I am currently trying so solve a simple time dependent 3D heat equation, however I am currently encountering some issues using a vector quantity in the final form to solve. My final form to solve looks like this:
G = as_tensor(T.dx(i), (i)) #gradient of T
G0 = as_tensor(T0.dx(i), (i)) # gradient of T at previous time step
q = -kappa*G
F = (1/dtime*(T-T0)*V - q[i]*V.dx(i)) * dv
But there seems to be an issue with using the vector quantity q as I get the following error:
File "/Users/parameterspace-test.py", line 79, in <module>
IndexError: only integers, slices (`:`), ellipsis (`...`), numpy.newaxis (`None`) and integer or boolean arrays are valid indices
How do I resolve this issue? My code is below.
import scipy as scipy
from ufl import as_tensor
from ufl import Index
import math
parameters["allow_extrapolation"] = True
set_log_level(50)
t_start = 0.0
t_end = 200
nstep = 400
dtime = (t_end - t_start)/ nstep #time step
p = 280 #W
kappamin = 0
kappamax = 1000
npstep = 100
for b in np.linspace(kappamin, kappamax, npstep):
kappa = b
data = 'mesh_3mm'
mesh = Mesh()
hdf = HDF5File(mesh.mpi_comm(), data+'.h5', 'r')
hdf.read(mesh, '/mesh', False)
cells_f = MeshFunction('size_t', mesh, 3)
hdf.read(cells_f, '/cells')
facets_f = MeshFunction('size_t', mesh, 2)
hdf.read(facets_f, '/facets')
boundaries = facets_f
all_cells = np.array(list(cells(mesh)))
tdim = mesh.topology().dim()
fdim = tdim - 1
mesh.init(fdim, tdim)
f_to_c = mesh.topology()(fdim, tdim)
c_to_f = mesh.topology()(tdim, fdim)
i,j,k = ufl.indices(3)
VectorSpace = VectorFunctionSpace(mesh, 'P', 1)
da = Measure('ds', domain=mesh, subdomain_data = facets_f, metadata = {'quadrature_degree': 2}) #area element
dv = Measure('dx', domain=mesh, subdomain_data = cells_f, metadata = {'quadrature_degree': 2}) #volume element
Space = FunctionSpace(mesh, 'P', 1)
T = Function(Space)
T0 = Function(Space)
T_init = Expression('Tambient', degree=1, Tambient=600.)
T = project(T_init, Space)
assign(T0,T)
V = TestFunction(Space) # Test Function used for FEA
dT = TrialFunction(Space) # Temperature Derivative
q0 = Function(VectorSpace) # heat flux at previous time step
i = Index()
q = -kappa*G
Gain = derivative(F, T, dT) # Gain will be used as the Jacobian required to determine the evolution of a dynamic system
problem = NonlinearVariationalProblem(F, T, [], Gain)
solver.parameters["newton_solver"]["relative_tolerance"] = 1E-4
solver.parameters["newton_solver"]["absolute_tolerance"] = 1E-3
solver.parameters["newton_solver"]["convergence_criterion"] = "residual"
solver.parameters["newton_solver"]["error_on_nonconvergence"] = True
solver.parameters["newton_solver"]["linear_solver"] = "cg"
solver.parameters["newton_solver"]["maximum_iterations"] = 10000
solver.parameters["newton_solver"]["preconditioner"] = "hypre_euclid"
solver.parameters["newton_solver"]["report"] = True
solver.parameters["newton_solver"]["krylov_solver"]["nonzero_initial_guess"] = False
solver.parameters["newton_solver"]["krylov_solver"]["relative_tolerance"] = 1E-4
solver.parameters["newton_solver"]["krylov_solver"]["absolute_tolerance"] = 1E-3
solver.parameters["newton_solver"]["krylov_solver"]["monitor_convergence"] = False
solver.parameters["newton_solver"]["krylov_solver"]["maximum_iterations"] = 100000
t = 0
#file_T << (T,t)
is_looping = True
for t in np.arange(t_start + dtime,t_end + dtime,dtime):
print( "Time", t)
solver.solve()
assign(T0, T)
is_looping = False
break
if not is_looping:
break
