I’m working under FEniCS for 1 year for my PhD thesis and i wanted to first of all thanks you for this amazing work.
I’m coding an hyper-elastic FE with a damage formulation and i want to add an energy (that does not require integration) to my minimization.
Lets define S1 the model domain, S2 the domain of a left suture and S3 for a right one.
When the model is stretched, some sutures need to be took into account in order to hold the sample in the perpendicular direction : Wwire = 0.5*kwire(u(x)dS2-u(x)dS3+l0)**2 with l0 the initial distance between suture.
I guess the code will be more clear that me :
# Function used to efficiently project CG1 on DG0 space (for H)
dv = TrialFunction(V)
v_ = TestFunction(V)
a_proj = inner(dv, v_)*dx
b_proj = inner(v, v_)*dx
solver.factorize()
if u is None:
solver.solve_local_rhs(u)
return u
return
### Load boundaries and subdomains defined under gmsh
subdomains = MeshFunction("size_t", mesh, path + "/mesh_physical_region.xml")
boundaries = MeshFunction("size_t", mesh, path + "/mesh_facet_region.xml")
File(path + '/subdomains.pvd') << subdomains
File(path + '/boundaries.pvd') << boundaries
### Define domains
dx = Measure("dx", domain=mesh, subdomain_data=subdomains)
ds = Measure("ds", domain=mesh, subdomain_data=boundaries)
dS = Measure("dS", domain=mesh, subdomain_data=boundaries)
sutleft.append(ds(8000))
sutright.append(ds(8100))
dstop = ds(8103)
dsright = ds(8104)
dsbottom = ds(8105)
dsleft = ds(8106)
### Define function space
Vu = VectorFunctionSpace(mesh, "CG", 1)
Vtens = TensorFunctionSpace(mesh, "DG", 0)
Vfunc = FunctionSpace(mesh, "DG", 0)
### Define Dirichlet boundary
bcbottom = Constant((0., 0.))
bctop = Constant((0., 0.))
bcs = [
DirichletBC(Vu, bcbottom, boundaries, 8105),
DirichletBC(Vu, bctop, boundaries, 8103)]
### Define functions
du = TrialFunction(Vu) # Incremental displacement
v = TestFunction(Vu) # Test function
u = Function(Vu, name="Displacement")
E = Function(Vtens, name="E")
S = Function(Vtens, name="PK1 Stress")
### Initial parameters
zeros = Constant((0., 0.))
b = zeros # Body force per unit volume
ttop = zeros # Traction force on the boundary
tbottom = zeros # Traction force on the boundary
tleft = zeros
tright = zeros
### Suture wire energy
kwire = Constant(400)
l0sut = Constant(3)
Wwire = 0.5*kwire*(u.sub(0)*sutleft-u.sub(0)*sutright + l0sut)
### Stored strain energy density
psi = PSI(u=u, ...) # computed with another script
### External volumetric force
Fvol = dot(b, u)*dx
### External surface force
Fsurf = dot(ttop, u)*dstop+dot(tbottom, u)*dsbottom+dot(tleft, u)*dsleft+dot(tright, u)*dsright
### Total potential energy
Pi = psi*dx - Fvol - Fsurf + Wwire
### Solve variational problem at intial conditions
u.interpolate(Constant((0., 0.)))
F = derivative(Pi, u, v)
J = derivative(F, u, du)
problem_u = NonlinearVariationalProblem(F, u, bcs=bcs, J=J)
solver_u = NonlinearVariationalSolver(problem_u)
solver_u.parameters['newton_solver']['linear_solver'] = 'gmres'
solver_u.parameters['newton_solver']['preconditioner'] = 'hypre_euclid'
solver_u.parameters['newton_solver']['relative_tolerance'] = 1e-4
solver_u.parameters['newton_solver']['maximum_iterations'] = 100
solver_u.parameters['newton_solver']['error_on_nonconvergence'] = False
solver_u.parameters['newton_solver']['krylov_solver']['relative_tolerance'] = 1e-4
solver_u.parameters['newton_solver']['krylov_solver']['nonzero_initial_guess'] = True
solver_u.parameters['symmetric'] = True
step = np.arange(0,1.1,0.1)
res_f = []
for i in step :
bctop.assign(Constant((0., 30.*i)))
solver_u.solve()
### Write solutions
file_results.write(u, i)
local_project(strain(u), Vtens, E)
file_results.write(E, i)
local_project(stress(u, SEF, x, Name), Vtens, S)
file_results.write(S, i)
local_project(psi, Vfunc, SSE)
file_results.write(SSE, i)
I removed the damage part and i let the definition of the external energy to use it later.
As you can imagine i have some trouble to define Wwire and add it to the functional energy Pi.
i have read an old post a bit similar : https://fenicsproject.org/qa/6580/spring-functionals-assembling-non-integral-functional/ but without solution.
Thank you for the help
