Getting an Attribute Error : 'Mesh' object has no attribute 'ufl_cell'
My code is as follows
    # This line needs to get cell data from what ever the markers have been called in the vtk file.
    # Expore this by printing mesh.cell_data
    # cell_data = mesh.get_cell_data("gmsh:physical", cell_type)
    if prune_z:
         points = mesh.points[:,:2]
    out_mesh = meshio.Mesh(points=points, cells={cell_type: cells})
    #, cell_data={"name_to_read":[cell_data]})
    return out_mesh
domain = meshio.read("testrve.xdmf")
from dolfinx.cpp.mesh import CellType
from dolfinx.io import (XDMFFile)
from dolfinx import mesh, fem, plot, io
from dolfinx.fem import FunctionSpace
V = dolfinx.fem.FunctionSpace(domain, ("CG", 2))
I am using the gmshModel API to create my mesh file. I am using the docker image of the Jupyter notebook for using FeniCSx. I was using the create_mesh function provided on this forum, but I think that is no longer required since I am directly using an xdmf file.
You cannot read in the xdmf file with meshio , and use it in DOLFINx.
You need to use the dolfinx.io.XDMFFile interface to read in such meshes, see for instance: Defining subdomains for different materials — FEniCSx tutorial
Yes, that worked. However now there is another issue, I get a RuntimeError: Cannot recognise cell type. Unknown value: mixed. I believe this has to do with the .xdmf file. I have pasted what I see in Notepad++ when I open the .xdmf file.
> <Xdmf Version="3.0">
> <Domain><Grid Name="Grid">
> <Geometry GeometryType="XYZ">
> <DataItem DataType="Float" Dimensions="4151 3" Format="HDF" Precision="8">testrve.h5:/data0</DataItem>
> </Geometry><Topology TopologyType="Mixed" NumberOfElements="8130">
> <DataItem DataType="Int" Dimensions="32520" Format="HDF" Precision="4">testrve.h5:/data1</DataItem>
> </Topology><Attribute Name="gmsh:dim_tags" AttributeType="Vector" Center="Node">
> <DataItem DataType="Int" Dimensions="4151 2" Format="HDF" Precision="4">testrve.h5:/data2</DataItem></Attribute>
> <Attribute Name="gmsh:physical" AttributeType="Scalar" Center="Cell">
> <DataItem DataType="Int" Dimensions="8130" Format="HDF" Precision="4">testrve.h5:/data3</DataItem>
> </Attribute><Attribute Name="gmsh:geometrical" AttributeType="Scalar" Center="Cell">
> <DataItem DataType="Int" Dimensions="8130" Format="HDF" Precision="4">testrve.h5:/data4</DataItem>
> </Attribute>
> </Grid>
> </Domain>
> </Xdmf>
    if prune_z:
    return out_mesh
with XDMFFile(MPI.COMM_WORLD, "testrve.xdmf", "r") as xdmf:
    domain = xdmf.read_mesh(name="Grid")
print(domain)
V = dolfinx.fem.FunctionSpace(domain, ("CG", 1))
This is my new code
This has been covered in various other topics, which you can find by searching for
on the forum.
An appropriate create_mesh function is also created at Defining subdomains for different materials — FEniCSx tutorial
which I already referred you to.
Actually it was a problem caused by my modification of the API code, I believe I have rectified it.
Thank You
