Advection diffusion implementation issues
Hi all!
I’m working on a coupled advection-diffusion problem in dolfinx v0.9.0, and I’ve come across a behaviour I don’t fully understand, hoping someone might have seen something similar or has some ideas as to what’s going on.
I start by solving the steady-state incompressible Navier–Stokes equations in a lid-driven cavity:
\begin{aligned} \left( \mathbf{u} \cdot \nabla \mathbf{u} \right) - \mu \nabla^2 \mathbf{u} + \nabla p &= 0 \\\\ \nabla \cdot \mathbf{u} &= 0 \end{aligned}
with no-slip on all walls and a fixed velocity on the top. Resulting in the following:
I use this velocity field in a transient advection-diffusion simulation:
\frac{\partial c}{\partial t} + \mathbf{u} \cdot \nabla c - D \nabla^2 c = S
The diffusing species has a source that is active for a short time and then turned off. I apply a Dirichlet boundary condition c = 0 on the top wall, and no-flux (Neumann = 0) on all other sides.
What I expected: the larger the velocity term, the faster the diffusing species would be flushed out through the top. But what I’m seeing instead is that the rate at which the diffusing species leaves the system doesn’t change much with velocity. Strangely, the total cumulative flux at the top boundary actually increases with higher velocity, even though the source adds the same amount each time. So, effectively, the system is seeming leaking mass that doesn’t exist.
Not sure if this could be something to do with time-stepping, the way I’m imposing boundary conditions, integrated the advection term in the diffusion problem, or something deeper like stabilisation issues or numerical diffusion, or probably more likely, something fundamental I’ve misunderstood in this problem. Any thoughts or similar experiences would be great to hear.
from dolfinx.mesh import CellType, create_unit_square, meshtags
from dolfinx.log import set_log_level, LogLevel
import basix
import adios4dolfinx
def top_surface(x):
    return np.isclose(x[1], 1.0)
def lid_driven_cavity():
    domain = create_unit_square(MPI.COMM_WORLD, 50, 50, CellType.triangle)
    # Define Taylor-Hood element (P2-P1)
    element_u = basix.ufl.element(
        "Lagrange", domain.basix_cell(), 2, shape=(domain.geometry.dim,)
    element_p = basix.ufl.element("Lagrange", domain.basix_cell(), 1)
    mixed_ele = basix.ufl.mixed_element([element_u, element_p])
    # define function space and colla
    W = fem.functionspace(domain, mixed_ele)
    V_collapsed, _ = W.sub(0).collapse()
    # Functions and test functions
    up = fem.Function(W)
    v_q = ufl.TestFunctions(W)
    v, q = v_q
    u, p = ufl.split(up)
    # Viscosity
    nu = 1e-03
    # top wall velocity bc
    lid_u = fem.Function(V_collapsed)
    lid_u.interpolate(
        lambda x: np.array([1e-4 * np.ones(x.shape[1]), np.zeros(x.shape[1])])
    facets_lid = mesh.locate_entities_boundary(
        domain, domain.topology.dim - 1, top_surface
    dofs_lid = fem.locate_dofs_topological((W.sub(0), V_collapsed), 1, facets_lid)
    bc_lid = fem.dirichletbc(lid_u, dofs_lid, W.sub(0))
    # No-slip walls bcs
    def walls(x):
        return np.isclose(x[0], 0.0) | np.isclose(x[0], 1.0) | np.isclose(x[1], 0.0)
    wall_facets = mesh.locate_entities_boundary(domain, domain.topology.dim - 1, walls)
    wall_dofs = fem.locate_dofs_topological((W.sub(0), V_collapsed), 1, wall_facets)
    u_noslip = fem.Function(V_collapsed)
    u_noslip.x.array[:] = 0.0
    bc_walls = fem.dirichletbc(u_noslip, wall_dofs, W.sub(0))
    bcs = [bc_lid, bc_walls]
    dx = ufl.Measure("dx", domain=domain)
    # Define variational problem (steady Navier-Stokes)
    F = (
        nu * ufl.inner(ufl.grad(u), ufl.grad(v)) * dx
        + ufl.inner(ufl.grad(u) * u, v) * dx
        - p * ufl.div(v) * dx
        - q * ufl.div(u) * dx
    J = ufl.derivative(F, up)
    set_log_level(LogLevel.INFO)
    # Create nonlinear problem and solver
    problem = NonlinearProblem(F, up, bcs, J)
    solver.atol = 1e-10
    solver.rtol = 1e-8
    solver.max_it = 50
    solver.report = True
    ksp = solver.krylov_solver
    opts = PETSc.Options()
    opts[f"{option_prefix}ksp_type"] = "gmres"
    ksp.setFromOptions()
    # Solve
    n, converged = solver.solve(up)
    print(f"Converged: {converged} in {n} Newton iterations")
    # Extract solutions
    uh, ph = up.sub(0).collapse(), up.sub(1).collapse()
    uh.name = "velocity"
    ph.name = "pressure"
    # Save solution to file
    writer = io.VTXWriter(MPI.COMM_WORLD, "lid_driven_cavity.bp", uh, "BP5")
    writer.write(t=0)
    # write checkpoints file
    adios4dolfinx.write_mesh("lid_driven_cavity_cp.bp", mesh=domain)
    adios4dolfinx.write_function("lid_driven_cavity_cp.bp", uh, time=0.0)
def advection_diffusion(domain, velocity_field):
    # Define Lagrange element (P1)
    element = basix.ufl.element("P", domain.basix_cell(), 1)
    V = fem.functionspace(domain, element)
    u = fem.Function(V)
    u_n = fem.Function(V)
    # Diffusion coefficient
    D = 1e-3
    dofs_lid = fem.locate_dofs_topological(V, 1, facets_lid)
    bc_top = fem.dirichletbc(fem.Constant(domain, PETSc.ScalarType(0)), dofs_lid, V)
    # source term only active for first 300 seconds then zero
    source_value = lambda t: 100 if t <= 300 else 0
    source = fem.Constant(domain, PETSc.ScalarType(source_value(t=0)))
    dt = fem.Constant(domain, PETSc.ScalarType(20))
    vdim = domain.topology.dim
    num_cells = domain.topology.index_map(vdim).size_local
    mesh_cell_indices = np.arange(num_cells, dtype=np.int32)
    tags_volumes = np.full(num_cells, 1, dtype=np.int32)
    vmt = meshtags(domain, vdim, mesh_cell_indices, tags_volumes)
    dx = ufl.Measure("dx", domain=domain, subdomain_data=vmt)
    bcs = [bc_top]
    # Define variational problem (steady diffusion)
    F = D * ufl.inner(ufl.grad(u), ufl.grad(v)) * dx
    F += ((u - u_n) / dt) * v * dx
    F += ufl.inner(ufl.dot(ufl.grad(u), velocity_field), v) * dx
    F -= source * v * dx
    problem = fem.petsc.NonlinearProblem(
        F,
        u,
        bcs,
    solver.atol = 1e-12
    solver.rtol = 1e-12
    solver.max_it = 30
    ksp.setType("preonly")
    ksp.getPC().setType("lu")
    ksp.getPC().setFactorSolverType("mumps")
    ksp.setErrorIfNotConverged(True)
    final_time = 2000
    t = fem.Constant(domain, PETSc.ScalarType(0))
    n = ufl.FacetNormal(domain)
    times, top_flux = [], []
    while t.value < final_time:
        source.value = source_value(t=t.value)
        t.value += dt.value
        solver.solve(u)
        u_n.x.array[:] = u.x.array[:]
        top_flux_value = fem.assemble_scalar(
            fem.form(-D * ufl.dot(ufl.grad(u), n) * ds)
        advective_flux = fem.assemble_scalar(
            fem.form(ufl.inner(velocity_field, n) * u * ds)
        top_flux.append(top_flux_value + advective_flux)
        times.append(float(t.value))
    return times, top_flux
def read_velocity(filename):
    # Read the velocity field from the lid-driven cavity simulation
    domain = adios4dolfinx.read_mesh(filename, MPI.COMM_WORLD)
    P2 = basix.ufl.element(
    V = fem.functionspace(domain, P2)
    u_ldc = fem.Function(V)
    u_ldc.name = "velocity"
    adios4dolfinx.read_function(filename, u_ldc, time=0.0)
    return u_ldc
if __name__ == "__main__":
    force_cfd = False
    if force_cfd:
        lid_driven_cavity()
    from scipy.integrate import cumulative_trapezoid
    # Run the advection-diffusion simulation
    fig, axs = plt.subplots(2, 1, figsize=(6, 8), sharex=True)
    for scaling_factor in np.linspace(1, 1000, num=5):
        print(f"Scaling factor: {scaling_factor:.1f}")
        u_ldc = read_velocity("lid_driven_cavity_cp.bp")
        u_ldc.x.array[:] *= scaling_factor
        t, top_flux = advection_diffusion(
            domain=u_ldc.function_space.mesh, velocity_field=u_ldc
        axs[0].plot(t, top_flux, label="Top Flux")
        integral_flux = cumulative_trapezoid(top_flux, x=t, initial=0)
        axs[1].plot(t, integral_flux, label=f"{scaling_factor:.1f}x")
    axs[0].set_ylabel("Flux [s-1]")
    axs[1].set_ylabel("Cumulative flux")
    axs[1].set_xlabel("Time")
    plt.tight_layout()
    plt.legend()
I’m not sure if I fully understand. Your advective field has no normal component through the boundarie, right? So why would you expect the species to be ‘flushed out’?
The process by which the species leaves is diffusion (since u*n=0). So when you talk about the flux , do you indeed mean the normal component of the species gradiënt?
What does the graph look like for the species concentration as a function of time?
(I’m @James_Dark 's colleague)
Because there is a c=0 BC on the top so species are not flushed out but rather diffuse out.
Yes the diffusive flux as J = -D \nabla c \cdot n
As you increase the velocity, transport by advection dominates. The standard continuous Galerkin methods do not work well for such problems. You may want to look into stabilization methods or switch to DG/HDG.
When I increase the diffusion coefficient to reduce dominance of advective transport, the errors in cumulative flux reduce.
