Issue in the size of sparse or dense matrix constructed from assemble_matrix for MPI
Hello All,
I am trying to perform the linear algebric operation Ax=b, where A matrix (denoted as Kf here) is obtained from the bilinear part of Variation formulation, and I have b (denoted as phirhs_petsc here) vector transformed to PETSc format.
Initialization
from dolfinx.la import InsertMode
from dolfinx.fem import (Function, FunctionSpace, form)
from dolfinx.fem.petsc import (apply_lifting, assemble_matrix, assemble_vector, set_bc )
from dolfinx.mesh import (CellType, GhostMode, create_box, create_rectangle, create_unit_square, locate_entities_boundary, meshtags)
from ufl import dx, grad, dot, inner, SpatialCoordinate, Measure, inv
from ufl import TrialFunction, TestFunction
from scipy.sparse import csr_matrix,lil_matrix
def mpi_print(s):
    print(f"Rank {comm.rank}: {s}")
dtype = PETSc.ScalarType  # type: ignore
comm = MPI.COMM_WORLD
rank = comm.rank
# Mesh (Either regular or Gmesh)
domain = create_unit_square(MPI.COMM_WORLD, 2, 2, ghost_mode=GhostMode.shared_facet)
tdim = domain.topology.dim
# Assuming `mesh` is the mesh created in the code
num_elements = domain.topology.index_map(tdim).size_local
num_nodes = domain.topology.index_map(0).size_local
# Summing up the counts from all processes in MPI_COMM_WORLD
num_elements_global = MPI.COMM_WORLD.allreduce(num_elements, op=MPI.SUM)
num_nodes_global = MPI.COMM_WORLD.allreduce(num_nodes, op=MPI.SUM)
num_cells = domain.topology.index_map(tdim).size_local + domain.topology.index_map(tdim).num_ghosts
num_vertices = domain.topology.index_map(0).size_local + domain.topology.index_map(0).num_ghosts
#Fespace
Vh1 = FunctionSpace(domain, ("CG", 1))
Vh1dc = FunctionSpace(domain, ("DG", 1))
Vh0 = FunctionSpace(domain, ("DG", 0))
Transforming the local numpy array to PETSc array
num_dofs_local = Vh1.dofmap.index_map.size_local
phirhs = Trf*rhoO
phirhsNO = Function(Vh1)
phirhsNO = phirhs[:num_dofs_local]
# Convert numpy array to PETSc vector
phirhs_petsc = PETSc.Vec().createWithArray(phirhsNO)
mpi_print(f"Size of phirhs vector: {len(phirhs_petsc.array)}")
Steps to validate the size of Kf matrix compatible with phirhs_petsc vector locally:
uf, vf = TrialFunction(Vh1), TestFunction(Vh1)
a = form(inner(grad(uf), grad(vf)) * dx + uf * vf * dx)
bc = []
Kf = assemble_matrix(a, bc)
Kf.assemble()
# Construct CSR matrix from PETSc matrix
assert isinstance(Kf, PETSc.Mat)
ai, aj, av = Kf.getValuesCSR()
Asp = csr_matrix((av, aj, ai))
mpi_print(f"Size of Kf in sparse matrix form: {Asp.shape}")
To test the size the Kf, I converted to sparse matrix as in Transform dolfinx assemble matrix to numpy array
Results from previous 2 sub codes for the 2 processors
Rank 0: Size of phirhs vector: 4
Rank 0: Size of Kf in sparse matrix form: (4, 8)
Rank 1: Size of phirhs vector: 5
Rank 1: Size of Kf in sparse matrix form: (5, 9)
And when I convert Kf to dense matrix to validate the size, they get spread on global mesh when I run run on MPI
# Construct dense matrix from PETSc matrix
C = Kf.convert('dense')
C.getDenseArray()
mpi_print(f"Size of Kf in dense matrix form: {C.size}")
Result from 2 processors
Rank 0: Size of Kf in dense matrix form: (9, 9)
Rank 1: Size of Kf in dense matrix form: (9, 9)
How can I make sure there is compatibility for matrix vector multiplication using MPI, as I am getting the satisfactory results for sequential?
Thanks
Just convert Asp to a numpy array (using Asp.toarray(), if memory serves).
