Hello, I recently upgraded dolfinx to version 0.7.2 and noticed that I could not use ‘UserExpression’ .If ‘UserExpression’ has been replaced, could you please guide me on the alternative method for importing 3D NumPy array data into a FunctionSpace? I appreciate your assistance in resolving this matter.
See for instance: UserExpression in dolfinx
Thanks for replying.I try to use the following code
msh = mesh.create_box(comm=MPI.COMM_WORLD, points=((-30.0, -30.0, -30.0), (30.0, 30.0, 30.0)), n=(Nx, Ny, Nz), cell_type=mesh.CellType.tetrahedron)
V = fem.functionspace(msh, ("Lagrange", 2))
class InterpolateFunction(Expression):
def __init__(self, data, **kwargs):
super().__init__(**kwargs)
self.data = data
def eval(self, values, x):
values[0] = self.interpolate_data(x)
def interpolate_data(self, x):
i, j, k = int((x[0] + 30) / 60 * Nx), int((x[1] + 30) / 60 * Ny), int((x[2] + 30) / 60 * Nz)
i = min(max(i, 0), Nx - 1)
j = min(max(j, 0), Ny - 1)
k = min(max(k, 0), Nz - 1)
return self.data[k, j, i]
f = Interpolate(InterpolateFunction(data=density), V)
But I meet some problems:
TypeError: Expression.__init__() missing 2 required positional arguments: 'e' and 'X'
May be using Expression is wrong?(I am a beginner
Did you actually look at the link the post I referenced you?
You do not need to use the expression class at all.
class InterpolateFunction():
def __init__(self, data):
self.data = data
def eval(self, x):
values = np.zeros(x.shape[1], dtype=np.float64)
for i, point in enumerate(x.T):
values[i] = self.interpolate_data(point)
func = InterpolateFunction(data=density)
f = fem.Function(V)
f.interpolate(func.eval, V)
As described in for instance: Form compilation — FEniCS Tutorial @ Sorbonne
def u_init(x, sigma=0.1, mu=0.3):
The input function x is a (3, number_of_points) numpy array, which is then
evaluated with the vectorized numpy functions for efficiency
return 1./(2 * np.pi * sigma)*np.exp(-0.5*((x[0]-mu)/sigma)**2)*np.exp(-0.5*((x[1]-mu)/sigma)**2)
u_n = dolfinx.fem.Function(V)
u_n.interpolate(u_init)
I am sorry to have discommoded you. It works. ![]()
