Hi,guys!I am optimizing a code for solving large PDEs.
It will probably solve a system of linear equations with a matrix of 150000 * 150000 in the end.
Therefore, assembling the bilinear matrix A at each time step requires a lot of time.
But A=A0+A1,where A0 remains constant at each time step.A1 contains a weak form of upwind format, therefore it is variable.
So my idea is to assemble A1 only in the time loop and then add it to A0 to form A.
use A.axpy(1.0,A0), But the program was killed.
Below, I have provided the minimum runnable code:
You only need to view the code after the weak form.
import petsc4py
from dolfinx import default_real_type, fem, io, mesh,default_scalar_type
from dolfinx.fem.petsc import assemble_matrix, assemble_vector
from ufl import (CellDiameter, FacetNormal, TestFunction, TrialFunction, avg,
conditional, div, dot, dS, ds, dx, grad, gt, inner, outer,
TrialFunctions,TestFunctions,curl,cross)
from dolfinx.io import gmshio,XDMFFile
from basix.ufl import element,mixed_element
create_vector, set_bc,create_matrix)
import time
startT=time.time()
num_time_steps =1000
out_interval=1
Ekman=0.001
Pm=5
Ra=100
Pr=1
ro=20/13
ri=7/13
tag="itertry3"
read_mesh = io.XDMFFile(MPI.COMM_WORLD, "cp6n_0.24w.xdmf" ,"r")
msh=read_mesh.read_mesh(name="Grid")
gdim = msh.geometry.dim
U_element=element("RT", msh.basix_cell(), 2)
#U_element=element("DG", msh.basix_cell(), k+1, shape=(msh.geometry.dim,))
P_element=element("DG", msh.basix_cell(), 1)
A_element=element("N1curl", msh.basix_cell(), 2)
T_element=element("DG", msh.basix_cell(), 1)
MIXED= mixed_element([U_element, P_element, A_element,T_element])
W =fem.functionspace(msh,MIXED)
W0,Wmap0=W.sub(0).collapse()
W1,Wmap1=W.sub(1).collapse()
W2,Wmap2=W.sub(2).collapse()
W3,Wmap3=W.sub(3).collapse()
(u,P,A,T)=ufl.TrialFunctions(W)
(v,q,Av,Tv)=ufl.TestFunctions(W)
#####dofs
imap = msh.topology.index_map(gdim)
num_cells = imap.size_local
ghost_cells = imap.num_ghosts
print(f"ID {msh.comm.rank}, num owned cells {num_cells} num ghost cells {ghost_cells},num dofs {W.dofmap.index_map.size_local * W.dofmap.index_map_bs}", flush=True)
u_n_1=fem.Function(W0)
u_n_2=fem.Function(W0)
u_D = fem.Function(W0)
A_n_1=fem.Function(W2)
A_n_2=fem.Function(W2)
T_n_1=fem.Function(W3)
T_n_2=fem.Function(W3)
T_D=fem.Function(W3)
T_D0=fem.Function(W3)
####weak form
t_end=0.01
delta_t = fem.Constant(msh, default_real_type(t_end / num_time_steps))
alpha = fem.Constant(msh, default_real_type(6.0))
h = CellDiameter(msh)
n = FacetNormal(msh)
def mean(vn,vn_1):
return 1/2*(vn+vn_1)
def star(v_n_1,v_n_2):
return 1/2*(3*v_n_1-v_n_2)
def jump(phi, n):
return outer(phi("+"), n("+")) + outer(phi("-"), n("-"))
lmbda = conditional(gt(dot(star(u_n_1,u_n_2), n), 0), 1, 0)
u_uw = lmbda("+") * mean(u,u_n_1)("+") + lmbda("-") * mean(u,u_n_1)("-")
T_uw = lmbda("+") * mean(T,T_n_1)("+") + lmbda("-") * mean(T,T_n_1)("-")
