Add a vector to a scalar - Forward Eular method
I apologize for my earlier untidy description. Here is a better version of my question
I’m trying to use Forward Eular method in solving the heat equation mentioned here
Then, the PDE becomes:
\frac{u^{n+1}-u^n}{\Delta t}=\triangledown^2u^n+f^n
And by following a similar calculation as given in the tutorial, we get:
\int\limits_{\Omega}uv dx=\int\limits_{\Omega}[u^n+\Delta t(\triangledown^2u^n+f^n)]v dx
Thus
a(u,v)=\int\limits_{\Omega}uv dx
L(v)=\int\limits_{\Omega}[u^n+\Delta t(\triangledown^2u^n+f^n)]v dx
where f is a constant function.
Now to compute the variational form in the code, I will have to compute the \triangledown^2u^n+f^n part which I’m finding it difficult.
Obviously the ufl.grad(ufl.grad(u_n))+f is not going to work because of the mismatch in the dimensions.
I first thought about having f as a constant numpy array. But I believe there should be a better way of handling this issue. And even for the numpy array I’m not exactly sure how to get the corresponding dimension related to ufl.grad(ufl.grad(u_n))
Appreciate your help and sorry again for the previous untidy question.
First of all, please format your code with markdown syntax, ie
```python
def f(x):
    return x
do you want to add f to each component of the matrix grad(grad(u_n))?
Please not that the following does not make sense, as double_derivativeis a 2x2 matrix, v a scalar value.
Please write down your variational form in latex formatting to make it easier for people to understand what you are trying to do.
I’m extremely sorry for the untidy format. I have edited it in a better way now
\Delta^2u is not equal to ufl.grad(ufl.grad(u)), But ufl.div(ufl.grad(u)).
Secondly, in the Finite element method, one uses integration by parts to reduce this term to `ufl.inner(ufl.grad(u), ufl.grad(v))*ufl.dx. See for instance:
https://jorgensd.github.io/dolfinx-tutorial/chapter1/fundamentals.html#finite-element-variational-formulation
Thank you so much. With your help I managed to do that.
So, L(v)=\int\limits_{\Omega}u^nvdx-\Delta t\int\limits_{\Omega}\triangledown u^n\triangledown v dx+\Delta t\int\limits_{\Omega}f^nvdx
I’m posting my entrie code below just in case if anyone else had the same problem:
import numpy
from dolfinx import mesh, fem
t = 0 # Start time
T = 2 # End time
num_steps = 20 # Number of time steps
dt = (T-t)/num_steps # Time step size
alpha = 3
beta = 1.2
nx, ny = 5, 5
domain = mesh.create_unit_square(MPI.COMM_WORLD, nx, ny, mesh.CellType.triangle)
class exact_solution():
    def __init__(self, alpha, beta, t):
        self.alpha = alpha
        self.beta = beta
        self.t = t
    def __call__(self, x):
        return 1 + x[0]**2 + self.alpha * x[1]**2 + self.beta * self.t
u_exact = exact_solution(alpha, beta, t)
u_D = fem.Function(V)
u_D.interpolate(u_exact)
tdim = domain.topology.dim
fdim = tdim - 1
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets))
u_n = fem.Function(V)
u_n.interpolate(u_exact)
f = fem.Constant(domain, beta - 2 - 2 * alpha)
def solve_problem(a,L,V,u_exact,num_steps,u_D):
    A = fem.petsc.assemble_matrix(a, bcs=[bc])
    b = fem.petsc.create_vector(L)
    uh = fem.Function(V)
    solver.setOperators(A)
    for n in range(num_steps):
        # Update Diriclet boundary condition
        u_exact.t+=dt
        with b.localForm() as loc_b:
            loc_b.set(0)
        fem.petsc.assemble_vector(b, L)
        fem.petsc.apply_lifting(b, [a], [[bc]])
        fem.petsc.set_bc(b, [bc])
        # Solve linear problem
        solver.solve(b, uh.vector)
        uh.x.scatter_forward()
        u_n.x.array[:] = uh.x.array
        # Compute L2 error and error at nodes
    V_ex = fem.FunctionSpace(domain, ("CG", 2))
    u_ex = fem.Function(V_ex)
    u_ex.interpolate(u_exact)
    error_L2 = numpy.sqrt(domain.comm.allreduce(fem.assemble_scalar(fem.form((uh - u_ex)**2 * ufl.dx)), op=MPI.SUM))
    if domain.comm.rank == 0:
        print(f"L2-error: {error_L2:.2e}")
    # Compute values at mesh vertices
    error_max = domain.comm.allreduce(numpy.max(numpy.abs(uh.x.array-u_D.x.array)), op=MPI.MAX)
        print(f"Error_max: {error_max:.2e}")
a_backward_Euler = fem.form(u * v * ufl.dx + dt*ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx)
L_backward_Euler = fem.form((u_n + dt * f) * v * ufl.dx)
solve_problem(a_backward_Euler,L_backward_Euler,V,u_exact,num_steps,u_D)
a_forward_Euler = fem.form(u * v * ufl.dx)
L_forward_Euler = fem.form((u_n * v * ufl.dx)-(dt*ufl.dot(ufl.grad(u_n),ufl.grad(v))*ufl.dx)+(dt*f*v*ufl.dx))
Source: Heat equation -Analytic solution
