UserExpression in dolfinx
Hi all,
I am trying to implement a function that depends on the spatial position. I can do it in fenics using the following code:
mesh = UnitSquareMesh(16,16)
V = FunctionSpace(mesh,'CG',1)
p = Function(V)
t = 0
class InitialCondition(UserExpression):
    def eval_cell(self, value, x, ufc_cell):
        if x[0] <= 0.01:
            value[0] = 1.0
            value[0] = 0.0
p.interpolate(InitialCondition())
xdmf = XDMFFile('p.xdmf')
xdmf.write(p, t)
However, I am having problems when I try to rewrite this code in dolfinx, since UserExpression is not defined.
Is there any alternative function in dolfinx?
Thanks!
You can use lambda-functions, together with dolfinx.fem.locate_dofs_geoemtrical as shown in: Combining Dirichlet and Neumann conditions — FEniCSx tutorial
Thank you @dokken for the speedy reply.
I’m using that approach to impose boundary conditions. However, what I want to do is to impose an initial condition. Therefore, instead of using bc = DirichletBC() and then apply this bc to the linear algebra structures, I need to store the values of the initial condition in a vector, say p_n.
Is then possible to define such kind of initial conditions in dolfinx? (That is, initial conditions over part of the domain as defined in the previous code).
Thanks again!
Simply use interpolate
def initial_condition(x):
     return 1.0*(x[0]<0.01)
u.interpolate(initial_condition)
Thank you very much!
It works.
Thanks for your help @dokken. I have the same problem with assigning initial values to Function. The difference between my question and the one you answered is that I need the real geometric coordinates for another package to calculate some quantities I need for initial values. For example, in the following code:
from scipy.spatial import KDTree
mesh = BoxMesh(Point(0, 0, 0), Point(1, 1, 0.1), 10, 10, 1)
PF = VectorFunctionSpace(mesh, 'CG', 1, dim=5)
phi   = Function(PF, name='order parameters')           # Order parameters
points = np.random.rand(10,2)
tree = KDTree(points)
class InitialConditions(UserExpression):
    def eval(self, values, x):
        distance, grain_index = tree.query([x[0], x[1]])
        for i in range(5):
            values[i] = 0.0
        values[grain_index % 5] = 1.0*np.exp(-1.0*(distance/0.1)**2)
    def value_shape(self):
        return (5,)
phi.interpolate(InitialConditions())
xdmf.write(phi)
I am converting it from FEniCS to FEniCSx. Follow your strategy, I write the following code:
     distance, grain_index = tree.query(x[0], x[1])
     for i in range(num_phi):
          values[i] = 0.0
     values[grain_index % num_phi] = 1.0 * np.exp(-1.0*(distance/0.1)**2)
     return values
phi.interpolate(initial_condition)
However, I found that the parameter I transfer into the tree.query() function is not the geometric coordinates. Could you please tell me how I can get the node coordinates and transfer it into the tree.query() function?
I think the discussion here may help
You haven’t defined values in this code. Please also supply a minimal reproducible example
