How do I use a Python function to define Dirichlet boundary conditions which are not known in closed form?
Hello all! Hope you’re having a good one.
To illustrate my question I will use the 2d Poisson equation as a toy example, and will use the example code, which I also include here:
mesh = UnitSquareMesh(8, 8)
# Define boundary condition
u_D = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]', degree=2)
def boundary(x, on_boundary):
    return on_boundary
f = Constant(-6.0)
a = dot(grad(u), grad(v))*dx
L = f*v*dx
# Compute solution
solve(a == L, u, bc)
# Plot solution and mesh
plot(u)
Suppose now, however, that we do not know the closed form of the Dirichlet boundary conditions, but that we have a python function
def py_fun(x,y):
    return 1 + x**2 + 2*y**2
(this is for illustration purposes only, here we assume that in general we do not know the closed form of py_fun(x,y). This function may give some interpolation from numerically calculated data, e.g.)
How would we change the
part in order to implement the boundary conditions to be taken from py_fun(x,y)?
This topic might be related, but it only imposes constant boundary conditions.
Any input will be very helpful!
Thanks! :slight_smile:
EDIT: So, as per dokken’s suggestion, writing
class MyExpression0(UserExpression):
def eval(self, value, x):
   value[0] = py_fun(x[0],x[1])
u_D = MyExpression0()
Does the job.
Have a look at UserExpressions, for instance:
Here, you can substitute self.T with your function, which has to be evaluated at x[0],x[1],x[2]
