A wrong pressure in axisimetric venturi pipe
Hi everyone.
I am trying to simulate an imcompressible flow through an axisymmetric venturi tube.
I have implemented the equations in FeniCSx. When I solve the equations the velocity looks good but the pressure does not. if I demand 0 pressure at the outlet of the pipe, I get
If I change it to pressure 1 at the outlet of the pipe
On the other hand, the pressure should increase after convergence. I have tested for different numbers of reynolds and the behavior is the same.
Anyone has a idea?
This is my full code:
import pyvista
import math
from ufl import (FacetNormal, FiniteElement, Identity, Measure, TestFunction, TrialFunction, VectorElement,
                 as_vector,as_tensor, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym, MixedElement)
                               create_vector, create_matrix, set_bc)
from dolfinx.fem import (Constant, Function, FunctionSpace,
                         assemble_scalar, dirichletbc, form, locate_dofs_topological, set_bc)
from dolfinx.mesh import create_unit_square
from dolfinx import geometry
from dolfinx.io import gmshio
    #Mesh with GMsh
gdim = 2
mesh_comm = MPI.COMM_WORLD
model_rank = 0
    #Points
n_point = 50
n_point1 = int(4*n_point)
n_point2 = int(0.8*n_point)
n_point3 = int(n_point)
n_point4 = int(1.5*n_point)
n_point5 = int(10*n_point)
n_point_axis = n_point1 + n_point2 + n_point3 + n_point4 + n_point5
bump = 0.05
a = 2.0*(bump-1)/(n_point*1.0)+1
n_bump = int(math.log(bump,a))
c = 1e-1;
gmsh.model.geo.add_point(0, 0.025, 0, c,1)
gmsh.model.geo.add_point(0.225, 0.025, 0, c,2)
gmsh.model.geo.add_point(0.252, 0.02, 0, c,3)
gmsh.model.geo.add_point(0.292, 0.02, 0, c, 4)
gmsh.model.geo.add_point(0.3737, 0.025, 0, c, 5)
gmsh.model.geo.add_point(0.945, 0.025, 0, c, 6)
gmsh.model.geo.add_point(0.945, 0, 0, c, 7)
gmsh.model.geo.add_point(0, 0, 0, c,8)
gmsh.model.occ.synchronize()
    #Lines
gmsh.model.geo.addLine(1, 2 ,1)
gmsh.model.geo.addLine(2, 3, 2)
gmsh.model.geo.addLine(3, 4,3)
gmsh.model.geo.addLine(4, 5,4)
gmsh.model.geo.addLine(5, 6,5)
gmsh.model.geo.addLine(6, 7,6)
gmsh.model.geo.addLine(7, 8,7)
gmsh.model.geo.addLine(8, 1,8)
gmsh.model.geo.add_curve_loop([1, 2, 3, 4, 5, 6, 7, 8],1)
gmsh.model.geo.add_plane_surface([1],1)
gmsh.model.geo.synchronize()
gmsh.model.addPhysicalGroup(1, [8], name='inflow')
gmsh.model.addPhysicalGroup(1, [6], name = 'outflow')
gmsh.model.addPhysicalGroup(1, [1,2,3,4,5], name= 'walls')
gmsh.model.addPhysicalGroup(1, [7], name= 'axis')
gmsh.model.addPhysicalGroup(2, [1], 1)
gmsh.model.geo.mesh.setTransfiniteCurve(6, n_bump, "Progression", 1.05)
gmsh.model.geo.mesh.setTransfiniteCurve(8, n_bump, "Progression", -1.05)
gmsh.model.geo.mesh.setTransfiniteCurve(1, n_point1)
gmsh.model.geo.mesh.setTransfiniteCurve(2, n_point2)
gmsh.model.geo.mesh.setTransfiniteCurve(3, n_point3)
gmsh.model.geo.mesh.setTransfiniteCurve(4, n_point4)
gmsh.model.geo.mesh.setTransfiniteCurve(5, n_point5)
gmsh.model.geo.mesh.setTransfiniteCurve(7, n_point_axis-4)
gmsh.model.geo.mesh.setTransfiniteSurface(1, "Left", [1,6,7,8])
gmsh.model.geo.mesh.setRecombine(2, 1)
gmsh.model.mesh.generate(2)
domain, _, ft = gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=2)
ft.name = "Facet markers"
gmsh.finalize()
    # Definition of Spaces. (dim and polinomial type)
v_cg1 = VectorElement("CG", domain.ufl_cell(), 2)
s_cg1 = FiniteElement("CG", domain.ufl_cell(), 1)
V = dolfinx.fem.FunctionSpace(domain, v_cg1)
Q = dolfinx.fem.FunctionSpace(domain, s_cg1)
Z = MixedElement([v_cg1, s_cg1])
W = dolfinx.fem.FunctionSpace(domain, Z)
    # Boundary subdomains and coditions
    # Definition of subdomains
Re = 500
Lx  =0.945
def upstream(x):
    return np.isclose(x[0],0)
def downstream(x):
    return np.isclose(x[0],Lx)
def walls(x):
    a = np.greater(x[0],0)
    b = np.less(x[0],Lx)
    return np.logical_and(np.greater(x[1]**2, 0.0000001), np.logical_and(a,b))
def axis(x):
    return np.isclose(x[1],0)
fdim = domain.topology.dim -1
up_facets = dolfinx.mesh.locate_entities_boundary(domain, fdim, upstream)
down_facets = dolfinx.mesh.locate_entities_boundary(domain, fdim, downstream)
wall_facets = dolfinx.mesh.locate_entities_boundary(domain, fdim, walls)
axis_facets = dolfinx.mesh.locate_entities_boundary(domain, fdim, axis)
def u_exact(x):
    values = np.zeros((2, x.shape[1]), dtype=PETSc.ScalarType)
    values[0] = 1
    return values
def p_exact(x):
    values = np.zeros((1, x.shape[1]), dtype=PETSc.ScalarType)
    values[:] = 0
    return values
V1, _ = W.sub(0).collapse()
Q1, _ = W.sub(1).collapse()
u_icondition = Function(V1)
u_wallcondition = Function(V1)
p_icondition = Function(Q1)
u_icondition.interpolate(u_exact)
p_icondition.interpolate(p_exact)
up_f = dolfinx.fem.locate_dofs_topological((W.sub(0),V1), fdim, up_facets)
wall_f = dolfinx.fem.locate_dofs_topological((W.sub(0),V1), fdim, wall_facets)
down_f = dolfinx.fem.locate_dofs_topological((W.sub(1),Q1), fdim, down_facets)
boundaries = [(1,up_facets),(2,down_facets),(3,wall_facets), (4,axis_facets)]
for (marker, face ) in boundaries:
    facet_indices.append(face)
    facet_markers.append(np.full_like(face, marker))
facet_tag = dolfinx.mesh.meshtags(domain, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
domain.topology.create_connectivity(domain.topology.dim-1, domain.topology.dim)
    # Define ds measure
ds = Measure("ds", domain=domain, subdomain_data=facet_tag)
    # Solve Navier-Stokes equtions axis
n = FacetNormal(domain)
radius = Function(Q1)
radius.interpolate(lambda x: x[1])
    # Definiton of stress tensor in cylindrical coordinates
    return sym(as_tensor([[u[0].dx(0),0,u[0].dx(1)],
                        [0,u[1]/radius,0],
                        [u[1].dx(0),0,u[1].dx(1)]]))
# Define stress tensor
def sigma(u, p):
    return 2*mu*epsilon(u) - p*Identity(3)
bc_u = dirichletbc(u_icondition, up_f,W.sub(0))
bc_w = dirichletbc(u_wallcondition, wall_f,W.sub(0))
bc_p = dirichletbc(p_icondition, down_f,W.sub(1))
bc = [bc_u, bc_w, bc_p]
mu = Constant(domain, PETSc.ScalarType(1/Re))
    # Define variables
w = Function(W)
u, p = ufl.split(w)
wtest = TestFunction(W)
v,q = ufl.split(wtest)
f = Function(Q1)
  # rdrdz = dV in axisymmetric
a1 = dot(dot(u,nabla_grad(u)),v)*radius*dx + inner(sigma(u,p),epsilon(v))*radius*dx
a2 = dot(div(u)*radius + u[1],q)*dx
#a2 = dot(div(ua)-f,qa)*dx
a3 = dot(p*n,v)*ds(2) - mu*dot(dot(grad(u),n),v)*ds(2)
#+ dot(dot(u,n),q)*ds(4)
a0 = a1+a2+a3
problem_a = dolfinx.fem.petsc.NonlinearProblem(a0, w, bcs=bc)
solver_a = dolfinx.nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem_a)
#solver.convergence_criterion = "incremental"
solver_a.rtol = 1e-4
solver_a.report = True
dolfinx.log.set_log_level(dolfinx.log.LogLevel.INFO)
n_it, converged = solver_a.solve(w)
u,p = w.split()
with dolfinx.io.XDMFFile(domain.comm, "Plot_axis/u.xdmf", "w") as file:
    file.write_mesh(domain)
    file.write_function(u)
with dolfinx.io.XDMFFile(domain.comm, "Plot_axis/p.xdmf", "w") as file:
    file.write_function(p)
Thank you much!