F0=Ekman*(inner(u / delta_t, v) * dx - inner(u_n_1 / delta_t, v) * dx)
F1= Ekman*(-inner(mean(u,u_n_1), div(outer(v, star(u_n_1,u_n_2)))) * dx +\
inner((dot(star(u_n_1,u_n_2), n))("+") * u_uw, v("+")) * dS + \
inner((dot(star(u_n_1,u_n_2), n))("-") * u_uw, v("-")) * dS + \
inner(dot(star(u_n_1,u_n_2), n) * lmbda * u, v) * ds)
F0+=Ekman * (inner(grad(mean(u,u_n_1)), grad(v)) * dx
- inner(avg(grad(mean(u,u_n_1))), jump(v, n)) * dS
- inner(jump(mean(u,u_n_1), n), avg(grad(v))) * dS
+ (alpha / avg(h)) * inner(jump(mean(u,u_n_1), n), jump(v, n)) * dS
- inner(grad(mean(u,u_n_1)), outer(v, n)) * ds
- inner(outer(mean(u,u_n_1), n), grad(v)) * ds
+ (alpha / h) * inner(outer(mean(u,u_n_1), n), outer(v, n)) * ds)
F0-= Ekman * (- inner(outer(mean(u_D,u_n_1), n), grad(v)) * ds
+ (alpha / h) * inner(outer(mean(u_D,u_n_1), n), outer(v, n)) * ds)
F0+=2*inner(cross(ufl.as_vector([0,0,1]),mean(u,u_n_1)),v)*dx
F0+=- inner(P, div(v)) * dx - inner(div(u), q) * dx
F0+= 1.0/Pm * inner(A/ delta_t,cross(curl(star(A_n_1,A_n_2)),v))*dx - 1.0/Pm * inner(A_n_1/ delta_t,cross(curl(star(A_n_1,A_n_2)),v))*dx
F0+= 1.0/Pm *inner(cross(curl(star(A_n_1,A_n_2)),mean(u,u_n_1)),cross(curl(star(A_n_1,A_n_2)),v))*dx
F0-= Ra * inner(ufl.as_vector([x[0],x[1],x[2]])*star(T_n_1,T_n_2),v) *dx
F0+= inner(A/ delta_t,Av) * dx -inner(A_n_1/ delta_t,Av) * dx
F0+=inner(cross(curl(star(A_n_1,A_n_2)),mean(u,u_n_1)),Av) *dx
F0+=1/Pm *inner(curl(mean(A,A_n_1)),curl(Av)) *dx
F0+= inner(T / delta_t, Tv) * dx -inner(T_n_1 / delta_t, Tv) * dx
F1+= -inner(mean(T,T_n_1), div(outer(Tv, star(u_n_1,u_n_2)))) * dx +\
inner((dot(star(u_n_1,u_n_2), n))("+") * T_uw, Tv("+")) * dS + \
inner((dot(star(u_n_1,u_n_2), n))("-") * T_uw, Tv("-")) * dS + \
inner(dot(star(u_n_1,u_n_2), n) * lmbda * T, Tv) * ds
F0+= (1/Pr)*(inner(grad(mean(T,T_n_1)), grad(Tv)) * dx
- inner(avg(grad(mean(T,T_n_1))), jump(Tv, n)) * dS
- inner(jump(mean(T,T_n_1), n), avg(grad(Tv))) * dS
+ (alpha / avg(h)) * inner(jump(mean(T,T_n_1), n), jump(Tv, n)) * dS
- inner(grad(mean(T,T_n_1)),outer(Tv,n)) * ds
- inner(outer(mean(T,T_n_1), n), grad(Tv)) * ds
+ (alpha / h) * inner(mean(T,T_n_1), Tv) * ds)
aa0=ufl.lhs(F0)
aa1=ufl.lhs(F1)
LL=ufl.rhs(F1+F0)
a0=fem.form(aa0)
a1=fem.form(aa1)
a=fem.form(aa0+aa1)
L=fem.form(LL)
star=time.time()
A0 = create_matrix(a0)
A1 = create_matrix(a0)
A = create_matrix(a0)
bcs=[]
A= assemble_matrix(a, bcs=bcs)
A0 = assemble_matrix(a0, bcs=bcs)
A0.assemble()
A1 = assemble_matrix(a1, bcs=bcs)
A1.assemble()
A.zeroEntries()
A.axpy(1.0,A0)
#A.axpy(1.0,A1)
b=create_vector(L)
endtime=time.time()
print(endtime-star)
ksp.setOperators(A)
ksp.setInitialGuessNonzero(True)
ksp.setConvergenceHistory(reset=True)
ksp.setType("gmres")
ksp.getPC().setType("ilu")
opts = PETSc.Options()
opts["ksp_rtol"] = 1.0e-8
ksp.setFromOptions()
A.axpy(1.0,A0) Resulted in the program being killed.
Thank you very much for any comments!Thanks!
