problem around a cylinder using Newton method. It works but does not converge. Hope to receive help, thanks.
My code:
T = 2.0 # final time
num_steps = 2000 # number of time steps
mu = 0.0001 # dynamic viscosity
rho = 1 # density
Re=100 # reynold number
# Create mesh
channel = Rectangle(Point(0, 0), Point(2.2, 0.41))
cylinder = Circle(Point(0.2, 0.2), 0.05)
domain = channel - cylinder
mesh = generate_mesh(domain, 64)
# Define function spaces
Q = FunctionSpace(mesh, 'P', 1)
elem01 = MixedElement([V.ufl_element(), Q.ufl_element()])
W = FunctionSpace(mesh, elem01)
# Define boundaries
inflow = 'near(x[0], 0)'
outflow = 'near(x[0], 2.2)'
walls = 'near(x[1], 0) || near(x[1], 0.41)'
cylinder = 'on_boundary && x[0]>0.15 && x[0]<0.25 && x[1]>0.15 && x[1]<0.25'
# Define inflow profile
inflow_profile = ('4.0*1.5*x[1]*(0.41 - x[1]) / pow(0.41, 2)', '0')
# Define boundary conditions
bcu_inflow = DirichletBC(W.sub(0), Expression(inflow_profile, degree=2), inflow)
bcu_walls = DirichletBC(W.sub(0), Constant((0, 0)), walls)
bcu_cylinder = DirichletBC(W.sub(0), Constant((0, 0)), cylinder)
bcp_outflow = DirichletBC(W.sub(1), Constant(0), outflow)
bcp= [bcu_inflow, bcu_walls, bcu_cylinder]
bcu = [bcp_outflow]
bcs = [bcu_inflow, bcu_walls, bcu_cylinder, bcp_outflow]
dw = TrialFunction(W)
v, q = TestFunctions(W)
w = Function(W)
w_n = Function(W)
w_fem = Function(W)
du, dp = split(dw)
u, p = split(w)
u_n, p_n = split(w_n)
u_fem, p_fem = split(w_fem)
class InitialCondition(UserExpression):
def eval(self, values, x):
if near(x[0], 0):
values[0] = 4.0 * 1.5 * x[1] * (0.41 - x[1]) / pow(0.41, 2) # u
values[1] = 0 # v
values[0] = 0 # u
values[1] = 0 # v
values[2] = 0
def value_shape(self):
return (3,)
initial_condition = InitialCondition(degree=2)
w_n.interpolate(initial_condition)
w.interpolate(initial_condition)
# Netwon solver
class NS(NonlinearProblem):
def __init__(self, a, L, bcs):
self.a = a
self.L = L
self.bcs = bcs
def F(self, b, x):
assemble(self.L, tensor=b)
for bc in self.bcs: #
bc.apply(b)
def J(self, A, x):
assemble(self.a, tensor=A)
bc.apply(A)
#weak form
L1 = Re * dot((u - u_n) / dt, v) * dx \
+ Re * dot(nabla_grad(u_n).T*u, v)*dx \
+ inner(nabla_grad(u), nabla_grad(v))*dx \
- p*div(v)*dx
L2 = div(u) * q * dx
L=L1+L2
a = derivative(L, w, dw)
problem = NS(a, L, bcs)
solver = NewtonSolver()
solver.parameters["linear_solver"] = "lu"
solver.parameters["convergence_criterion"] = "incremental"
solver.parameters["relative_tolerance"] = 1e-6
file = File("NS/output.pvd", "compressed")
# Time-stepping
t=0.0
for n in range(5000):
w_n.vector()[:] = w.vector()
solver.solve(problem, w.vector())
u, p = w.split()
if n % 1 == 0:
file << (u, t)
plot(u)
plt.draw()
plt.pause(0.02)
plt.clf()
