All of the sudden getting the error AttributeError: 'NoneType' object has no attribute 'ufl_id' when code worked last week
I was using this code last week that ran and gave me my desired results.
# @title coupler - 3D FEM, 1D dG
The 1D and 3D domains are computed and coupled here.
import vtk
from vtk.util.numpy_support import vtk_to_numpy
from xii import *
from graphnics import *
from scipy.spatial import cKDTree
def save_mesh_vtk_dg(Lambda, file_path, radius_map, uh1d_dg=None):
    Saves a tube mesh as a VTK file with the option to include the 1D solution as a data array.
    Args:
        Lambda (dolfin.Mesh): The mesh to be saved.
        file_path (str): The path where the VTK file will be saved.
        radius_map (dolfin.UserExpression): A function to compute radius values at each point.
        uh1d (dolfin.Function, optional): A function representing 1D pressure data.
    Returns:
        None
    points = Lambda.coordinates()
    cells = {"line": Lambda.cells()}
    radius_values = np.array([radius_map(point) for point in points])
    uh1d_values = np.array([uh1d_dg(point) for point in points])
    if uh1d_dg is not None:
        mesh = meshio.Mesh(points, cells, point_data={"radius": radius_values, "Pressure1D": uh1d_values})
        mesh = meshio.Mesh(points, cells, point_data={"radius": radius_values})
    mesh.write(file_path)
    reader = vtk.vtkUnstructuredGridReader()
    reader.SetFileName(file_path)
    reader.Update()
    geometryFilter = vtk.vtkGeometryFilter()
    geometryFilter.SetInputData(reader.GetOutput())
    geometryFilter.Update()
    polydata = geometryFilter.GetOutput()
    writer = vtk.vtkPolyDataWriter()
    writer.SetFileName(file_path)
    writer.SetInputData(polydata)
    writer.Write()
def export_all_for_paraview(Lambda, Omega, uh1d_dg, uh3d_dg, radius_map, output_dir="vtk_output"):
    os.makedirs(output_dir, exist_ok=True)
    # --- Export 1D Vessel ---  #
    import pyvista as pv
    coords_1d = Lambda.coordinates()
    poly = pv.PolyData()
    poly.points = coords_1d
    # Build polyline segments from graph edges
    connectivity = []
    for i, j in ves_Geom.edges():
        connectivity.extend([2, i, j])  # VTK format: [n_points, pt0, pt1]
    poly.lines = np.array(connectivity)
    # Point data: pressure and radius
    pressure_1d = np.array([uh1d_dg(p) for p in coords_1d])
    radii_1d = np.array([radius_map(p) for p in coords_1d])
    poly["Pressure1D"] = pressure_1d
    poly["radius"] = radii_1d
    mesh1d_path = os.path.join(output_dir, "lambda_1d.vtp")
    poly.save(mesh1d_path)
    print(f"[EXPORT] Saved 1D vessel to: {mesh1d_path}")
    # --- Export 3D Tissue ---  #
    points_3d = Omega.coordinates()
    # Extract tetrahedral connectivity
    tetra_cells = [cell.entities(0) for cell in cells(Omega)]
    cells_3d = [("tetra", np.array(tetra_cells))]
    # Get pressure values at vertices
    pressure_3d = uh3d_dg.compute_vertex_values(Omega)
    mesh3d = meshio.Mesh(
        points_3d,
        cells_3d,
        point_data={"Pressure3D": pressure_3d}
    mesh3d_path = os.path.join(output_dir, "omega_3d.vtu")
    mesh3d.write(mesh3d_path)
    print(f"[EXPORT] Saved 1D mesh to {mesh1d_path}")
    print(f"[EXPORT] Saved 3D mesh to {mesh3d_path}")
class radius_function(UserExpression):
    A user expression to compute the radius at a given point based on the nearest control point in a graph.
    Args:
        ves_Geom (graphnics.FenicsGraph): The graph containing control points with radius information.
        mf (dolfin.MeshFunction): A mesh function associated with the graph.
        kdtree (scipy.spatial.cKDTree): A k-d tree for efficient nearest neighbor search in the graph.