Furthermore, note that:
  1. you can carry out most of the algebraic operations in petsc, without any need to convert matrix/vector to scipy/numpy
  2. if you don’t want to assemble a petsc matrix/vector, you may as well import assemble_matrix/assemble_vector from dolfinx.fem instead of dolfinx.fem.petsc
Thanks @francesco-ballarin
Exactly that is what I was trying to do before
Until I found my results for the ouput vector off in MPI as compared to sequential
MWE for algebraic operation
phirhs = Trf*rhoO
bc = []
Kf.assemble()
apply_lifting(phirhs_petsc, [a], [bc])
solver.setOperators(Kf)
opvec = Function(Vh1)
solver.solve(phirhs_petsc, opvec.vector)
opvec.x.scatter_forward()
opvecO = opvec.x.array
mpi_print(f"Size of output vector: {len(opvecO)}")
mpi_print(f"Range of output vector:{max(opvecO) , min(opvecO)}")
Using Sequential
Rank 0: Size of output vector: 9
Rank 0: Range of output vector:(0.6000000000000011, 0.6000000000000009)
Using MPI (2 Procs)
Rank 0: Size of output vector: 8
Rank 0: Range of output vector:(0.5777647955458147, 0.5711207707117077)
Rank 1: Size of output vector: 8
Rank 1: Range of output vector:(0.5777647955458147, 0.5711207707117077)
The size of the output vector is understandable it is on local+ghosts, I am more concerned about the range.
What I am doing wrong here?
Your code is not complete. Could you please provide a complete demo to show your attempt? And what
is you expectation?
@chenyongxin
Well, the complete code was little long to put here, but if it is difficult to understand my query from MWE, I will put the complete code and try to reexplain what I am trying to achieve.
Basically I want to perform this simple operation using MPI
Screenshot from 2024-04-10 13-47-58
n = # of nodes , m = # of columns
where rho is iniatialized on elements
Tf contains the basis funcitons of discontinuous galerkin elements of order 1 (DG1) arranged in sparse matrix form of size (nXm)
# from dolfinx.fem import assemble_matrix, assemble_vector
def mpi_print(s):
def mpi_print2(s1,s2):
    print(f"Rank {comm.rank}: {s1}, {s2}")
rank = comm.rank
#Fespace
def NO2overlapfe(rho):
    rho.x.scatter_reverse(InsertMode.add)
    rho.x.scatter_forward()
    rhoO = rho.x.array
    return rhoO
def NO2overlapvector(b_area,cell_area):
    assemble_vector(b_area.vector, cell_area)
    b_area.x.scatter_reverse(InsertMode.add)
    b_area.x.scatter_forward()
    areaK = b_area.x.array
    return areaK
# volume of the element
varea = TestFunction(Vh0)
cell_area = (form(varea*dx))
b_area = Function(Vh0)
areaK = NO2overlapvector(b_area,cell_area)
rho = Function(Vh0)
rho.vector.setArray(0.6)
rhoO = NO2overlapfe(rho)
etaf = TestFunction(Vh1dc)
Rhdc = (form(etaf*dx))
etaf_a = Function(Vh1dc)
RhdcO = NO2overlapvector(etaf_a,Rhdc)
# Mesh Connectivity
c2v = domain.topology.connectivity(domain.topology.dim, 0)
# Initialize sparse matrices
Trf = lil_matrix((num_vertices, num_cells))
for cell in range(num_cells):
    vertices = c2v.links(cell)
    dofs = Vh1dc.dofmap.cell_dofs(cell)
    for i, vertex in enumerate(vertices):
        Trf[vertex, cell] = RhdcO[dofs[i]]
Trf = Trf.tocsr()
Further Kf matrix is obtained from the weak formulation
phirhs = Trf*rhoO
bc = []
Kf.assemble()
opvecNO = opvecO[:num_dofs_local]
mpi_print(f"Size of output vector: {len(opvecNO)}")
mpi_print(f"Range of output vector:{max(opvecNO) , min(opvecNO)}")
There are few of the variable notations used in the code contains the suffix O or NO, where O represents owner dofs, whereas NO represents owner+ghosts dofs.
Comparison of results output vectors on serial and MPI
Serial:
MPI 2 procs:
Rank 0: Size of output vector: 4
Rank 0: Range of output vector:(0.5777647955458146, 0.5757310754894136)
Rank 1: Size of output vector: 5
I am still a little lost with your question. Let me guess that you want to say when you make it parallel with 2 processes, the value range of the partitioned vector opvecO is different from that of a serial run as quoted above?
If that is your confusion, just to check the RHS vector phirhs in serial VS in parallel:
phirhs = Trf*rhoO
mpi_print(f"phirhs: {np.sort(phirhs)}")
and it gives the following with a 2-process run
Rank 0: phirhs: [0.025 0.025 0.025 0.05  0.05  0.075 0.075 0.125]
Rank 1: phirhs: [0.025 0.025 0.025 0.05  0.05  0.075 0.075 0.125]
and it gives the following with a serial run
Rank 0: phirhs: [0.025 0.025 0.05  0.05  0.075 0.075 0.075 0.075 0.15 ]
So it means your problem is actually the phirhs is computed differently from the matrix-vector multiplication because the A matrix Trf is built locally but not globally in parallel:
Please consider the suggestion from @francesco-ballarin to replace the building of your matrix Trf directly in PETSc format instead of numpy or scipy conversion whatever:
