Dear community,
I want to solve a nonlinear problem using GMRES preconditioned with BoomerAMG. My setup experiences a strong memory leak when using a smoother, e.g. ParaSails. I am not sure whether this is related to the way I’ve set things up or if it’s an issue inside PETSc.
Consider the following hyperelasticity MWE (run with latest dolfinx release) of a clamped block elongated by a Neumann traction:
#!/usr/bin/env python3
import sys
from dolfinx import fem, mesh
import dolfinx.fem.petsc
comm = MPI.COMM_WORLD
msh = mesh.create_box(comm, [np.array([0.0, 0.0, 0.0]),np.array([2.0, 1.0, 1.0])], [5, 5, 5],
mesh.CellType.tetrahedron)
dx_ = ufl.Measure("dx", domain=msh)
# function space for displacement
V_u = fem.functionspace(msh, ("Lagrange", 1, (msh.geometry.dim,)))
# collect dofs and meshtags
dofs_left = fem.locate_dofs_geometrical(V_u, lambda x: np.isclose(x[0], 0.))
# select boundaries (right, bottom, top)
boundaries = [(1, lambda x: np.isclose(x[0], 2.)), (2, lambda x: np.isclose(x[1], 0.)), (3, lambda x: np.isclose(x[1], 1.))]
fdim = msh.topology.dim - 1
facets = mesh.locate_entities(msh, fdim, locator)
facet_indices.append(facets)
facet_tag = mesh.meshtags(msh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds_ = ufl.Measure("ds", domain=msh, subdomain_data=facet_tag)
# reference normal on mesh facets
n0 = ufl.FacetNormal(msh)
# define functions
du = ufl.TrialFunction(V_u) # Incremental displacement
var_u = ufl.TestFunction(V_u) # Test function
u = fem.Function(V_u, name='Displacement')
# disp increment for Newton
del_u = fem.Function(V_u)
# load
p = fem.Constant(msh, 0.0)
# Boundary conditions
zero = fem.Function(V_u)
zero.vector.set(0.0)
dbcs = [ fem.dirichletbc(zero, dofs_left) ]
F = ufl.variable(ufl.Identity(len(u)) + ufl.grad(u)) # deformation gradient
C = F.T*F # right Cauchy-Green tensor
mu, nu = 10., 0.3 # shear modulus and Poisson's ratio
beta = nu/(1.-2.*nu)
Psi = (mu/2.) * (ufl.tr(C) - msh.geometry.dim) + mu/(2.*beta)*(ufl.det(F)**(-2.*beta) - 1.) # strain energy density (compressible Neo-Hooke)
P = ufl.diff(Psi,F) # 1st Piola-Kirchhoff stress
# internal virtual work, plus Robin terms
k=1e3
n_o_n = ufl.outer(n0,n0)
dW_int = ufl.inner(P,ufl.grad(var_u))*dx_ + k*ufl.dot(n_o_n*u, var_u)*ds_(2) + k*ufl.dot(n_o_n*u, var_u)*ds_(3)
# external virtual work
dW_ext = p*ufl.det(F)*ufl.dot(ufl.dot(ufl.inv(F).T,n0), var_u)*ds_(1)
# nonlinear variational form: internal minus external virtual work
varform = dW_int - dW_ext
# Jacobian of nonlinear variational form
jac = ufl.derivative(varform, u, du)
r_form, jac_form = fem.form(varform), fem.form(jac)
r = fem.petsc.create_vector(r_form)
K = fem.petsc.create_matrix(jac_form)
# create solver
ksp = PETSc.KSP().create(comm)
ksp.setType("gmres")
ksp.getPC().setType("hypre")
ksp.getPC().setHYPREType("boomeramg")
opt_dict = {'pc_hypre_boomeramg_strong_threshold':0.7,
'pc_hypre_boomeramg_smooth_type':'parasails'} # Schwarz-smoothers, parasails, pilut, euclid
opts = PETSc.Options()
for o in opt_dict:
opts.setValue(o, opt_dict[o])
ksp.getPC().setFromOptions()
T = 1.0
nstep = 10000
dt = T/nstep
# load/time stepping
interval = np.linspace(0, T, nstep+1)
dp = 0.01
for (N, dt) in enumerate(np.diff(interval)):
t = interval[N+1]
p.value += dp
# Newton loop
tolres = 1.0e-8
tolinc = 1.0e-0
it = 0
maxiter = 25
# print header
if comm.rank == 0:
print("iter res 2-norm incr 2-norm")
sys.stdout.flush()
# assemble initial rhs vector
with r.localForm() as r_local: r_local.set(0.0)
fem.petsc.assemble_vector(r, r_form)
fem.petsc.apply_lifting(r, [jac_form], [dbcs], x0=[u.vector], scale=-1.0)
r.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
fem.petsc.set_bc(r, dbcs, x0=u.vector, scale=-1.0)
# get initial residual norm
struct_res_norm = r.norm()
if comm.rank == 0:
print("%i %.4e " % (it, struct_res_norm))
sys.stdout.flush()
it += 1
while it < maxiter:
# assemble system matrix
K.zeroEntries()
fem.petsc.assemble_matrix(K, jac_form, dbcs)
K.assemble()
# solve linear system
ksp.setOperators(K)
ksp.solve(-r, del_u.vector)
# get increment norm
struct_inc_norm = del_u.vector.norm()
# update solution
u.vector.axpy(1.0, del_u.vector)
u.vector.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
# assemble updated rhs vector
# get residual norm
if comm.rank == 0:
print("%i %.4e %.4e" % (it, struct_res_norm, struct_inc_norm))
sys.stdout.flush()
# increase iteration index
it += 1
# check if converged
if struct_res_norm <= tolres and struct_inc_norm <= tolinc:
break
Apologies for the length of the MWE, but I needed to run through the nonlinear solver loop to have the leak be obvious.
Removing l. 93 (ksp.getPC().setFromOptions()) seems to cure the problem: It runs and does not allocate unneeded memory. Setting the options, however, let’s it either fail due to a leak in step 2, or accumulates memory in case pc_hypre_boomeramg_strong_threshold is set to the default (0.25).
Has anyone worked with these PETSc smoothers, e.g. are there additional settings to take care of? Or would it be something rather to be reported in a PETSc forum, e.g. non-FEniCS related?
P.S. Setting a nullspace to the matrix like reported here, dolfinx/python/demo/demo_elasticity.py at main · FEniCS/dolfinx · GitHub, does not change the issue.
I’d appreciate any help.
Best,
Marc