        **kwargs: Additional keyword arguments to be passed to the UserExpression constructor.
    def __init__(self, ves_Geom, mf, kdtree, **kwargs):
        self.ves_Geom = ves_Geom
        self.mf = mf
        self.kdtree = kdtree
        super().__init__(**kwargs)
    def eval(self, value, x):
        p = (x[0], x[1], x[2])
        _, nearest_control_point_index = self.kdtree.query(p)
        nearest_control_point = list(self.ves_Geom.nodes)[nearest_control_point_index]
        value[0] = self.ves_Geom.nodes[nearest_control_point]['radius']
    def value_shape(self):
        return ()
def steadystate_dg(ves_Geom, directory_path, Lambda, Omega, mf, del_Omega, perf3, perf1, kappa, gamma_in, gamma_out, P):
    Runs a steady state simulation with prescribed pressure in both the 1D and 3D domains
    Args:
        G (graphnics.FenicsGraph): The graph representing the network.
        directory_path (str): The directory where the results will be saved
        del_Omega (float, optional): Boundary condition value for 3D pressure. Defaults to 3.0
        perf3     (float, optional): 3D perfusion coefficient
        perf1     (float, optional): 1D perfusion coefficient
        kappa     (float, optional): Transfer coefficient, defines the permeability
        gamma     (float, optional): Boundary condition coefficient for 1D pressure
        P         (float, optional): Boundary condition value for 1D pressure
    Returns:
        tuple (an ordered, unchanging list): A tuple containing:
            - output_file_1d (str): The path to the saved 1D pressure VTK file
            - output_file_3d (str): The path to the saved 3D pressure PVD file
            - uh1d (dolfin.Function): The computed 1D pressure function
            - uh3d (dolfin.Function): The computed 3D pressure function
    # Reference copy of \Lambda
    H = ves_Geom.copy()
    kdtree = cKDTree(np.array(list(nx.get_node_attributes(H, 'pos').values())))
    c = Omega.coordinates()
    zmin = np.min(c[:, 2])
    zmax = np.max(c[:, 2])
    zl = zmax - zmin
    #def boundary_Omega(x, on_boundary):
    #    return on_boundary and not near(x[2], zmin) and not near(x[2], zmax)
    # Constants
    kappa = Constant(kappa) #permeability or transfer coefficient
    gamma_in = Constant(gamma_in) #1D boundary coeff
    gamma_out = Constant(gamma_out) #1D boundary coeff
    P = Constant(P) #1D pressure value to be imposed
    #del_Omega = Constant(del_Omega) #3D pressure value to be imposed, comment back in when not doing convergence
    # Function spaces
    V1 = FunctionSpace(Lambda, "DG", 1)  # Now DG
    V3 = FunctionSpace(Omega, "CG", 1)
    W = [V3, V1]
    u3, u1 = list(map(TrialFunction, W))
    v3, v1 = list(map(TestFunction, W))
    # Mesh-related terms
    n = FacetNormal(Lambda)
    h = CellDiameter(Lambda)
    alpha = Constant(10.0)  # penalty parameter
    # define radius values for vessel - modeled as cylinder
    radius_map = radius_function(ves_Geom, mf, kdtree)
    cylinder = Circle(radius=radius_map, degree=5)
    # Define average of the cross-section
    u3_avg = Average(u3, Lambda, cylinder)
    v3_avg = Average(v3, Lambda, cylinder)
    # Dirac measures
    dxOmega = Measure("dx", domain=Omega) #3D
    dxLambda = Measure("dx", domain=Lambda) #1D
    #For dsLambda to be used in dG
    boundary_markers = MeshFunction("size_t", Lambda, Lambda.topology().dim() - 1, 0)
    #vessel inlet
    class BottomEnd(SubDomain):
            return on_boundary and near(x[2], 0.0)
    #vessl outlet
    class TopEnd(SubDomain):
            return on_boundary and near(x[2], 1.0)  # set to actual domain length in x[0], or use `np.max(Lambda.coordinates()[:, 0])`
    bottom = BottomEnd()
    top = TopEnd()
    bottom.mark(boundary_markers, 1)
    top.mark(boundary_markers, 2)
    dsLambda = Measure("ds", domain=Lambda, subdomain_data=boundary_markers)
    def inlet_3d(x, on_boundary):
    def outlet_3d(x, on_boundary):
    bc3d = [DirichletBC(V3, del_Omega, inlet_3d),
            DirichletBC(V3, del_Omega, outlet_3d)]
    # Define D_area and D_perimeter
    #D_area = Expression("pi*radius*radius", radius=radius_map, pi=np.pi, degree=2) # parameterization of cross-section
    #D_perimeter = Expression("2*pi*radius", radius=radius_map, pi=np.pi, degree=2) # boundary of cross-section (circumference)
    DG0 = FunctionSpace(Lambda, "DG", 0)
    D_area_expr = Expression("pi*radius*radius", radius=radius_map, pi=np.pi, degree=2)
    D_perimeter_expr = Expression("2*pi*radius", radius=radius_map, pi=np.pi, degree=2)
    D_area = interpolate(D_area_expr, DG0)
    D_perimeter = interpolate(D_perimeter_expr, DG0)
    # Blocks
    a00 = perf3*inner(grad(u3), grad(v3))*dxOmega + kappa*inner(u3_avg, v3_avg)*D_perimeter*dxLambda
    a01 = -kappa*inner(u1, v3_avg)*D_perimeter*dxLambda
    a10 = -kappa*inner(u3_avg, v1)*D_perimeter*dxLambda
    #a11 = perf1*inner(grad(u1), grad(v1))*D_area*dxLambda + kappa*inner(u1, v1)*D_perimeter*dxLambda - gamma*inner(u1, v1)*dsLambda
    # dG formulation for 1D block
    a11 = (
      - perf1*dot(avg(grad(u1)), jump(v1, n))*avg(D_area)*dS
      - perf1*dot(avg(grad(v1)), jump(u1, n))*avg(D_area)*dS
      + perf1*alpha('+')/h('+')*dot(jump(u1, n), jump(v1, n))*avg(D_area)*dS
      - gamma_in*inner(u1, v1)*D_area*dsLambda(1) + gamma_out*inner(u1, v1)*D_area*dsLambda(2)
    # Right-hand side
    L0 = inner(Constant(0), v3_avg)*dxLambda
    L1 = inner(Constant(0), v1)*D_area*dxLambda - gamma_in*inner(P, v1)*dsLambda(1) + gamma_out*inner(P, v1)*dsLambda(2)
    a = [[a00, a01], [a10, a11]]
    L = [L0, L1]
    # Define boundary subdomain for 1D
    class BottomBoundary1D(SubDomain):
            return near(x[2], 0.0)
    bc1d_dg = DirichletBC(V1, Constant(P), BottomBoundary1D(), method="pointwise")
    W_bcs = [
        bc3d,         # 3D
        [bc1d_dg]     # 1D
    A, b = map(ii_assemble, (a, L))
    A, b = apply_bc(A, b, W_bcs)
    A, b = map(ii_convert, (A, b))
    wh = ii_Function(W)
    solver = LUSolver(A, "mumps")
    solver.solve(wh.vector(), b)
    uh3d_dg, uh1d_dg = wh
    # Rename variables
    uh3d_dg.rename("3D Pressure", "3D Pressure Distribution")
    uh1d_dg.rename("1D Pressure", "1D Pressure Distribution")
    # SAVE AND RETURN SOLUTIONS #
    #os.makedirs(directory_path, exist_ok=True)
    #output_file_1d = os.path.join(directory_path, "pressure1d.vtk")
    #output_file_3d = os.path.join(directory_path, "pressure3d.pvd")
    #save_mesh_vtk(Lambda, output_file_1d, radius_map, uh1d=uh1d)
    #File(output_file_3d) << uh3d
    #return output_file_1d, output_file_3d, uh1d, uh3d, Lambda, Omega
       # Save for ParaView
    #export_all_for_paraview(Lambda, Omega, uh1d_dg, uh3d_dg, radius_map, output_dir=directory_path)
    return os.path.join(directory_path, "lambda_1d.vtk"), os.path.join(directory_path, "omega_3d.pvd"), uh1d_dg, uh3d_dg, Lambda, Omega
With the call function
output_file_1d, output_file_3d, uh1d_dg, uh3d_dg, Lambda, Omega = steadystate_dg(ves_Geom, OUTPUT_PATH,
    Lambda, Omega, mf,
    del_Omega=800,
    perf3=9.6e-2,
    perf1=1.45e4,
    kappa=3.0,
    gamma_in=1.0,
    gamma_out = 1.0,
    P=934
Logging back in this week I am all of the sudden getting the error
<ipython-input-6-38f996b25037> in <cell line: 0>()
     30 #)
     31
---> 32 output_file_1d, output_file_3d, uh1d_dg, uh3d_dg, Lambda, Omega = steadystate_dg(ves_Geom, OUTPUT_PATH,
     33     Lambda, Omega, mf,
     34     del_Omega=800,
6 frames
/usr/local/lib/python3.11/dist-packages/dolfin/fem/assembling.py in assemble(form, tensor, form_compiler_parameters, add_values, finalize_tensor, keep_diagonal, backend)
    214                 if hasattr(op, "ufl_function_space"):
    215                     same_mesh = bool(
--> 216                         same_mesh and op.ufl_function_space().ufl_domain().ufl_id() == dolfin_form.mesh().ufl_domain().ufl_id()
    217                     )
    218
Was there an update that occurred that changed the compatibility with certain elements of my setup? I am pretty new to fenics and FEM in general so any tips would be appreciated.
Indeed, we made small changes causing this error yesterday (sorry for inconvenience). It has been fixed today so your code should work again with the latest version.
Thank you for your quick reply. I am still getting the error today, I pulled from the following libraries today:
# @title Install required libraries (try-catch safe)
NOTE: You can save the Docker image state after running this block so that you don't have to run it every time you start a new environment.
import os, re
def replace_in_file(file_path):
    with open(file_path, 'r', encoding='utf-8') as file:
        content = file.read()
    # Replace 'ufl' with 'ufl_legacy'
    content = re.sub(r'\bufl\b', 'ufl_legacy', content)
    with open(file_path, 'w', encoding='utf-8') as file:
        file.write(content)
def process_directory(directory):
    for root, _, files in os.walk(directory):
        for file in files:
            if file.endswith('.py'):
                file_path = os.path.join(root, file)
# ipywidgets
try:
    import ipywidgets
except ImportError:
    !pip install ipywidgets
# dolfin
try:
    import dolfin
except ImportError:
    !wget "https://fem-on-colab.github.io/releases/fenics-install-release-real.sh" -O "/tmp/fenics-install.sh" && bash "/tmp/fenics-install.sh"
    import dolfin
# block
try:
    import block
except ImportError:
    !git clone "https://bitbucket.org/fenics-apps/cbc.block/src/master/"
    !pip install master/
# fenics_ii
try:
    import xii
except ImportError:
    !git clone "https://github.com/MiroK/fenics_ii"
    process_directory("fenics_ii/")
    !pip install fenics_ii/
# vtk
try:
    import vtk
except ImportError:
    !pip install vtk
# graphnics
try:
    import graphnics
except ImportError:
    !git clone "https://github.com/IngeborgGjerde/graphnics"
    !pip install graphnics/
# meshio
try:
except ImportError:
    !pip install meshio
# pyvista
try:
    import pyvista
except ImportError:
    !pip install pyvista
I should mention I am running code on Google Colab. Were any of the links to the repositories changed with this fix? Or should I just allow more time for the fix to take place?
Hi @al25,
I have triggered a rebuild of the FEniCS package in FEM on Colab, and the fix mentioned above should now be available there.
Keep in mind that if you have a notebook currently running you’ll need to go to “Runtime → Disconnect and delete runtime” to force it to the download the updated version.
