IPCS solver with time-dependent pressure bc
Dear FEniCSx-community,
I am trying to adapt this flow-past-cylinder-demo to have time-dependent inflow/outflow boundary conditions. I implemented the time-dependence by InletPressure() which has a sinusoidal pressure fluctuation through time. I simplified the demo code by using the unit-square mesh instead.
The boundary conditions (see Figure 1) and the initial pressure (Figure 2) seem to be correct.
The problem is that after just a few time steps, there is no steady flow between inlet and outlet but most of the mesh cells have 0 pressure (see Figure 3). Also the velocities don’t look like expected (see Figure 4).
Figure 1:
Figure 2 (initial pressure):
Figure 3 (pressure at time frame 10):
Figure 4 (velocities at time frame 10):
Code:
from dolfinx.cpp.mesh import locate_entities_boundary, CellType
from dolfinx.fem import (Constant, Function, FunctionSpace, dirichletbc, form, locate_dofs_topological)
from dolfinx.fem.petsc import (apply_lifting, assemble_matrix, assemble_vector, create_vector, create_matrix, set_bc)
from dolfinx.mesh import create_unit_square
from ufl import (FiniteElement, TestFunction, TrialFunction, VectorElement,
                 div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs)
mesh = create_unit_square(MPI.COMM_WORLD, 50, 50, CellType.triangle)
t = 0
T = 1  # Final time
dt = 1 / 600  # Time step size
num_steps = int(T / dt)
mu = Constant(mesh, PETSc.ScalarType(0.001))  # Dynamic viscosity
rho = Constant(mesh, PETSc.ScalarType(1))  # Density
v_cg2 = VectorElement("CG", mesh.ufl_cell(), 2)
s_cg1 = FiniteElement("CG", mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, v_cg2)
Q = FunctionSpace(mesh, s_cg1)
gdim = 2
fdim = mesh.topology.dim - 1
# Define boundary conditions
class InletPressure():
    def __init__(self, t):
        self.t = t
    def __call__(self, x):
        return np.full(x.shape[1], 2 + np.sin(self.t))
u_ = Function(V)
u_.name = "u"
u_s = Function(V)
u_n = Function(V)
u_n1 = Function(V)
p = TrialFunction(Q)
q = TestFunction(Q)
p_ = Function(Q)
p_.name = "p"
phi = Function(Q)
def inflow(x):
    return np.isclose(x[0], 0)
def outflow(x):
    return np.isclose(x[0], 1)
def walls(x):
    return np.logical_not(np.logical_or(inflow(x), outflow(x)))
# Walls
u_nonslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
facets = locate_entities_boundary(mesh, fdim, walls)
bcu_walls = dirichletbc(u_nonslip, locate_dofs_topological(V, fdim, facets), V)
bcu = [bcu_walls]
# Inlet
p_inlet = Function(Q)
inlet_pressure = InletPressure(t)
p_inlet.interpolate(inlet_pressure)
facets = locate_entities_boundary(mesh, fdim, inflow)
bcp_inflow = dirichletbc(p_inlet, locate_dofs_topological(Q, fdim, facets))
# Outlet
facets = locate_entities_boundary(mesh, fdim, outflow)
bcp_outlet = dirichletbc(PETSc.ScalarType(-2), locate_dofs_topological(Q, fdim, facets), Q)
bcp = [bcp_inflow, bcp_outlet]
u_ = Function(V)
u_.name = "u"
u_s = Function(V)
u_n = Function(V)
u_n1 = Function(V)
q = TestFunction(Q)
p_ = Function(Q)
p_.name = "p"
phi = Function(Q)
f = Constant(mesh, PETSc.ScalarType((0, 0)))
F1 = rho / k * dot(u - u_n, v) * dx
F1 += inner(dot(1.5 * u_n - 0.5 * u_n1, 0.5 * nabla_grad(u + u_n)), v) * dx
F1 += 0.5 * mu * inner(grad(u + u_n), grad(v)) * dx - dot(p_, div(v)) * dx
F1 += dot(f, v) * dx
a1 = form(lhs(F1))
L1 = form(rhs(F1))
A1 = create_matrix(a1)
b1 = create_vector(L1)
a2 = form(dot(grad(p), grad(q)) * dx)
L2 = form(-rho / k * dot(div(u_s), q) * dx)
A2.assemble()
b2 = create_vector(L2)
a3 = form(rho * dot(u, v) * dx)
L3 = form(rho * dot(u_s, v) * dx - k * dot(nabla_grad(phi), v) * dx)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
# Solver for step 1
solver1 = PETSc.KSP().create(mesh.comm)
solver1.setOperators(A1)
pc1 = solver1.getPC()
pc1.setType(PETSc.PC.Type.JACOBI)
# Solver for step 2
solver2 = PETSc.KSP().create(mesh.comm)
solver2.setOperators(A2)
solver2.setType(PETSc.KSP.Type.MINRES)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(mesh.comm)
solver3.setOperators(A3)
pc3 = solver3.getPC()
vtx_u = VTXWriter(mesh.comm, "dfg2D-3-u.bp", [u_])
vtx_p = VTXWriter(mesh.comm, "dfg2D-3-p.bp", [p_])
vtx_u.write(t)
vtx_p.write(t)
for i in range(num_steps):
    # Update current time step
    # Update inlet velocity
    inlet_pressure.t = t
    A1.zeroEntries()
    assemble_matrix(A1, a1, bcs=bcu)
    A1.assemble()
    with b1.localForm() as loc:
        loc.set(0)
    assemble_vector(b1, L1)
    set_bc(b1, bcu)
    solver1.solve(b1, u_s.vector)
    u_s.x.scatter_forward()
    with b2.localForm() as loc:
        loc.set(0)
    assemble_vector(b2, L2)
    set_bc(b2, bcp)
    solver2.solve(b2, phi.vector)
    phi.x.scatter_forward()
    p_.vector.axpy(1, phi.vector)
    p_.x.scatter_forward()
    with b3.localForm() as loc:
        loc.set(0)
    assemble_vector(b3, L3)
    solver3.solve(b3, u_.vector)
    u_.x.scatter_forward()
    # Write solutions to file
    vtx_u.write(t)
    vtx_p.write(t)
    with u_.vector.localForm() as loc_, u_n.vector.localForm() as loc_n, u_n1.vector.localForm() as loc_n1:
        loc_n.copy(loc_n1)
        loc_.copy(loc_n)
vtx_u.close()
vtx_p.close()
What could be the cause of that?
And I am I correct that this flow-past-cylinder-demo uses the IPCS solver and can be used for more complex meshes?
Many thanks in advance for your help.
Best regards,
Georg
I am facing a similar problem but also didn’t find a solution yet.
Using pressure conditions for the IPCS solver is not really well supported.
I’ve written out the mathematics of the splitting scheme at:
https://computationalphysiology.github.io/oasisx/splitting_schemes.html
highlighting issues with the boundary conditions known from literature (with references).
If you want to set DirichletBCs for the pressure condition, I would definitely not use the \phi -formulation of the pressure correction step, but solving it for p^(n+1) directly.
@dokken Many thanks for your help. I would also be happy with the basic Chorin method in FEniCSx exactly like in this old fenics example.. Are pressure conditions also not well supported for Chorin’s method? Since IPCS is a modified version of Chorin’s method I probably don’t have to change much but I struggle to transition this old example to FEniCSx.
If you use the p^(n+1)-p^n formulation of either Chorin or IPCS, you can apply the pressure condition (although it is not natural in the sense of boundary conditions).
In your code you are applying the pressure boundary condition to the \phi. This means that
p^n+1 = p^n + bcp on any boundary with a dirichletbc, which is not correct.
What you can do is to solve for \phi, with zero Dirichlet conditions on this boundary.
Then after calling
you could assign bcp to p_.vector using dolfinx.fem.petsc.set_bc(p_.vector, bcp).
Hello @dokken
I have some questions about my implementation
  1. How can I see if I implemented my boundary conditions for velocity and pressure correctly?. I used classes
  2. After finalizing my code, the plot doesn’t show. I commented out the line.
  3. How is implemented the initial condition in this test problem
  4. How can implemented a pow in my boundary condition in classes?
    #pyvista.start_xvfb()
because my kernel died. My code is and share the mesh here
import pyvista
from tqdm import tqdm
from dolfinx.cpp.mesh import Geometry_float32, Geometry_float64
from dolfinx.fem.petsc import assemble_matrix, create_vector, assemble_vector, apply_lifting
                         assemble_scalar, dirichletbc, form, locate_dofs_topological, set_bc, locate_dofs_geometrical)
from dolfinx.io import (VTXWriter, distribute_entity_data, gmshio, XDMFFile)
from ufl import (FacetNormal, FiniteElement, Identity, Measure, TestFunction, TrialFunction, VectorElement,
                 as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym)
mesh, cell_tags, facet_tags = gmshio.read_from_msh(
        "mesh_v1.msh", MPI.COMM_WORLD, 0, gdim=2)
if MPI.COMM_WORLD.rank == 0:
    gmsh.model.add("Mesh from file")
    gmsh.merge("mesh_v1.msh")
output = gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=2)
gmsh.finalize()
# Data values
rho_bc = 1.184
u_ref = 1.2
z_ref = 2
p0 = 101325
g = 9.81
t = 0
TIME_STEP_LENGTH = 0.01
SIMULATION_TIME = 1
N_TIME_STEPS = int(SIMULATION_TIME/TIME_STEP_LENGTH)
v_cg2 = VectorElement("Lagrange", mesh.ufl_cell(), 2)
s_cg1 = FiniteElement("Lagrange", mesh.ufl_cell(), 1)
q = TestFunction(Q)
class InletVelocity():
        values = np.zeros((2, x.shape[1]), dtype=PETSc.ScalarType)
        values[0] = u_ref * pow(x[1] / z_ref, 0.16)
        return values
        values = np.zeros((1, x.shape[1]), dtype=PETSc.ScalarType)
        values[0] = p0 - rho_bc * g * x[1]
        return values
# Inlet
features_in = facet_tags.find(1)
u_inlet = Function(V)
inlet_velocity = InletVelocity()
u_inlet.interpolate(inlet_velocity)
bcu_inflow = dirichletbc(u_inlet, locate_dofs_topological(V, 2, features_in))
inlet_pressure = InletPressure()
bcp_inflow = dirichletbc(p_inlet, locate_dofs_topological(Q, 1, features_in))
# Walls
features_bot = facet_tags.find(2)
u_noslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
bcu_noslip = dirichletbc(u_noslip, features_bot, V)
# Outlet
features_out = facet_tags.find(4)
bcp_outlet = dirichletbc(PETSc.ScalarType(0), features_out, Q)
# Boundary conditions
bcu = [bcu_inflow, bcu_noslip]
u_n = Function(V)
u_n.name = "u_n"
p_n = Function(Q)
p_n.name = "p_n"
dt = Constant(mesh, PETSc.ScalarType(TIME_STEP_LENGTH))
mu = Constant(mesh, PETSc.ScalarType(1.87 * 1e-5))  # Dynamic viscosity
rho = Constant(mesh, PETSc.ScalarType(1.184))  # Density
# Define the variational problem for the first step
F1 = rho * dot((u - u_n) / dt, v) * dx
F1 += rho * dot(dot(u_n, nabla_grad(u_n)), v) * dx
F1 += mu * inner(grad(u), grad(v)) * dx
F1 -= dot(f, v) * dx
a1 = form(lhs(F1))
L1 = form(rhs(F1))
A1 = assemble_matrix(a1, bcs=bcu)
A1.assemble()
u_ = Function(V)
a2 = form(dot(nabla_grad(p), nabla_grad(q)) * dx)
L2 = form(- (rho / dt) * div(u_) * q * dx)
A2.assemble()
p_ = Function(Q)
a3 = form(dot(u, v) * dx)
L3 = form(dot(u_, v) * dx - (dt / rho) * dot(nabla_grad(p_), v) * dx)
A3.assemble()
# Solver for step 1
pc1.setHYPREType("boomeramg")
from pathlib import Path
folder = Path("/home/gerard/Escritorio/FEniCSx/results")
folder.mkdir(exist_ok=True, parents=True)
vtx_u = VTXWriter(mesh.comm, folder / "poiseuille_u.bp", u_n, engine="BP4")
vtx_p = VTXWriter(mesh.comm, folder / "poiseuille_p.bp", p_n, engine="BP4")
vtx_u.write(t)
vtx_p.write(t)
# Solver for step 2
solver2.setType(PETSc.KSP.Type.BCGS)
# Solver for step 3
for i in tqdm(range(N_TIME_STEPS)):
    t += TIME_STEP_LENGTH
    # Step 1: Tentative veolcity step
    with b1.localForm() as loc_1:
        loc_1.set(0)
    set_bc(b1, bcu)
    solver1.solve(b1, u_.vector)
    # Step 2: Pressure corrrection step
    with b2.localForm() as loc_2:
        loc_2.set(0)
    set_bc(b2, bcp)
    solver2.solve(b2, p_.vector)
    with b3.localForm() as loc_3:
        loc_3.set(0)
    u_n.x.array[:] = u_.x.array[:]
    p_n.x.array[:] = p_.x.array[:]
# Close xmdf file
vtx_u.close()
vtx_p.close()
b1.destroy()
b2.destroy()
b3.destroy()
solver1.destroy()
solver2.destroy()
solver3.destroy()
# Visualization of vectors
topology, cell_types, geometry = vtk_mesh(V)
grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
plotter = pyvista.Plotter()
plotter.show()
values = np.zeros((geometry.shape[0], 3), dtype=np.float64)
values[:, :len(u_n)] = u_n.x.array.real.reshape((geometry.shape[0], len(u_n)))
# Create a point cloud of glyphs
function_grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
function_grid["u"] = values
glyphs = function_grid.glyph(orient="u", factor=0.2)
# Create a pyvista-grid for the mesh
grid = pyvista.UnstructuredGrid(*vtk_mesh(mesh, mesh.topology.dim))
# Create plotter
plotter.add_mesh(grid, style="wireframe", color="k")
plotter.add_mesh(glyphs)
plotter.view_xy()
if not pyvista.OFF_SCREEN:
    plotter.show()
    fig_as_array = plotter.screenshot("glyphs.png")
Thanks for your help.
I don’t have the bandwidth to go through this whole code.
Store the velocity and or pressure to file, for instance after applying the bc to a function in the V or Q space.
See for instance: Struggling with vector values bcdirichlet - #15 by dokken
which shows how to check them.
This depends on what system you are running DOLFINx on, and how you have installed dolfinx. Without further information it is hard to help.
I wouldn’t go for pressure conditions when it comes to splitting schemes. You can choose whatever method you might like (like setting it strongly after solving the pressure correciton step). It does mean that you are walking in uncharted territory (at least as far as I know) when it comes to guaranteed convergence of the scheme.
what do you mean with a pow?
