Proceeding along the lines of the example I would like to set \bf g equal to a vector proportional to the normal \bf n to the boundary of the mesh, defined as
n = FacetNormal(mesh).
For example, I want to set {\bf g} = \sin(x) * \bf n. How should I modify BoundarySource to achieve this? If I just copy and paste the BoundarySource definition from the example, the code fails
$ python3 example.py
File "example.py", line 126, in <module>
g_D = BoundarySource(mesh)
File "example.py", line 96, in __init__
self.mesh = mesh
File "/usr/local/lib/python3.6/dist-packages/dolfin/function/expression.py", line 438, in __setattr__
elif name in self._parameters:
File "/usr/local/lib/python3.6/dist-packages/dolfin/function/expression.py", line 432, in __getattr__
return self._parameters[name]
[Previous line repeated 327 more times]
RecursionError: maximum recursion depth exceeded
Please note that you have not provided a minimal example.
The code that you have provided above does not produce your error message, as the following code returns no error:
class BoundarySource(UserExpression): # UserExpression instead of Expression
super().__init__(**kwargs) # This part is new!
self.markers = markers
values[0] = 1
values[1] = 2
def value_shape(self):
return (2,)
mesh = UnitSquareMesh(10, 10)
ft = MeshFunction("size_t", mesh, mesh.topology().dim()-1, 0)
bc = BoundarySource(markers=ft, degree=1)
Please provide a reproducible example, such that people can understand what modifications are implied by
import argparse
import ufl as ufl
# Create mesh
cylinder = Circle(Point(0.0, 0.0), 1.0)
domain = cylinder
mesh = generate_mesh(domain, 64)
boundary = 'on_boundary'
# Define function spaces
P_U = FiniteElement('P', triangle, 2)
P_V = VectorElement('P', triangle, 2)
element = MixedElement([P_U, P_V])
UV = FunctionSpace(mesh, element)
U = UV.sub(0).collapse()
V = UV.sub(1).collapse()
class g_expression(Expression):
def __init__(self, mesh):
self.mesh = mesh
def eval_cell(self, values, x, ufc_cell):
cell = Cell(self.mesh, ufc_cell.index)
n = cell.normal(ufc_cell.local_facet)
g = sin(5*x[0])
values[0] = g*n[0]
values[1] = g*n[1]
return (2,)
g_D = g_expression(mesh)
bc_v = DirichletBC(UV.sub(1), g_D, boundary)
when I run it I get
File "example.py", line 42, in <module>
File "example.py", line 32, in __init__
self.mesh = mesh
Note that I tried to include this minimal working example in the original post, but I could not modify it.
