Dear community,
I tried to adapt this Navier-Stokes example to a similar scenario with an L-shaped domain. The velocities are very turbulent and many velocities have an extreme value compared to their neighbours (see Fig. 1). Later on in the simulation all velocities are NaN (see Fig. 2). The boundary conditions are trivial, which means it can’t be the Gibbs phenomenon mentioned in this thread.
I don’t know what causes that bug and thus clueless how to fix it.
Many thanks in advance for your response!
Code to reproduce:
import pyvista
import os
from dolfinx.fem import (Constant, Function, FunctionSpace, dirichletbc, form, locate_dofs_topological)
from dolfinx.fem.petsc import (apply_lifting, assemble_matrix, assemble_vector, create_vector, create_matrix, set_bc)
from dolfinx.mesh import locate_entities_boundary
from ufl import (FiniteElement, TestFunction, TrialFunction, VectorElement, div, dot, dx, inner, lhs, grad, nabla_grad, rhs)
from dolfinx import io
import pygmsh
with pygmsh.geo.Geometry() as geom:
geom.add_polygon(
[0.0, 0.0],
[0.0, 1.0],
[0.5, 1.0],
[0.5, 0.5],
[1.0, 0.5],
[1.0, 0.0],
mesh_size=0.1,
mesh = geom.generate_mesh()
cells = [("triangle", mesh.cells_dict['triangle'])]
mesh = meshio.Mesh(mesh.points[:, :2], cells)
meshio.write("lshape.xdmf", mesh)
with io.XDMFFile(MPI.COMM_WORLD, "lshape.xdmf", 'r') as infile:
mesh = infile.read_mesh(name="Grid")
m_grid = pyvista.UnstructuredGrid(*create_vtk_mesh(mesh))
plotter = pyvista.Plotter()
plotter.add_mesh(m_grid, show_edges=True, opacity=0.5)
plotter.show_bounds(
grid='front',
location='outer',
all_edges=True)
plotter.view_xy()
plotter.show()
# Problem parameters
t = 0
T = 3 # Final time
dt = 0.1 # Time step size
num_steps = int(T / dt)
mu = Constant(mesh, PETSc.ScalarType(0.001)) # Dynamic viscosity
rho = Constant(mesh, PETSc.ScalarType(1)) # Density
v_cg2 = VectorElement("CG", mesh.ufl_cell(), 2)
s_cg1 = FiniteElement("CG", mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, v_cg2)
Q = FunctionSpace(mesh, s_cg1)
fdim = mesh.topology.dim - 1
gdim = 2
# Define boundary conditions
class InletPressure():
def __init__(self, t):
self.t = t
def __call__(self, x):
values = np.zeros((1, x.shape[1]), dtype=PETSc.ScalarType)
values[0] = np.sin(3.0 * self.t)
return values
DOLFIN_EPS = 0.000001
def inflow(x):
return x[1] > 1 - DOLFIN_EPS
def outflow(x):
return x[0] > 1 - DOLFIN_EPS
def boundary(x):
return np.logical_or(x[0] < DOLFIN_EPS,
x[1] < DOLFIN_EPS,
np.logical_and(x[0] > 0.5 - DOLFIN_EPS, x[1] > 0.5 - DOLFIN_EPS))
# Inlet
p_inlet = Function(Q)
inlet_pressure = InletPressure(t)
p_inlet.interpolate(inlet_pressure)
inflow_facets = locate_entities_boundary(mesh, fdim, inflow)
bcu_inflow = dirichletbc(p_inlet, locate_dofs_topological(Q, fdim, inflow_facets))
# Walls
u_nonslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
bndry_facets = locate_entities_boundary(mesh, fdim, boundary)
bcu_walls = dirichletbc(u_nonslip, locate_dofs_topological(V, fdim, bndry_facets), V)
bcu = [bcu_inflow, bcu_walls]
# Outlet
outflow_facets = locate_entities_boundary(mesh, fdim, outflow)
bcp_outlet = dirichletbc(PETSc.ScalarType(0), locate_dofs_topological(Q, fdim, outflow_facets), Q)
bcp = [bcp_outlet]
# Define variables
u_ = Function(V)
u_.name = "u"
u_s = Function(V)
u_n = Function(V)
u_n1 = Function(V)
p = TrialFunction(Q)
q = TestFunction(Q)
p_ = Function(Q)
p_.name = "p"
phi = Function(Q)
f = Constant(mesh, PETSc.ScalarType((0, 0)))
F1 = rho / k * dot(u - u_n, v) * dx
F1 += inner(dot(1.5 * u_n - 0.5 * u_n1, 0.5 * nabla_grad(u + u_n)), v) * dx
F1 += 0.5 * mu * inner(grad(u + u_n), grad(v)) * dx - dot(p_, div(v)) * dx
F1 += dot(f, v) * dx
a1 = form(lhs(F1))
L1 = form(rhs(F1))
A1 = create_matrix(a1)
b1 = create_vector(L1)
a2 = form(dot(grad(p), grad(q)) * dx)
L2 = form(-1 / k * dot(div(u_s), q) * dx)
A2.assemble()
b2 = create_vector(L2)
a3 = form(dot(u, v) * dx)
L3 = form(dot(u_s, v) * dx - k * dot(nabla_grad(phi), v) * dx)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
# Solver for step 1
solver1 = PETSc.KSP().create(mesh.comm)
solver1.setOperators(A1)
pc1 = solver1.getPC()
pc1.setType(PETSc.PC.Type.JACOBI)
# Solver for step 2
solver2 = PETSc.KSP().create(mesh.comm)
solver2.setOperators(A2)
solver2.setType(PETSc.KSP.Type.MINRES)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(mesh.comm)
solver3.setOperators(A3)
pc3 = solver3.getPC()
A3.assemble()
u_out = './u-shapeL'
p_out = './p-shapeL'
if not os.path.exists(u_out):
os.makedirs(u_out)
if not os.path.exists(p_out):
os.makedirs(p_out)
topology, cell_types, geometry = create_vtk_mesh(V)
u_grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
p_grid = pyvista.UnstructuredGrid(*create_vtk_mesh(Q))
for i in range(num_steps):
# Update current time step
# Update inlet velocity
inlet_pressure.t = t
A1.zeroEntries()
assemble_matrix(A1, a1, bcs=bcu)
A1.assemble()
with b1.localForm() as loc:
loc.set(0)
assemble_vector(b1, L1)
set_bc(b1, bcu)
solver1.solve(b1, u_s.vector)
u_s.x.scatter_forward()
# Step 2: Pressure corrrection step
with b2.localForm() as loc:
loc.set(0)
assemble_vector(b2, L2)
set_bc(b2, bcp)
solver2.solve(b2, phi.vector)
phi.x.scatter_forward()
p_.vector.axpy(1, phi.vector)
p_.x.scatter_forward()
with b3.localForm() as loc:
loc.set(0)
assemble_vector(b3, L3)
solver3.solve(b3, u_.vector)
u_.x.scatter_forward()
# Create plotter
u_plotter = pyvista.Plotter(off_screen=True)
p_plotter = pyvista.Plotter(off_screen=True)
p_plotter.add_title("Frame {}".format(i))
p_plotter.add_mesh(p_grid, style="wireframe", color="k")
p_grid["p"] = p_.x.array.real
p_plotter.add_mesh(p_grid, cmap='viridis')
p_plotter.show_bounds(
grid='front',
location='outer',
all_edges=True)
values = np.zeros((geometry.shape[0], 3), dtype=np.float64)
values[:, :len(u_)] = u_.x.array.real.reshape((geometry.shape[0], len(u_)))
u_grid["u"] = values
glyphs = u_grid.glyph(orient="u", scale=False, factor=0.1)
u_plotter.add_title("Frame {}".format(i))
u_plotter.add_mesh(glyphs, cmap='jet')
u_plotter.show_bounds(
grid='front',
location='outer',
all_edges=True)
u_plotter.view_xy()
u_plotter.screenshot("{}/{}.png".format(u_out, i))
p_plotter.view_xy()
p_plotter.screenshot("{}/{}.png".format(p_out, i))
with u_.vector.localForm() as loc_, u_n.vector.localForm() as loc_n, u_n1.vector.localForm() as loc_n1:
loc_n.copy(loc_n1)
loc_.copy(loc_n)
Figure 1:
Figure 2:
